CPU usage when compiling on the Librem Mini
Exactly one that I bought.
So it does have some PD input actually? I had concern it has PD output 15W only but no input…
all ChromeOS devices with USB-C ports support USB-PD, starting with the 2015 Chromebook Pixel 2.
does USB-PD support always imply two-way powering?
(that should also mean all PD displays can be powered by PD)
I’m not 100% certain if the spec implies that, but all ChromeOS devices with USB-C ports support being externally powered via USB-C PD. I’m not sure how many, if any, support powering other devices via USB-C PD (outside of normal USB3 charging spec)
Interestingly enough we could measure actual power consumption of Chrome devices using just Suzy-Qable:
https://chromium.googlesource.com/chromiumos/third_party/hdctools/+/HEAD/docs/power_measurement.md
How did you use powerstat tool? It always shows 0W for me on Asus Chromebox 3:
$ powerstat
Running for 300.0 seconds (30 samples at 10.0 second intervals).
Power measurements will start in 180 seconds time.
  Time    User  Nice   Sys  Idle    IO  Run Ctxt/s  IRQ/s  Watts
14:45:43   1.0   0.0   0.7  98.3   0.1    1   1819    884   0.00
14:45:53   1.6   0.0   0.7  97.6   0.1    1   2119   1002   0.00
14:46:03   1.0   0.0   0.6  98.3   0.1    1   1844    850   0.00
14:46:13   1.5   0.0   0.5  97.8   0.1    1   1960    960   0.00
14:46:23   2.4   0.0   0.8  96.6   0.2    1   2319   1149   0.00
14:46:33  88.1   0.0   0.5  11.4   0.0   14   2946   2984   0.00
14:46:43  99.7   0.0   0.3   0.0   0.0   14   2395   2952   0.00
14:46:53  99.7   0.0   0.3   0.0   0.0   14   2441   3024   0.00
14:47:03  99.7   0.0   0.3   0.0   0.0   14   2375   2965   0.00
14:47:13  99.7   0.0   0.3   0.0   0.0   14   2484   3005   0.00
14:47:23  99.7   0.0   0.3   0.0   0.0   14   2284   2923   0.00
^C-------- ----- ----- ----- ----- ----- ---- ------ ------ ------
 Average  54.0   0.0   0.5  45.5   0.1  8.1 2271.6 2063.6   0.00
 GeoMean  14.3   0.0   0.4   0.0   0.0  4.2 2250.5 1782.4   0.00
  StdDev  48.0   0.0   0.2  47.8   0.1  6.5  311.1 1001.8   0.00
 Minimum   1.0   0.0   0.3   0.0   0.0  1.0 1819.3  850.0   0.00
 Maximum  99.7   0.0   0.8  98.3   0.2 14.0 2945.9 3023.6   0.00
Summary:
System:   0.00 Watts on average with standard deviation 0.00
Note: Power calculated from battery capacity drain, may not be accurate.
I can’t remember, it was quite a while ago that I did it. But I wasn’t using a Chromebook so that might make a difference.
It is Chromebox not Chromebook.
Do you still have that system?
No I sold it a while back
