My HDMI port suddenly stopped working a few days ago. I’ve had my Librem 15 for about 3 months, my second monitor worked fine out of the box until recently.
Fn+F7 and Settings>Devices.Displays show nothing.
I have tried two different monitors and two different HDMI cables, all function with other computers. I have also updated to the latest OS and restarted.
Any solutions?
I’m having the same problem on my Librem 13v4. HDMI was working fine until I restarted my computer today, when it suddenly stopped working.
Here’s what I’ve tried:
- Attempted connecting to two different monitors and two different cables
- Tried on firmware versions 4.11 and 4.9-Purism-2
- Tried using my normal OS (Nixos with X11) and the PureOS live installation USB
It seems like my computer is still aware that the HDMI connection exists, but doesn’t see it as connected. Output of xrandr is as follows:
~ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 290mm x 170mm
1920x1080 59.98*+ 59.93 48.01
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 60.00 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 60.00 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
640x360 59.84 59.32 60.00
HDMI1 disconnected primary (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
It’s working again now.
For future reference in case anyone else encounters this problem, here’s what I did:
- Unplugged all USB devices, the HDMI cable, and the power cable
- Turned off the computer
- Turned the computer back on
- Plugged back in the HDMI cable
My guess is that it was the powering off of the computer (and then powering it back on) that did the trick. When changing the OS and firmware versions, I was rebooting the computer instead.
Thank you! I was having this issue on my Librem 15 v3, though for me xrandr
didn’t mention HDMI at all. Those steps worked for me as well.
