Hello,
my Librem 15v4 with PureBoot + LibremKey and encryption disk with Swap Encryption too won’t start after update!
So i made a fresh clean install, LibremKey and encryption drive works well.
BUT: If if type in the terminal:
sudo apt update && sudo apt full-upgrade
After the update you can read this:
update-initramfs: Generating /boot/initrd.img-4.19 0-5-amd64
cryptsetup: WARNING: Resume target luks-d34…
uses a key file
After reboot after disk encryption password the system can’t encrypt the drive → Only a black terminal with the text
busybox …
initramfs
How i can update my system so that it boot after updates?
→ Workaround for now:
Create the portions manuel with new install:
1150MiB = 1.1GB boot /boot ext4
Rest of for your system / root ext4 with luks disk encryption set password
8.8GiB swaplinux
Problem: Only your OS and Data are with luks encrypted, not the swap
Thanx!
Important Links:
PS: If you want a honest review about the librem 15v4:
