Hello, pureos users! Pls, help me. I have installed pureos for my sister on Dell Latitude 7420, but, I have problem with wifi. There no WiFi adapter found. What I need to do? Maybe install some drivers, or what?
Acquire a device that does not require proprietary drivers for Wi-Fi/Bluetooth functionality in PureOS.
Yes, unfortunately I really can’t recommend PureOS for computers that haven’t been specifically made with open source software in mind. I would honestly recommend using Ubuntu or Fedora on most hardware.
If you really want to stick with PureOS, this thread may have some helpful information:
This is likely to be troublesome but if you want to persevere then the next step would be … find out exactly what make and model of WiFi card is present in the laptop.
Does that laptop have working ethernet?
No it does not:
Thank you so much!
No, he doesn’t
