Geary Sending Issue
Hi,
I am trying to configure Geary for sending and receiving mail. Mail is being received but any attempt to send ends up in my ‘Outbox’ and never gets sent. The one thing in the account setup that I could not find are the port numbers. I tried putting the port after the server address as in server_addr:port. It takes the port number but that gets wiped out. I am not positive this is a port issue (there are no errors).
Is there a log?
Ideas?
One idea: you can start it with a debug flag from the command-line like this:
geary --debug > geary-log.txt
Then try sending an email again and look what you get in the geary-log.txt file.
@Skalman,
Thanks for the advice. I tried this twice. Once just to find out if it doing anything with the other three messages in my ‘Outbox’ and once when I sent another message. In both cases, the log file was empty.
Strange. When I run geary --debug it gives lots of output already when it starts, even if I don’t send or receive anything but just start it, there is still a lot of debug output. It works like that both on the Librem 5 and on a laptop where I also tried it. Are you sure you included the --debug option? Or could it be some typo or something?
Here is what the startup looks like for me:
purism@pureos:~$ geary --debug
*[wrn] 20:47:20.0722 Gtk:Locale not supported by C library.
	Using the fallback 'C' locale.
 [deb] 20:47:20.0720 GLib-GIO:_g_io_module_get_default: Found default implementation gvfs (GDaemonVfs) for ‘gio-vfs’
 [deb] 20:47:20.0731 GLib-GIO:_g_io_module_get_default: Found default implementation dconf (DConfSettingsBackend) for ‘gsettings-backend’
 [deb] 20:47:20.0731 dconf:watch_fast: "/org/gnome/desktop/interface/" (establishing: 0, active: 0)
 [deb] 20:47:20.0732 dconf:watch_fast: "/org/gnome/desktop/peripherals/mouse/" (establishing: 0, active: 0)
 [deb] 20:47:20.0732 dconf:watch_fast: "/org/gnome/settings-daemon/peripherals/mouse/" (establishing: 0, active: 0)
 [deb] 20:47:20.0732 dconf:watch_fast: "/org/gnome/desktop/sound/" (establishing: 0, active: 0)
 [deb] 20:47:20.0732 dconf:watch_fast: "/org/gnome/desktop/privacy/" (establishing: 0, active: 0)
 [deb] 20:47:20.0732 dconf:watch_fast: "/org/gnome/desktop/wm/preferences/" (establishing: 0, active: 0)
 [deb] 20:47:20.0733 dconf:watch_fast: "/org/gnome/settings-daemon/plugins/xsettings/" (establishing: 0, active: 0)
 [deb] 20:47:20.0733 dconf:watch_fast: "/org/gnome/desktop/a11y/" (establishing: 0, active: 0)
 [deb] 20:47:20.0735 dconf:watch_established: "/org/gnome/desktop/interface/" (establishing: 1)
 [deb] 20:47:20.0736 dconf:watch_established: "/org/gnome/desktop/peripherals/mouse/" (establishing: 1)
 [deb] 20:47:20.0736 dconf:watch_established: "/org/gnome/settings-daemon/peripherals/mouse/" (establishing: 1)
 [deb] 20:47:20.0736 dconf:watch_established: "/org/gnome/desktop/sound/" (establishing: 1)
 [deb] 20:47:20.0736 dconf:watch_established: "/org/gnome/desktop/privacy/" (establishing: 1)
 [deb] 20:47:20.0736 dconf:watch_established: "/org/gnome/desktop/wm/preferences/" (establishing: 1)
 [deb] 20:47:20.0736 dconf:watch_established: "/org/gnome/settings-daemon/plugins/xsettings/" (establishing: 1)
 [deb] 20:47:20.0736 dconf:watch_established: "/org/gnome/desktop/a11y/" (establishing: 1)
 [deb] 20:47:20.0890 Gdk:Compositor prefers decoration mode 'client'
 [deb] 20:47:21.0068 GLib:unsetenv() is not thread-safe and should not be used after threads are created
 [deb] 20:47:21.0068 Gtk:Connecting to session manager
 [deb] 20:47:21.0095 dconf:watch_fast: "/org/gnome/Geary/" (establishing: 0, active: 0)
 [deb] 20:47:21.0096 dconf:watch_fast: "/org/gnome/desktop/interface/" (establishing: 0, active: 1)
All that is from the first couple of seconds when geary is starting, then there is a lot more later on, probably something when sending also although I did not check that, I don’t have any email account configured right now.
You may need to do killall geary first - otherwise the command likely just calls the already running geary instance and exits.
See Tips & Tricks · Wiki · Librem5 / Librem 5 Community Wiki · GitLab under Geary. I think I added that tip. It definitely works for me.
Check config file as mentioned at POP3 -for- email - #26 by irvinewade
I am using a non-default port number for both incoming and outgoing.
Also be aware of a current problem: Keyring unlock / Email crashes (hopefully fix coming soon).
Thanks to all the respondents,
After the large update today, Geary started sending by itself. I did not make any configuration changes.
Ah, so the classic approach “wait for updates and hope for the best” worked this time! It’s not always the best approach but it does have some advantages, if you can afford to wait. :slight_smile:
Hello,
I have the same problem: Geary doesn’t send my messages but receives them and I see everything I have sent and received with my computer and tablet.
What’s the problem?
What should I do?
I don’t understand what has been written above.
Thanks in advance!
Patrick
French then english
Il semblerait qu’une mise à jour du système a réglé le problème de rsmereka
Tu peux tester la commande suivante
sudo apt update && sudo apt upgrade
Ou mettre à jour depuis l’app PureOs store
Si ça ne fonctionne toujours pas tu peux enregistrer les log de geary dans un fichier pour voir ce qui se passe quand tu envoi un email, avec la commande suivante (il faut fermer/tuer geary avant)
Seems like a simple system update solved rsmereka’s problem
You can test the following command
Or update from the PureOs store
if it still doesn’t work you can save the geary logs of what’s happening when you send an email with the following command (you have to close/kill geary before)
Hello,
I just realized that the problem I am having with Geary exists on two accounts I have opened with GANDI but not with my Librem.one account.
When I open Geary I get the following message: "Account problem
Geary encountered a problem sending email for patrick@…(my email) "
Underneath there are two buttons: “Details” and “Retry”.
When I click on Details I get a long message that I don’t understand and at the bottom of the window I find another button: “Logs”.
I was able to save these two long messages. But I don’t know how sending these here (*)
I thank you in advance for helping me to solve this problem.
Sincerely,
Patrick
PS: I add that I can’t create a mail account at « tdn-fait.net » and I don’t understand why ??? But it is another problem…
(*) I try to copy here the two messages :
First message :
Account identifier: goa_account_1617034988_1
Account provider: GEARY_SERVICE_PROVIDER_OTHER
Service type: GEARY_PROTOCOL_SMTP
Service host: mail.gandi.net
Error type: GearySmtpError 6
Message: “rcpt to:<@>” failed: 501 5.1.3 Bad recipient address syntax
Back trace:
  • geary_problem_report_construct
  • geary_account_problem_report_construct
  • geary_service_problem_report_construct
  • application_main_window_update_account_status
  • application_account_context_get_tls_validation_failed
  • g_closure_invoke
  • g_signal_handler_disconnect
  • g_signal_emit_valist
  • g_signal_emit
  • g_cclosure_marshal_BOOLEAN__BOXED_BOXEDv
  • g_object_notify_by_pspec
  • g_closure_invoke
  • g_signal_emit
  • geary_client_service_notify_unrecoverable_error
  • geary_smtp_client_service_get_sending_monitor
  • g_simple_proxy_resolver_set_uri_proxy
  • g_task_attach_source
  • geary_rf_c822_utils_get_best_encoding_finish
  • geary_smtp_authenticator_construct
  • g_io_stream_clear_pending
  • g_main_context_dispatch
  • g_main_context_iteration
  • g_application_run
  • _vala_main
  • __libc_start_main
  • _start
Geary version: 3.36.0
Geary revision:
GTK version: 3.24.27
GLib version: 2.58.3
WebKitGTK version: 2.30.6
Desktop environment: GNOME
Distribution name: PureOS
Distribution release: 9.0
Installation prefix: /usr
[deb] 07:29:13.0045 dconf:watch_fast: “/org/gnome/desktop/interface/” (establishing: 0, active: 0)
[deb] 07:29:13.0046 dconf:watch_fast: “/org/gnome/desktop/peripherals/mouse/” (establishing: 0, active: 0)
[deb] 07:29:13.0046 dconf:watch_fast: “/org/gnome/settings-daemon/peripherals/mouse/” (establishing: 0, active: 0)
[deb] 07:29:13.0046 dconf:watch_fast: “/org/gnome/desktop/sound/” (establishing: 0, active: 0)
[deb] 07:29:13.0046 dconf:watch_fast: “/org/gnome/desktop/privacy/” (establishing: 0, active: 0)
[deb] 07:29:13.0046 dconf:watch_fast: “/org/gnome/desktop/wm/preferences/” (establishing: 0, active: 0)
[deb] 07:29:13.0046 dconf:watch_fast: “/org/gnome/settings-daemon/plugins/xsettings/” (establishing: 0, active: 0)
[deb] 07:29:13.0046 dconf:watch_fast: “/org/gnome/desktop/a11y/” (establishing: 0, active: 0)
[deb] 07:29:13.0047 dconf:watch_established: “/org/gnome/desktop/interface/” (establishing: 1)
[deb] 07:29:13.0047 dconf:watch_established: “/org/gnome/desktop/peripherals/mouse/” (establishing: 1)
[deb] 07:29:13.0047 dconf:watch_established: “/org/gnome/settings-daemon/peripherals/mouse/” (establishing: 1)
[deb] 07:29:13.0047 dconf:watch_established: “/org/gnome/desktop/sound/” (establishing: 1)
[deb] 07:29:13.0048 dconf:watch_established: “/org/gnome/desktop/privacy/” (establishing: 1)
[deb] 07:29:13.0048 dconf:watch_established: “/org/gnome/desktop/wm/preferences/” (establishing: 1)
[deb] 07:29:13.0049 dconf:watch_established: “/org/gnome/settings-daemon/plugins/xsettings/” (establishing: 1)
[deb] 07:29:13.0049 dconf:watch_established: “/org/gnome/desktop/a11y/” (establishing: 1)
[deb] 07:29:13.0147 Gdk:Compositor prefers decoration mode ‘client’
[deb] 07:29:13.0278 Gtk:Connecting to session manager
[deb] 07:29:13.0305 dconf:watch_fast: “/org/gnome/Geary/” (establishing: 0, active: 0)
[deb] 07:29:13.0305 dconf:watch_fast: “/org/gnome/desktop/interface/” (establishing: 0, active: 1)
[deb] 07:29:13.0306 dconf:watch_established: “/org/gnome/Geary/” (establishing: 1)
[msg] 07:29:13.0315 geary:application-client.vala:839: Geary 3.36.0 prefix=/usr exec_dir=/usr/bin is_installed=true
[deb] 07:29:13.0548 GLib:posix_spawn avoided (fd close requested) (child_setup specified)
[deb] 07:29:13.0123 dconf:watch_fast: “/org/freedesktop/folks/” (establishing: 0, active: 0)
[deb] 07:29:13.0124 dconf:watch_established: “/org/freedesktop/folks/” (establishing: 1)
[deb] 07:29:13.0131 geary:application-plugin-manager.vala:55: Loading built-in plugin: Notification Badge
[deb] 07:29:13.0168 geary:application-plugin-manager.vala:55: Loading built-in plugin: Desktop Notifications
[deb] 07:29:13.0209 Gcr:starting initialize of registered modules
[deb] 07:29:13.0662 dconf:watch_fast: “/org/gnome/evolution/” (establishing: 0, active: 0)
[deb] 07:29:13.0663 Gcr:completed initialize of registered modules
[deb] 07:29:13.0663 Gcr:trust store uri is: (null)
[deb] 07:29:13.0663 Gcr:trust lookup uris are: pkcs11:library-description=PKCS%2311%20Kit%20Trust%20Module
[deb] 07:29:13.0663 geary:application-certificate-manager.vala:71: GCR slot URIs found: false
[deb] 07:29:13.0664 dconf:watch_established: “/org/gnome/evolution/” (establishing: 1)
[deb] 07:29:13.0845 GLib-GIO:Failed to initialize portal (GNetworkMonitorPortal) for gio-network-monitor: Not using portals
[deb] 07:29:13.0870 dconf:watch_fast: “/org/gnome/evolution-data-server/addressbook/” (establishing: 0, active: 0)
[deb] 07:29:13.0871 dconf:watch_established: “/org/gnome/evolution-data-server/addressbook/” (establishing: 1)
[deb] 07:29:14.0047 geary:db-versioned-database.vala:97: VersionedDatabase.upgrade: current database schema for /home/purism/.local/share/geary/goa_account_1617036125_5/geary.db: 25
[deb] 07:29:14.0101 geary:db-versioned-database.vala:97: VersionedDatabase.upgrade: current database schema for /home/purism/.local/share/geary/goa_account_1617035748_3/geary.db: 25
[deb] 07:29:14.0138 geary:imap-db-gc.vala:104: [GC:/home/purism/.local/share/geary/goa_account_1617036125_5/geary.db] GC state: last_reap_time=2021-03-29T21:11:16+0200 last_vacuum_time=never reaped_messages_since=0 free_page_bytes=86016
[deb] 07:29:14.0138 geary:db-versioned-database.vala:97: VersionedDatabase.upgrade: current database schema for /home/purism/.local/share/geary/goa_account_1617035806_4/geary.db: 25
[deb] 07:29:14.0192 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 0)
[deb] 07:29:14.0192 dconf:unwatch_fast: “/org/gtk/settings/purism/” (active: 0, establishing: 1)
[deb] 07:29:14.0194 dconf:watch_established: “/org/gtk/settings/purism/” (establishing: 1)
[deb] 07:29:14.0195 dconf:watch_established: “/org/gtk/settings/purism/” (establishing: 0)
[deb] 07:29:14.0195 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 1)
[deb] 07:29:14.0195 dconf:unwatch_fast: “/org/gtk/settings/purism/” (active: 2, establishing: 0)
[deb] 07:29:14.0199 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 2)
[deb] 07:29:14.0199 dconf:unwatch_fast: “/org/gtk/settings/purism/” (active: 3, establishing: 0)
[deb] 07:29:14.0206 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 3)
[deb] 07:29:14.0377 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 4)
[deb] 07:29:14.0377 dconf:unwatch_fast: “/org/gtk/settings/purism/” (active: 5, establishing: 0)
[deb] 07:29:14.0451 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 4)
[deb] 07:29:14.0452 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 5)
[deb] 07:29:14.0455 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 6)
[deb] 07:29:14.0817 geary:imap-db-gc.vala:104: [GC:/home/purism/.local/share/geary/goa_account_1617035748_3/geary.db] GC state: last_reap_time=2021-03-29T21:11:17+0200 last_vacuum_time=never reaped_messages_since=0 free_page_bytes=4096
[deb] 07:29:14.0896 geary:imap-db-gc.vala:131: [GC:/home/purism/.local/share/geary/goa_account_1617036125_5/geary.db] Reaping last completed on 2021-03-29T21:11:16+0200 (9 days ago)
[deb] 07:29:14.0896 geary:imap-db-gc.vala:141: [GC:/home/purism/.local/share/geary/goa_account_1617036125_5/geary.db] Database never vacuumed (0 messages reaped)
[deb] 07:29:14.0899 geary:db-versioned-database.vala:97: VersionedDatabase.upgrade: current database schema for /home/purism/.local/share/geary/goa_account_1617034988_1/geary.db: 25
[deb] 07:29:14.0899 geary:imap-db-gc.vala:104: [GC:/home/purism/.local/share/geary/goa_account_1617035806_4/geary.db] GC state: last_reap_time=2021-03-29T21:11:16+0200 last_vacuum_time=never reaped_messages_since=0 free_page_bytes=4096
[deb] 07:29:14.0917 geary:imap-db-gc.vala:131: [GC:/home/purism/.local/share/geary/goa_account_1617035748_3/geary.db] Reaping last completed on 2021-03-29T21:11:17+0200 (9 days ago)
[deb] 07:29:14.0917 geary:imap-db-gc.vala:141: [GC:/home/purism/.local/share/geary/goa_account_1617035748_3/geary.db] Database never vacuumed (0 messages reaped)
[deb] 07:29:14.0939 geary:util-connectivity-manager.vala:109: Checking if imap.zaclys.net:143 reachable…
[deb] 07:29:14.0951 dconf:watch_fast: “/system/proxy/” (establishing: 0, active: 0)
[deb] 07:29:14.0951 dconf:watch_fast: “/system/proxy/http/” (establishing: 0, active: 0)
[deb] 07:29:14.0951 dconf:watch_fast: “/system/proxy/https/” (establishing: 0, active: 0)
[deb] 07:29:14.0951 dconf:watch_fast: “/system/proxy/ftp/” (establishing: 0, active: 0)
[deb] 07:29:14.0951 dconf:watch_fast: “/system/proxy/socks/” (establishing: 0, active: 0)
[deb] 07:29:14.0954 dconf:watch_established: “/system/proxy/” (establishing: 1)
[deb] 07:29:14.0954 dconf:watch_established: “/system/proxy/http/” (establishing: 1)
[deb] 07:29:14.0955 dconf:watch_established: “/system/proxy/https/” (establishing: 1)
[deb] 07:29:14.0955 dconf:watch_established: “/system/proxy/ftp/” (establishing: 1)
[deb] 07:29:14.0955 dconf:watch_established: “/system/proxy/socks/” (establishing: 1)
[deb] 07:29:14.0985 geary:imap-db-gc.vala:131: [GC:/home/purism/.local/share/geary/goa_account_1617035806_4/geary.db] Reaping last completed on 2021-03-29T21:11:16+0200 (9 days ago)
[deb] 07:29:14.0985 geary:imap-db-gc.vala:141: [GC:/home/purism/.local/share/geary/goa_account_1617035806_4/geary.db] Database never vacuumed (0 messages reaped)
[deb] 07:29:14.0985 geary:db-versioned-database.vala:97: VersionedDatabase.upgrade: current database schema for /home/purism/.local/share/geary/account_02/geary.db: 25
[deb] 07:29:14.0986 geary:util-connectivity-manager.vala:240: Remote imap.zaclys.net:143 became reachable
[deb] 07:29:15.0022 geary:imap-db-gc.vala:104: [GC:/home/purism/.local/share/geary/goa_account_1617034988_1/geary.db] GC state: last_reap_time=2021-03-29T21:11:53+0200 last_vacuum_time=never reaped_messages_since=0 free_page_bytes=417792
[deb] 07:29:15.0022 geary:util-connectivity-manager.vala:109: Checking if mail.gandi.net:993 reachable…
[deb] 07:29:15.0023 geary:db-versioned-database.vala:97: VersionedDatabase.upgrade: current database schema for /home/purism/.local/share/geary/account_01/geary.db: 25
[deb] 07:29:15.0058 geary:util-connectivity-manager.vala:109: Checking if imap.librem.one:993 reachable…
[deb] 07:29:15.0060 geary:imap-db-gc.vala:104: [GC:/home/purism/.local/share/geary/account_02/geary.db] GC state: last_reap_time=2021-03-29T21:37:27+0200 last_vacuum_time=never reaped_messages_since=0 free_page_bytes=106496
[deb] 07:29:15.0060 geary:util-connectivity-manager.vala:240: Remote mail.gandi.net:993 became reachable
[deb] 07:29:15.0094 geary:imap-db-gc.vala:131: [GC:/home/purism/.local/share/geary/goa_account_1617034988_1/geary.db] Reaping last completed on 2021-03-29T21:11:53+0200 (9 days ago)
[deb] 07:29:15.0094 geary:imap-db-gc.vala:141: [GC:/home/purism/.local/share/geary/goa_account_1617034988_1/geary.db] Database never vacuumed (0 messages reaped)
[deb] 07:29:15.0094 geary:util-connectivity-manager.vala:240: Remote imap.librem.one:993 became reachable
[deb] 07:29:15.0111 geary:imap-db-gc.vala:104: [GC:/home/purism/.local/share/geary/account_01/geary.db] GC state: last_reap_time=never last_vacuum_time=never reaped_messages_since=0 free_page_bytes=4096
[deb] 07:29:15.0112 geary:imap-db-gc.vala:131: [GC:/home/purism/.local/share/geary/account_02/geary.db] Reaping last completed on 2021-03-29T21:37:27+0200 (9 days ago)
[deb] 07:29:15.0112 geary:imap-db-gc.vala:141: [GC:/home/purism/.local/share/geary/account_02/geary.db] Database never vacuumed (0 messages reaped)
[deb] 07:29:15.0158 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineLoadFolders(goa_account_1617034988_1)
[deb] 07:29:15.0158 Geary[ALL]: [goa_account_1617034988_1] [imap] GearyImapClientService: Started
[deb] 07:29:15.0158 Geary[ALL]: [goa_account_1617034988_1] [imap] GearyImapClientService: Checking session pool with 0 of 0 free
[deb] 07:29:15.0629 geary:imap-db-gc.vala:122: [GC:/home/purism/.local/share/geary/account_01/geary.db] Recommending reaping: never completed
[deb] 07:29:15.0629 geary:imap-db-gc.vala:141: [GC:/home/purism/.local/share/geary/account_01/geary.db] Database never vacuumed (0 messages reaped)
[deb] 07:29:15.0629 geary:imap-db-gc.vala:258: [GC:/home/purism/.local/share/geary/account_01/geary.db] Starting garbage collection of IMAP database
[deb] 07:29:15.0629 geary:imap-db-gc.vala:287: [GC:/home/purism/.local/share/geary/account_01/geary.db] Garbage collector reaping date: 2021-03-09T07:29:15+0100 (1615271355)
[deb] 07:29:15.0630 geary:util-connectivity-manager.vala:109: Checking if disroot.org:993 reachable…
[deb] 07:29:15.0630 Geary[ALL]: [goa_account_1617034988_1] [imap] GearyImapClientService: Opening new session
[deb] 07:29:15.0637 Geary[ALL]: [goa_account_1617034988_1] [imap] GearyImapClientService: Opening new session
[deb] 07:29:15.0638 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineStartPostie(goa_account_1617034988_1)
[deb] 07:29:15.0638 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEnginePopulateSearchTable(goa_account_1617034988_1)
[deb] 07:29:15.0674 Geary[ALL]: [goa_account_1617034988_1] [queued: 2] GearyImapEngineAccountProcessor: Executing operation: GearyImapEngineLoadFolders(goa_account_1617034988_1)
[deb] 07:29:15.0707 geary:util-connectivity-manager.vala:109: Checking if mail.ecloud.global:993 reachable…
[msg] 07:29:15.0707 geary:imap-db-gc.vala:316: [GC:/home/purism/.local/share/geary/account_01/geary.db] Found 0 email messages ready for reaping
[msg] 07:29:15.0707 geary:imap-db-gc.vala:347: [GC:/home/purism/.local/share/geary/account_01/geary.db] Reaped completed: 0 messages
[deb] 07:29:15.0709 geary:util-connectivity-manager.vala:240: Remote disroot.org:993 became reachable
[msg] 07:29:15.0790 geary:imap-db-gc.vala:370: [GC:/home/purism/.local/share/geary/account_01/geary.db] Completed: Reaped 0 attachment files
[deb] 07:29:15.0816 Geary[ALL]: [goa_account_1617034988_1] [imap] [connecting] GearyImapClientSession: Connected to mail.gandi.net:993
[deb] 07:29:15.0818 Geary[ALL]: [goa_account_1617034988_1] [imap] [connecting] GearyImapClientSession: Connected to mail.gandi.net:993
[deb] 07:29:15.0819 geary:util-connectivity-manager.vala:240: Remote mail.ecloud.global:993 became reachable
[deb] 07:29:15.0838 Geary[ALL]: [goa_account_1617034988_1] [imap] [connecting] GearyImapClientSession: ok #1: IMAP4rev1 ENABLE LOGIN-REFERRALS “AUTH=PLAIN” SASL-IR ID LITERAL+ IDLE
[deb] 07:29:15.0840 Geary[ALL]: [goa_account_1617034988_1] [imap] [connecting] GearyImapClientSession: ok #1: IMAP4rev1 ENABLE LOGIN-REFERRALS “AUTH=PLAIN” SASL-IR ID LITERAL+ IDLE
[deb] 07:29:15.0953 Geary[ALL]: [goa_account_1617034988_1] [imap] [authorizing] GearyImapClientSession: ok #2: “THREAD=ORDEREDSUBJECT” “THREAD=REFS” “THREAD=REFERENCES” “PREVIEW=FUZZY” QUOTA QRESYNC ID MULTIAPPEND UNSELECT SASL-IR URL-PARTIAL IDLE ENABLE NAMESPACE WITHIN LIST-STATUS “CONTEXT=SEARCH” CONDSTORE BINARY UIDPLUS CHILDREN “SNIPPET=FUZZY” LOGIN-REFERRALS NOTIFY MOVE “I18NLEVEL=1” LIST-EXTENDED SAVEDATE CATENATE SORT “SORT=DISPLAY” “STATUS=SIZE” SEARCHRES IMAP4rev1 LITERAL+ ESEARCH ESORT
[deb] 07:29:15.0974 Geary[ALL]: [goa_account_1617034988_1] [imap] [authorizing] GearyImapClientSession: ok #2: “THREAD=ORDEREDSUBJECT” “THREAD=REFS” “THREAD=REFERENCES” “PREVIEW=FUZZY” QUOTA QRESYNC ID MULTIAPPEND UNSELECT SASL-IR URL-PARTIAL IDLE ENABLE NAMESPACE WITHIN LIST-STATUS “CONTEXT=SEARCH” CONDSTORE BINARY UIDPLUS CHILDREN “SNIPPET=FUZZY” LOGIN-REFERRALS NOTIFY MOVE “I18NLEVEL=1” LIST-EXTENDED SAVEDATE CATENATE SORT “SORT=DISPLAY” “STATUS=SIZE” SEARCHRES IMAP4rev1 LITERAL+ ESEARCH ESORT
[deb] 07:29:16.0123 Geary[ALL]: [goa_account_1617034988_1] [imap] [authorized] GearyImapClientSession: Using INBOX: INBOX/\HasNoChildren
[deb] 07:29:16.0124 Geary[ALL]: [goa_account_1617034988_1] [imap] [authorized] GearyImapClientSession: Using INBOX: INBOX/\HasNoChildren
[deb] 07:29:16.0167 geary:util-connectivity-manager.vala:109: Checking if smtp.librem.one:465 reachable…
[deb] 07:29:18.0804 geary:imap-db-account.vala:906: goa_account_1617035806_4: Populating search table
[deb] 07:29:18.0804 geary:imap-db-account.vala:938: goa_account_1617035806_4: Searching for up to 50 missing indexed messages…
[deb] 07:29:18.0870 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>INBOX, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:18.0894 geary:imap-db-account.vala:920: goa_account_1617035806_4: Done populating search table
[deb] 07:29:18.0894 Geary[ALL]: [goa_account_1617034988_1] [imap] [authorized] GearyImapClientSession: Default personal namespace: (,/)
[deb] 07:29:18.0895 Geary[ALL]: [goa_account_1617034988_1] [imap] [authorized] GearyImapClientSession: Default personal namespace: (,/)
[deb] 07:29:18.0895 Geary[ALL]: [goa_account_1617034988_1] [imap] GearyImapClientService: Status changed to: connected
[deb] 07:29:18.0895 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineUpdateRemoteFolders(goa_account_1617034988_1)
[deb] 07:29:18.0991 geary:util-connectivity-manager.vala:240: Remote smtp.librem.one:465 became reachable
[deb] 07:29:19.0047 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:19.0064 geary:util-connectivity-manager.vala:109: Checking if mail.ecloud.global:587 reachable…
[deb] 07:29:19.0065 geary:util-connectivity-manager.vala:109: Checking if disroot.org:465 reachable…
[deb] 07:29:19.0065 geary:util-connectivity-manager.vala:109: Checking if smtp.zaclys.net:587 reachable…
[deb] 07:29:19.0067 geary:imap-db-account.vala:906: account_01: Populating search table
[deb] 07:29:19.0067 geary:imap-db-account.vala:938: account_01: Searching for up to 50 missing indexed messages…
[deb] 07:29:19.0068 geary:imap-db-account.vala:906: account_02: Populating search table
[deb] 07:29:19.0068 geary:imap-db-account.vala:938: account_02: Searching for up to 50 missing indexed messages…
[deb] 07:29:19.0070 geary:imap-db-account.vala:906: goa_account_1617036125_5: Populating search table
[deb] 07:29:19.0070 geary:imap-db-account.vala:938: goa_account_1617036125_5: Searching for up to 50 missing indexed messages…
[deb] 07:29:19.0139 geary:util-connectivity-manager.vala:240: Remote mail.ecloud.global:587 became reachable
[deb] 07:29:19.0139 geary:util-connectivity-manager.vala:240: Remote disroot.org:465 became reachable
[deb] 07:29:19.0139 geary:util-connectivity-manager.vala:240: Remote smtp.zaclys.net:587 became reachable
[deb] 07:29:19.0141 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>INBOX, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:19.0165 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>INBOX, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:19.0186 geary:imap-db-account.vala:920: account_01: Done populating search table
[deb] 07:29:19.0186 geary:imap-db-account.vala:920: account_02: Done populating search table
[deb] 07:29:19.0186 geary:imap-db-account.vala:920: goa_account_1617036125_5: Done populating search table
[deb] 07:29:19.0191 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>INBOX, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:19.0221 geary:util-connectivity-manager.vala:109: Checking if mail.gandi.net:465 reachable…
[deb] 07:29:19.0223 geary:imap-db-account.vala:906: goa_account_1617035748_3: Populating search table
[deb] 07:29:19.0223 geary:imap-db-account.vala:938: goa_account_1617035748_3: Searching for up to 50 missing indexed messages…
[deb] 07:29:19.0268 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Archive)
[deb] 07:29:19.0268 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Archives)
[deb] 07:29:19.0268 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Brouillons)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Corbeille)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Deleted Messages)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Drafts)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Envoyés)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>INBOX)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Junk)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Sent)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Sent Messages)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Spam)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Trash)
[deb] 07:29:19.0269 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Enqueuing operation: GearyImapEngineCheckFolderSync(goa_account_1617034988_1:>Archives>2019)
[deb] 07:29:19.0287 geary:conversation-viewer.vala:364: Showing: loading_page
[deb] 07:29:19.0287 geary:application-main-window.vala:729: Folder selected: GearyImapEngineOtherFolder(>INBOX, open_count=0, remote_opened=false)
[deb] 07:29:19.0291 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Promoting GearyImapEngineOtherFolder(>Archive, open_count=0, remote_opened=false) to GEARY_SPECIAL_FOLDER_TYPE_ARCHIVE
[deb] 07:29:19.0292 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Promoting GearyImapEngineOtherFolder(>Drafts, open_count=0, remote_opened=false) to GEARY_SPECIAL_FOLDER_TYPE_DRAFTS
[deb] 07:29:19.0293 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Promoting GearyImapEngineOtherFolder(>Sent, open_count=0, remote_opened=false) to GEARY_SPECIAL_FOLDER_TYPE_SENT
[deb] 07:29:19.0294 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Promoting GearyImapEngineOtherFolder(>Junk, open_count=0, remote_opened=false) to GEARY_SPECIAL_FOLDER_TYPE_SPAM
[deb] 07:29:19.0295 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Promoting GearyImapEngineOtherFolder(>Trash, open_count=0, remote_opened=false) to GEARY_SPECIAL_FOLDER_TYPE_TRASH
[deb] 07:29:19.0297 geary:util-connectivity-manager.vala:240: Remote mail.gandi.net:465 became reachable
[deb] 07:29:19.0297 Geary[ALL]: [goa_account_1617034988_1] [>INBOX, open_count=1, remote_opened=false] GearyImapEngineOtherFolder: Folder opened
[deb] 07:29:19.0299 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>INBOX, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:19.0300 Geary[ALL]: [goa_account_1617034988_1] [>INBOX, open_count=1, remote_opened=false] GearyImapEngineOtherFolder: Opening remote session
[deb] 07:29:19.0300 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Acquiring folder session for: >INBOX
[deb] 07:29:19.0301 Geary[ALL]: [goa_account_1617034988_1] [queued: 16] GearyImapEngineAccountProcessor: Executing operation: GearyImapEngineStartPostie(goa_account_1617034988_1)
[deb] 07:29:19.0301 Geary[ALL]: [goa_account_1617034988_1] [imap] GearyImapClientService: Claiming session with 2 of 2 free
[deb] 07:29:19.0301 Geary[ALL]: [goa_account_1617034988_1] [smtp] GearySmtpClientService: Filling queue
[deb] 07:29:19.0397 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:19.0423 geary:imap-db-account.vala:920: goa_account_1617035748_3: Done populating search table
[deb] 07:29:19.0424 Geary[ALL]: [goa_account_1617034988_1] [smtp] GearySmtpClientService: Started
[deb] 07:29:19.0424 Geary[ALL]: [goa_account_1617034988_1] [smtp] GearySmtpClientService: Starting outbox postie with 12 messages queued
[deb] 07:29:19.0425 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:19.0993 Geary[ALL]: [goa_account_1617034988_1] [queued: 15] GearyImapEngineAccountProcessor: Executing operation: GearyImapEnginePopulateSearchTable(goa_account_1617034988_1)
[deb] 07:29:19.0993 geary:imap-db-account.vala:906: goa_account_1617034988_1: Populating search table
[deb] 07:29:19.0993 geary:imap-db-account.vala:938: goa_account_1617034988_1: Searching for up to 50 missing indexed messages…
[deb] 07:29:20.0059 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>INBOX, open_count=2, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:20.0091 Geary[ALL]: [goa_account_1617034988_1] [smtp] GearySmtpClientService: Outbox postie: Sending “Notre pique-nique…” (ID:GearyOutboxEmailIdentifier(1,9))…
[deb] 07:29:20.0094 geary:imap-engine-replay-queue.vala:516: ReplayQueue.do_replay_local_async ReplayQueue:GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false) (notification=0 local=0 local_active=false remote=1 remote_active=false) exiting
[deb] 07:29:20.0137 geary:imap-engine-replay-queue.vala:631: ReplayQueue.do_replay_remote_async ReplayQueue:GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false) (notification=0 local=0 local_active=false remote=0 remote_active=false) exiting
[deb] 07:29:20.0163 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:20.0163 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>INBOX>Archives, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:20.0216 geary:imap-engine-replay-queue.vala:516: ReplayQueue.do_replay_local_async ReplayQueue:GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false) (notification=0 local=0 local_active=false remote=1 remote_active=false) exiting
[deb] 07:29:20.0245 geary:imap-engine-replay-queue.vala:631: ReplayQueue.do_replay_remote_async ReplayQueue:GearyImapEngineOtherFolder(>Archive, open_count=1, remote_opened=false) (notification=0 local=0 local_active=false remote=0 remote_active=false) exiting
[deb] 07:29:20.0246 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>Brouillons, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:20.0369 geary:smtp-client-session.vala:136: [mail.gandi.net:465] Attempting PLAIN authenticator
[deb] 07:29:20.0414 geary:imap-engine-email-prefetcher.vala:114: GearyImapEngineOtherFolder(>Archives, open_count=1, remote_opened=false): Scheduling 0 messages on open for prefetching
[deb] 07:29:20.0435 geary:imap-db-account.vala:920: goa_account_1617034988_1: Done populating search table
[deb] 07:29:20.0436 Geary[ALL]: [goa_account_1617034988_1] [queued: 14] GearyImapEngineAccountProcessor: Executing operation: GearyImapEngineUpdateRemoteFolders(goa_account_1617034988_1)
[deb] 07:29:20.0436 Geary[ALL]: [goa_account_1617034988_1] GearyImapEngineOtherAccount: Acquiring account session
[deb] 07:29:20.0437 Geary[ALL]: [goa_account_1617034988_1] [imap] GearyImapClientService: Claiming session with 1 of 2 free
[deb] 07:29:20.0458 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0000/mail.gandi.net:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered $Junk Junk $MDNSent \Flagged * \Seen $Forwarded \Deleted \Draft NonJunk LoadRemoteImages, accepts_user_flags: true] GearyImapFolderSession: EXISTS 781
[deb] 07:29:20.0497 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0000/mail.gandi.net:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered $Junk Junk $MDNSent \Flagged * \Seen $Forwarded \Deleted \Draft NonJunk LoadRemoteImages, accepts_user_flags: true] GearyImapFolderSession: RECENT 0
[deb] 07:29:21.0472 Geary[ALL]: [goa_account_1617034988_1] [>INBOX, open_count=2, remote_opened=false] GearyImapEngineOtherFolder: Begin normalizing remote and local folders
[deb] 07:29:21.0483 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0004/mail.gandi.net:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered Junk \Flagged * \Seen $Forwarded \Deleted \Draft NonJunk, accepts_user_flags: true] GearyImapFolderSession: EXISTS 34
[deb] 07:29:21.0485 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0004/mail.gandi.net:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered Junk \Flagged * \Seen $Forwarded \Deleted \Draft NonJunk, accepts_user_flags: true] GearyImapFolderSession: RECENT 0
[deb] 07:29:21.0502 Geary[ALL]: [goa_account_1617034988_1] [>INBOX, open_count=2, remote_opened=false] GearyImapEngineOtherFolder: Messages only appended (local/remote UIDNEXT=22785/22786 total=780/781 diff=1), gathering mail UIDs 22785:22785
[deb] 07:29:21.0523 geary:conversation-list-store.vala:441: Adding 13 conversations.
[deb] 07:29:21.0561 geary:conversation-list-store.vala:447: Added 13/13 conversations.
[deb] 07:29:21.0566 geary:app-fill-window-operation.vala:44: Filled 20 of 20 locally, window: 13, total: 780
[deb] 07:29:21.0583 geary:app-email-store.vala:150: EmailStore GearyImapEngineOtherAccount(goa_account_1617034988_1) running GearyAppListOperation on 13 emails
[deb] 07:29:21.0594 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0002/imap.zaclys.net:143/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: (none), accepts_user_flags: unknown] GearyImapFolderSession: EXISTS 35
[deb] 07:29:21.0602 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0002/imap.zaclys.net:143/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: (none), accepts_user_flags: unknown] GearyImapFolderSession: RECENT 0
[deb] 07:29:21.0602 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0005/mail.gandi.net:993/up)), Imap.Folder(>Archives), ro: unknown, permanent_flags: \Answered \Flagged * \Seen \Deleted \Draft, accepts_user_flags: true] GearyImapFolderSession: EXISTS 0
[deb] 07:29:21.0604 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0005/mail.gandi.net:993/up)), Imap.Folder(>Archives), ro: unknown, permanent_flags: \Answered \Flagged * \Seen \Deleted \Draft, accepts_user_flags: true] GearyImapFolderSession: RECENT 0
[deb] 07:29:21.0611 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0003/imap.zaclys.net:143/up)), Imap.Folder(>INBOX>Archives), ro: unknown, permanent_flags: (none), accepts_user_flags: unknown] GearyImapFolderSession: EXISTS 0
[deb] 07:29:21.0615 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0003/imap.zaclys.net:143/up)), Imap.Folder(>INBOX>Archives), ro: unknown, permanent_flags: (none), accepts_user_flags: unknown] GearyImapFolderSession: RECENT 0
[deb] 07:29:21.0654 Geary[ALL]: [goa_account_1617034988_1] [>INBOX, open_count=3, remote_opened=false] GearyImapEngineOtherFolder: Loaded local (0) and remote (1) UIDs, normalizing…
[deb] 07:29:21.0656 Geary[ALL]: [goa_account_1617034988_1] [>INBOX, open_count=3, remote_opened=false] GearyImapEngineOtherFolder: Changes since last seen: removed=0 appended=1 inserted=0
[deb] 07:29:21.0677 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0008/disroot.org:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered $Junk Junk $MDNSent \Flagged * \Seen \Deleted \Draft NonJunk, accepts_user_flags: true] GearyImapFolderSession: EXISTS 76
[deb] 07:29:21.0678 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0009/disroot.org:993/up)), Imap.Folder(>Archive), ro: unknown, permanent_flags: \Answered \Flagged * \Seen \Deleted \Draft, accepts_user_flags: true] GearyImapFolderSession: EXISTS 0
[deb] 07:29:21.0683 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0008/disroot.org:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered $Junk Junk $MDNSent \Flagged * \Seen \Deleted \Draft NonJunk, accepts_user_flags: true] GearyImapFolderSession: RECENT 0
[deb] 07:29:21.0684 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(0009/disroot.org:993/up)), Imap.Folder(>Archive), ro: unknown, permanent_flags: \Answered \Flagged * \Seen \Deleted \Draft, accepts_user_flags: true] GearyImapFolderSession: RECENT 0
[msg] 07:29:21.0737 geary:imap-db-database.vala:122: Garbage collection of IMAP database /home/purism/.local/share/geary/account_01/geary.db failed: Error opening directory ‘/home/purism/.local/share/geary/account_01/attachments’: No such file or directory
[deb] 07:29:21.0760 geary:conversation-viewer.vala:364: Showing: conversation_page
[deb] 07:29:21.0766 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 7)
[deb] 07:29:21.0766 dconf:unwatch_fast: “/org/gtk/settings/purism/” (active: 8, establishing: 0)
[deb] 07:29:21.0769 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 8)
[deb] 07:29:21.0770 dconf:unwatch_fast: “/org/gtk/settings/purism/” (active: 9, establishing: 0)
[deb] 07:29:21.0770 dconf:watch_fast: “/org/gtk/settings/purism/” (establishing: 0, active: 8)
[deb] 07:29:22.0722 geary:app-email-store.vala:150: EmailStore GearyImapEngineOtherAccount(goa_account_1617034988_1) running GearyAppFetchOperation on 1 emails
[deb] 07:29:22.0752 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(000B/mail.ecloud.global:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered Junk \Flagged * \Seen $Forwarded \Deleted \Draft NonJunk, accepts_user_flags: true] GearyImapFolderSession: EXISTS 5
[deb] 07:29:22.0753 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(000A/mail.ecloud.global:993/up)), Imap.Folder(>Brouillons), ro: unknown, permanent_flags: \Answered \Flagged * \Seen \Deleted \Draft, accepts_user_flags: true] GearyImapFolderSession: EXISTS 0
[deb] 07:29:22.0780 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(000B/mail.ecloud.global:993/up)), Imap.Folder(>INBOX), ro: unknown, permanent_flags: \Answered Junk \Flagged * \Seen $Forwarded \Deleted \Draft NonJunk, accepts_user_flags: true] GearyImapFolderSession: RECENT 0
[deb] 07:29:22.0780 Geary[ALL]: [GearyImapClientSession(selecting, GearyImapClientConnection(000A/mail.ecloud.global:993/up)), Imap.Folder(>Brouillons), ro: unknown, permanent_flags: \Answered \Flagged * \Seen \Deleted \Draft, accepts_user_flags: true] GearyImapFolderSession: RECENT 0
[deb] 07:29:22.0818 Geary[ALL]: [goa_account_1617034988_1] [smtp] GearySmtpClientService: SMTP send mail error: “rcpt to:<@>” failed: 501 5.1.3 Bad recipient address syntax
[deb] 07:29:22.0849 Geary[ALL]: [goa_account_1617034988_1] [>INBOX, open_count=3, remote_opened=false] GearyImapEngineOtherFolder: Finished creating/merging 1 emails
[deb] 07:29:22.0859 geary:imap-engine-replay-queue.vala:516: ReplayQueue.do_replay_local_async ReplayQueue:GearyImapEngineOtherFolder(>Archives, open_count=1, remote_opened=true) (notification=0 local=0 local_active=false remote=1 remote_active=false) exiting
[deb] 07:29:22.0860 geary:imap-engine-replay-queue.vala:516: ReplayQueue.do_replay_local_async ReplayQueue:GearyImapEngineOtherFolder(>INBOX>Archives, open_count=1, remote_opened=true) (notification=0 local=0 local_active=false remote=1 remote_active=false) exiting
[deb] 07:29:22.0893 geary:imap-engine-replay-queue.vala:631: ReplayQueue.do_replay_remote_async ReplayQueue:GearyImapEngineOtherFolder(>Archive
Second message :
Second message :
Back trace:
  • g_closure_invoke
  • g_signal_emit
  • g_closure_invoke
  • g_signal_emit
  • g_application_run
  • _vala_main
  • __libc_start_main
  • _start
Geary revision:
[deb] 07:29:22.0893 geary:imap-engine-replay-queue.vala:631: ReplayQueue.do_replay_remote_async ReplayQueue:GearyImapEngineOtherFolder(>Archives, open_count=1, remote_opened=true) (notification=0 local=0 local_active=false remote=0 remote_active=false) exiting
One thing I can say is that
is undoubtedly true. You would expect RCPT TO:<local-part@domain>
(where the “RCPT TO” is not case sensitive, so lower case is OK too). What has happened to the email address??
I assume that you are attempting to send to a valid address.
Where is the recipient address coming from? You are typing it in to Geary? You are getting it from your address book (contacts)?
You are sending mail from your address book (contacts)? You are sending mail directly from Geary?
Based on the above error message, it looks as if the “To” address (or another recipient address) has been messed up.
I get this message as soon as I open Geary, BEFORE I even start writing a message on any account.
By the way, only my two accounts at “GANDI.net” have this problem of sending messages.
I have tested all the others (I have four others): they work perfectly.
The problem does not seem to be related to the way the address is written because it happens in the same way whether I write it myself or whether it comes from the Contact Book.
Then it’s probably something stuck in your Outbox from an earlier problem. I suggest deleting the messages from Outbox.
Me too. I haven’t had a problem sending email from Geary.
It is possible that the server that you are using with the gandi.net account is advertising an option (a capability) that is confusing Geary or causing Geary to mishandle things.
Are you using the same outgoing mail (SMTP) server for all six accounts? Or are you using one SMTP server with the gandi.net accounts and a different SMTP server with the other four accounts?
I just found: I was using STARTTLS instead of SSL.
I corrected: everything works now.
On the other hand I still have a problem with the creation of my account on TDN-FAI.NET which is also my internet provider.
I tried to change the parameters one by one, but I can’t find it.
I will contact TDN.
In any case, thank you for your answers!
I’m starting to get the hang of my phone.
I still have to figure out :
  • how to properly format my additional memory card (which was previously on my Android-Lineage smartphone)
  • how to make a correct backup of the phone
  • how to delete in command line files unnecessarily copied because I didn’t see in Nautilus a way to do it in graphical mode and I’m very afraid to make big mistakes
  • how to install a Matrix client (Fractal or Elements) because there is none in the PureOS Store and I can’t do it with sudo apt in command line either.
    In short, something to keep me busy in this taming process.
Sincerely,
Patrick
Great!
Then I’m too late with this advice, but let me say it anyway in case it helps someone else: in situations like this we can make use of the “convergence” feature. Very likely you would have had the same problem running Geary on a desktop/laptop computer, especially since the problem you had was not at all related to screen size. So you could have used a desktop/laptop computer to troubleshoot the issue, running the same version of Geary.
Thank you very much !
I wouldn’t have thought of this trick.
Best regards,
Patrick
