GLES 3.0 for Librem 5
I just created this thread to track GLES3.0 development for Librem 5.
Christian Gmeiner
Hi @austriancoder any news for GLES3.0 for Free Software Etnaviv driver for Librem 5 GPU?
Thank you.
Hi @carlosgonz have you heard any more news about GLES3.0?
I don’t know where else to look for news than the blog you linked, which unfortunately has no recent updates.
I’m just excited about this and know it’s something you are paying close attention to.
This more recently…
Woohoo progress!
I feel like this isn’t getting the attention it deserves but it’s a really big deal for L5 and GNU/Linux mobile.
This would be absolutely stunning.
Currently Flutter apps on Librem 5 seem to be damned to use only software rendering, resulting in very improvable performance…
How do you check this and how install the app?
I observed that when running a self compiled Flutter app. Flutter does not fallback to software rendering by default and showed an error. There is an open issue here: Support software rendering fallback on Linux · Issue #151389 · flutter/flutter · GitHub
Another app example is FluffyChat, see: Installing / using fluffychat
Some suggested to use Flatseal for unchecking GPU acceleration. In my case I just added Flatpak support today and only tried to run the app manually. The workaround was like:
export LIBGL_ALWAYS_SOFTWARE=1
./myapp
I just install FluffyChat using FlatHub in my Byzantium backports environment (mesa 24.3.2) and can conclude that it works pretty well.
The side effect is I found dozens very nice apps written in flutter that I’d like to try :blush:
Thanks for your follow up @galilley
I should have mentioned that I’m on Mobian and perhaps assumed too early that it generally doesn’t work because of missing GLES 3.0 I didn’t dig deeper so far. Would you mind testing whether a binary compiled by me works for you flawlessly? :eyes:
If so, you could download the ARM build here: v0.13.0 - epinez/Energize - Codeberg.org
Looks like it works as expected…
Of course, gles3 is still not supported, but some of its critical parts are. So, Mesa version matter.
Thank you! :slightly_smiling_face: That’s really nice to hear. I’ll have a look at what’s the problem on Mobian
I can not find this commit to follow it…
Okay so here’s a quick follow up. tl;dr: export GDK_GL=gles needed.
Check mesa versions:
mobian@mobian:~/Downloads$ apt list --installed "mesa-*"
mesa-libgallium/testing,now 25.0.3-1 arm64 [installed,automatic]
mesa-va-drivers/testing,now 25.0.3-1 arm64 [installed,automatic]
mesa-vdpau-drivers/testing,now 25.0.3-1 arm64 [installed,automatic]
Try to run app directly:
mobian@mobian:~/Downloads$ ./energize/energize
(energize:2188): Gdk-CRITICAL **: 14:37:23.943: gdk_gl_context_make_current: assertion 'GDK_IS_GL_CONTEXT (context)' failed
** (energize:2188): WARNING **: 14:37:23.943: Failed to initialize GLArea: Unable to create a GL context
** (energize:2188): CRITICAL **: 14:37:23.970: FlutterEngineDisplayId fl_display_monitor_get_display_id(FlDisplayMonitor *, GdkMonitor *): assertion 'FL_IS_DISPLAY_MONITOR(self)' failed
Try to run fluffychat directly (build from Github):
mobian@mobian:~/Downloads$ ./fluffychat
(fluffychat:2754): Gdk-CRITICAL **: 14:53:15.412: gdk_gl_context_make_current: assertion 'GDK_IS_GL_CONTEXT (context)' failed
** (fluffychat:2754): WARNING **: 14:53:15.412: Failed to initialize GLArea: Unable to create a GL context
** (fluffychat:2754): WARNING **: 14:53:15.455: gtk.dart: failed to call method: No engine to send to
** (fluffychat:2754): WARNING **: 14:53:15.456: gtk.dart: failed to call method: No engine to send to
(fluffychat:2754): Gdk-CRITICAL **: 14:53:41.400: gdk_gl_context_make_current: assertion 'GDK_IS_GL_CONTEXT (context)' failed
** (fluffychat:2754): WARNING **: 14:53:41.400: Failed to uninitialize GLArea: Unable to create a GL context
embedder.cc (2429): 'FlutterEngineRemoveView' returned 'kInvalidArguments'. Engine handle was invalid.
(fluffychat:2754): GLib-GObject-CRITICAL **: 14:53:41.402: g_object_weak_unref: couldn't find weak ref 0xffffb3e89ba0(0xaaab184befc8)
Hmm, but why is the installed FluffyChat version via Flathub working?
mobian@mobian:~/Downloads$ grep Exec /var/lib/flatpak/exports/share/applications/im.fluffychat.Fluffychat.desktop
Exec=/usr/bin/flatpak run --branch=stable --arch=aarch64 --command=env --file-forwarding im.fluffychat.Fluffychat GDK_GL=gles fluffychat @@u %U @@
Ah, it’s setting the environment variable GDK_GL=gles…
Can also be found in their Flathub manifest.
Run app again with env:
mobian@mobian:~/Downloads$ env GDK_GL=gles bash -c ./energize/energize
Gdk-Message: 15:10:11.935: Unable to load  from the cursor theme
<GUI plopping up and working>
Working hardware acceleration included.
While GLES 3.0 will just add power save on active-mode and not in inactive-mode and suspend-mode. We already have big issues on power save on inactive-mode and suspend-mode i hope it is bugs on software and not on hardware, if it is hadware-bug we need Librem 5 Fir Release to tackle this powersave erratas.
Librem 5 Still Wonderfull!
I just curious if Gnu Emerald will be the first one with GLES3 native for L5. :anguished:
Amber
Byzantium
Crimson
Dawn
Emerald
@austriancoder is a Super HERO!
