Ah: sudo dpkg -i enteryourthemenamehere.deb
(either in the directory where the deb resides or with the proper path in the command.)
Beg pardon.
The problem isnāt installing the deb the problem is where are you getting the deb file from? If you go on gnome-look say for the Nordic theme, as far as I can tell there isnāt a deb file I can findā¦not one with apt search eitherā¦so does that mean I cannot install it?
I have no idea.
@wimdows
Where are you finding the *.debs? Please detail .
Here is the magical command for finding deb themes using apt:
apt list *-gtk-theme
EDIT: turns out if you use search in the forums you can find some good stuff.
There are a limited number of them, but suffice to say that there are a few to choose from including the DarkFire one.
That is how I found the adw-gtk3-dark.deb on github.
Most of the themes on gnome-look appear to have links to github pages as well.
Havenāt been able to install themes using the download and extract install method they describe so not sure what Iām doing wrong there.
Sorry, I havenāt tried that method.
Have seen this page:
https://itsfoss.com/install-switch-themes-gnome-shell/?
Yep, tried that canāt get it to work.
Hmm. Too bad.
I was happy to install the adw-gtk3-dark theme and tweak the colors with Gradience. I like the rounded buttons (for now), but couldnāt stand their original blueness.
Woops quoted the wrong github page for that adw-gtk3-dark theme: https://github.com/lassekongo83/adw-gtk3
Hmm. It seems that I installed DarkFire as a deb, and that I just copied the files that came with the adw-gtk3-dark theme. That appears to have worked as expected - didnāt do anything special, as far as I recall.
The instructions on the adw-gtk3 theme says, the files should be copied to ~/.local/share/themes/ or /usr/share/theme, not to both. (Just to make sure.)
Forgive me if I missed it when searching. Is there a documented way to set the lockscreen background independent of the home screen/desktop background?
You can accomplish it this way.
Thank you! Not sure how I missed that those instructions included the option for 2 separate backgrounds the first time through.
@amarok
Do you know where i can the name for the pulldown panel. I want to try to put a custom background on it but i canāt find its name.
No. Sorry.
I tried both locations, but Iām good with Greybird dark. I also disabled the highlight current line in gedit otherwise dark themes make the text unreadable. You do that with gsettings.
