Purism has informally indicated that the time interval between crimson and dawn will be less than the time interval between byzantium and crimson was, and you can see from the commit stream that @dos is already working on dawn but he has stated clearly that it is not ready for experimental download and install.
So don’t be too pessimistic but in any case I guess it depends on what you mean by “soon” - and I would in no way encourage Purism to make any more precise public statements about the timing for dawn.
Well, you can install and run it, you just won’t get any help nor compassion when things inevitably break There’s little value in reporting bugs and regressions at this point either.
Since crimson’s gnome calls USSD support was very unreliable compared to that of FuriOS forky, I wanted to try updating just gnome calls.
I installed individual debs by manually resolving dependencies, but gnome apps won’t start, firefox and thunderbird worked.
Then I did a dist-upgrade but keyboard won’t launch. I had to run
update-alternatives –config Phosh-OSKand select phosh-osk-stevia (I had to use jumpdrive and chroot). So you might want to add this to readme.
Also millipixels from backports don’t recognize qr codes, so I had to downgrade and hold it to the crimson version. Did you miss any patches or updates ?
The latest one also works not so good, Cyrillic symbols show up as “?”. It would be difficult to upgrade just gnome calls because they depends on whole gnome infrastructure like gnome-shell, gnome-control-center, etc.
Yes, I’ve disabled qr-codes to speed-up the app. gnome-decoder works fine with backports, please try it.
p.s. please do not try to upgrade your phone right now, there are some broken deps in the repo that I’m trying to fix to reach Gnome 50 environment.
OK, given that you may be running an unusual operating system, what about downloading standard crimson, flashing it to a spare µSD card, and temporarily booting your phone from µSD card. Does standard crimson provide correct haptic feedback?
The apps are very very slow since last update - most likely due to missing hardware acceleration and newer gtk4 (needs gles 3.0). It also power off more often.
I can still use USSD pay, though needs a lot of patience. Since it does not work well on crimson I can’t go back either
Hoping dawn comes sooner or newer mesa lands in crimson.
Update: Setting MESA_GLES_VERSION_OVERRIDE = 3.2 seems to help.
Now I’m wondering how to set it system wide, may be /etc/profile ?
I can get calls, chatty and millipixels to load faster, firefox gives a black screen, can’t see any text, gnome web still works, so can live with it.
I copied .desktop files from /usr/share/applications to .local/share/applications and added env MESA_GLES_VERSION_OVERRIDE=3.0 (not sure if 3.2 or 3.0 better) before the command on Exec= line.
I tried the same in /usr/share/wayland-sessions but it sees not working - millipixels loading screen keeps spinning even after millipixels itself is started. Is phosh ported to gtk4 yet?
Thanks for this link! I’ve just thought to upgrade my kernel but will do it more careful now. I used 6.18 for a week and do not observed troubles with mesa 26.2.0. Hope current update will be successful…
