Have you tried it with PureOS 10/Byzantium? I also have an Epson (WF series) which worked like a charm under PureOS 9/Amber, which seamlessly found it on the wireless network and printed perfectly from day 1 onwards, 18+months ago.
PureOS 10/Byzantium, however … that’s a different story so far.
Downloaded the allegedly appropriate Linux driver package from Epson. Then did:
Librem15:~/Downloads$ sudo apt-get install ./epson-inkjet-printer-escpr2_1.1.45-1lsb3.2_amd64.deb
Reading package lists... Done
Building dependency tree... Done
Note, selecting 'epson-inkjet-printer-escpr2' instead of './epson-inkjet-printer-escpr2_1.1.45-1lsb3.2_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
epson-inkjet-printer-escpr2 : Depends: lsb (>= 3.2) but it is not installable
E: Unable to correct problems, you have held broken packages.
Librem15:~/Downloads$ sudo apt-get install lsb
Package lsb is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'lsb' has no installation candidate
Both lsb-base and lsb-release are installed, from the byzantium repo, as version 11.1.0pureos1 (byzantium).
So, if you have moved up to byzantium, have you managed to finesse this issue as you did above for amber? This is now the one last thing holding me back from a working system such as I had before the upgrade to byzantium, which was a fresh install of the OS (not a dist-upgrade), and a restore from backup of the data files in Home. Thus, it is a totally clean byzantium system.
Any ideas applicable from your quest?
