Altor
December 19, 2022, 6:42pm
1
Hello,
I saw on the post about the Uperfect-x lapdock that there are some gsetting command to make phosh detect an external monitor as a touchscreen,
I just wanted to share my current findings with other folks who are looking for the ideal convergence set up for their Librem 5. I have long been a fan of tiny laptops and when I talk about convergence with the Librem 5 and Nexdock 360 for travel some folks come back with the observation that the Nexdock 360 is the same size as a laptop.
Without getting into the counterarguments there, and the benefits of traveling with an inexpensive lapdock instead of a full computer, I also realized it would…
I have a lenovo m14t which works well, but I can’t find the command.
Today, when I touch the lenovo screen, the scroll (for example) is activated on the librem5’ screen, not on the lenovo side.
lsusb -tv returns:
Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
|__ Port 1: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 2d1f:524c Wacom Taiwan Information Co. Ltd.
|__ Port 1: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 12M
I don’t know about the gsettings command, but I got touchscreen to work with Nexdock touchscreen using the phosh-mobile-settings app. Maybe it will work for your monitor too.
Altor
December 20, 2022, 6:37pm
3
The issue is that my “dock” is not configured in the phosh-mobile-settings.
I add the following line for my “dock” to src/ms-convergence-panel.c, compile it and running it following https://source.puri.sm/guido.gunther/phosh-mobile-settings but it is still not known.
* Manufacturer: LENOVO
* Model: m14T
.name = “Thinkvisiom M14T”,
.make = “LEN”,
.model = “M14T”,
.serial = “V307G6CZ”, / from Detailed timing descriptors in the edid
.touch_usb_vendor = 0x2d1f, /* from lsusb -vt
.touch_usb_id = 0x524c,
/*.touch_usb_vendor = 0x524c,
.touch_usb_id = 0x2d1f,*/
Altor
August 12, 2023, 4:30pm
4
Thanks to @guido.gunther help, I found the correct gsetting command. For other m14t user :
gsettings set org.gnome.desktop.peripherals.touchscreen:/org/gnome/desktop/peripherals/touchscreens/2d1f:524c/ output “[‘Lenovo Group Limited’,‘M14t’,‘V307G6CZ’]”
Thanks @Altor , I added it here .
Could you get me the full edid-decode output please so I can complete the information? The command is something like
edid-decode /sys/devices/platform/soc@0/32c00000.bus/32e00000.display-controller/drm/card2/card2-DP-1/edid
but you might needed to change the path to the edid blob. See src/ms-convergence-panel.c · main · Guido Günther / phosh-mobile-settings · GitLab on how to locate the edid blob.
Altor
March 2, 2024, 7:16am
6
here my edi-code. Sorry for the delay but i didn’t have access to the screen.
edid-decode (hex):
00 ff ff ff ff ff ff 00 30 ae a3 62 5a 43 36 47
13 1f 01 04 a5 1f 11 78 3e ee 95 a3 54 4c 99 26
0f 50 54 bd cf 80 a9 40 81 00 81 80 81 8c 95 00
95 0f a9 4a b3 00 02 3a 80 18 71 38 2d 40 58 2c
45 00 35 ae 10 00 00 1e 00 00 00 ff 00 56 33 30
37 47 36 43 5a 0a 20 20 20 20 00 00 00 fd 00 32
4b 1e 5a 15 00 0a 20 20 20 20 20 20 00 00 00 fc
00 4d 31 34 74 0a 20 20 20 20 20 20 20 20 01 57
02 03 1c b1 4d 01 02 03 11 12 13 04 0e 0f 1d 1e
1f 90 83 01 00 00 65 03 0c 00 10 00 01 1d 00 72
51 d0 1e 20 6e 28 55 00 35 ae 10 00 00 1e 8c 0a
d0 8a 20 e0 2d 10 10 3e 96 00 35 ae 10 00 00 18
0e 1f 00 80 51 00 1e 30 40 80 37 00 35 ae 10 00
00 1c 20 1c 56 86 50 00 20 30 0e 38 13 00 35 ae
10 00 00 1e 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17
Block 0, Base EDID:
EDID Structure Version & Revision: 1.4
Vendor & Product Identification:
Manufacturer: LEN
Model: 25251
Serial Number: 1194738522
Made in: week 19 of 2021
Basic Display Parameters & Features:
Digital display
Bits per primary color channel: 8
DisplayPort interface
Maximum image size: 31 cm x 17 cm
Gamma: 2.20
DPMS levels: Off
Supported color formats: RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
Default (sRGB) color space is primary color space
First detailed timing includes the native pixel format and preferred refresh rate
Color Characteristics:
Red : 0.6396, 0.3300
Green: 0.2998, 0.5996
Blue : 0.1503, 0.0595
White: 0.3134, 0.3291
Established Timings I & II:
IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz
DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
Apple : 640x480 66.667 Hz 4:3 35.000 kHz 30.240 MHz
DMT 0x05: 640x480 72.809 Hz 4:3 37.861 kHz 31.500 MHz
DMT 0x06: 640x480 75.000 Hz 4:3 37.500 kHz 31.500 MHz
DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz
DMT 0x0a: 800x600 72.188 Hz 4:3 48.077 kHz 50.000 MHz
DMT 0x0b: 800x600 75.000 Hz 4:3 46.875 kHz 49.500 MHz
DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz
DMT 0x11: 1024x768 70.069 Hz 4:3 56.476 kHz 75.000 MHz
DMT 0x12: 1024x768 75.029 Hz 4:3 60.023 kHz 78.750 MHz
DMT 0x24: 1280x1024 75.025 Hz 5:4 79.976 kHz 135.000 MHz
Apple : 1152x870 75.062 Hz 192:145 68.681 kHz 100.000 MHz
Standard Timings:
DMT 0x33: 1600x1200 60.000 Hz 4:3 75.000 kHz 162.000 MHz
DMT 0x1c: 1280x800 59.810 Hz 16:10 49.702 kHz 83.500 MHz
DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz
CVT : 1280x1024 71.932 Hz 5:4 76.968 kHz 133.000 MHz (EDID 1.4 source)
GTF : 1280x1024 72.000 Hz 5:4 76.824 kHz 132.752 MHz (EDID 1.3 source)
DMT 0x2f: 1440x900 59.887 Hz 16:10 55.935 kHz 106.500 MHz
DMT 0x30: 1440x900 74.984 Hz 16:10 70.635 kHz 136.750 MHz
DMT 0x35: 1600x1200 70.000 Hz 4:3 87.500 kHz 189.000 MHz
DMT 0x3a: 1680x1050 59.954 Hz 16:10 65.290 kHz 146.250 MHz
Detailed Timing Descriptors:
DTD 1: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (309 mm x 174 mm)
Hfront 88 Hsync 44 Hback 148 Hpol P
Vfront 4 Vsync 5 Vback 36 Vpol P
Display Product Serial Number: 'V307G6CZ'
Display Range Limits:
Monitor ranges (GTF): 50-75 Hz V, 30-90 kHz H, max dotclock 210 MHz
Display Product Name: 'M14t'
Extension blocks: 1
Checksum: 0x57
Block 1, CTA-861 Extension Block:
Revision: 3
Underscans IT Video Formats by default
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 1
Video Data Block:
VIC 1: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
VIC 2: 720x480 59.940 Hz 4:3 31.469 kHz 27.000 MHz
VIC 3: 720x480 59.940 Hz 16:9 31.469 kHz 27.000 MHz
VIC 17: 720x576 50.000 Hz 4:3 31.250 kHz 27.000 MHz
VIC 18: 720x576 50.000 Hz 16:9 31.250 kHz 27.000 MHz
VIC 19: 1280x720 50.000 Hz 16:9 37.500 kHz 74.250 MHz
VIC 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz
VIC 14: 1440x480 59.940 Hz 4:3 31.469 kHz 54.000 MHz
VIC 15: 1440x480 59.940 Hz 16:9 31.469 kHz 54.000 MHz
VIC 29: 1440x576 50.000 Hz 4:3 31.250 kHz 54.000 MHz
VIC 30: 1440x576 50.000 Hz 16:9 31.250 kHz 54.000 MHz
VIC 31: 1920x1080 50.000 Hz 16:9 56.250 kHz 148.500 MHz
VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (native)
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 1.0.0.0
DTD 2: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz (309 mm x 174 mm)
Hfront 110 Hsync 40 Hback 220 Hpol P
Vfront 5 Vsync 5 Vback 20 Vpol P
DTD 3: 720x480 59.940 Hz 3:2 31.469 kHz 27.000 MHz (309 mm x 174 mm)
Hfront 16 Hsync 62 Hback 60 Hpol N
Vfront 9 Vsync 6 Vback 30 Vpol N
DTD 4: 1280x768 59.870 Hz 5:3 47.776 kHz 79.500 MHz (309 mm x 174 mm)
Hfront 64 Hsync 128 Hback 192 Hpol N
Vfront 3 Vsync 7 Vback 20 Vpol P
DTD 5: 1366x768 60.000 Hz 683:384 48.000 kHz 72.000 MHz (309 mm x 174 mm)
Hfront 14 Hsync 56 Hback 64 Hpol P
Vfront 1 Vsync 3 Vback 28 Vpol P
Checksum: 0x17
