Fix broken phoc.ini
I might have accidentally changed something in phoc.ini to something that does not work. The phone only shows the librem5 logo for a short while after the the disk decryption.
I believe that I would only have to change this file so I don’t want to reflash if it is not necessary.
What is the best way to fix this? How can I access and change the file? I have not set up ssh yet.
You can boot the phone and wait for the serial device to show up. Should show up together with the network interface. Then:
picocom -b 115200 /dev/ttyACM0
Log in and reinstall phoc, or fix it whichever other way.
Thanks a lot. That was exactly what I needed.
I fixed the file and the phone immediately showed the login screen.
