High CPU usage with Lenovo USB C charger
Hello everyone,
I am just joining the show, slowly migrating everything from my de-Googled Cosmo Communicator to the Librem 5.
I found out that sometimes my phone would get very hot when charging. Investigating the issue, I found out that the issue only happened with the Lenovo USB C charger that I have at home (model 01FR28 65W).
Digging a bit deeper, I found out that this charger gets the Librem 5 using 100% CPU, and this is why actually the phone gets hot. If I use my desktop USB C port or the provided charger, it’s all good.
The affected process is upowerd and it also causes a lot of activity on systemd-udevd. Has anyone faced this issue? Is this the same problem described here: Overheating the Librem 5 with USB-PD. Should I always use the charger in the box? ?
Thank you!
Your charger is giving the phone too much power it’s 65w…it’s a super fast charger. I don’t think the L5 battery I capable of that. If you continue. You will explode your battery or the phone
Why do I get high CPU usage in these processes using the Lenovo charger and not with the standard charger?
In any case, I’ve stopped using the charger… I was just trying to find out the root cause of the problem. The phone SEEMS to be charging at the correct speed - I will add a kill-a-watt to the wall at some point to confirm.
Never mind. You can charge your phone with a 65w charge… what you described os interesting indeed :thinking:
All right, I did some investigation and I am tempted to blame the charger (as my Cosmo Communicator also gets way warmer charging with the Lenovo charger compared to the Purism charger).
Here is the loop that I found in the logs when I connect charger (journalctl):
  • bq25890-charger Upstream supply changed: 1, then disabling OTG_EN pin.
  • New usb device found, idvendor=1d6b, idproduct 002, etc
  • kernel: xhcd-hcd new USB bus registered
  • USB hub, one port detected
  • We don know the algorithms for LPM for this host
  • bq25890-charger: upstream supply changed, disabling OTG_EN pin.
Loop forever. I got hundreds of MB of logs in a few minutes. So this explains the CPU usage and the heat.
Is that normal for a charger?
Without knowing much of that: I guess yes because the phone and the charger could negotiate current and voltage via data line.
It’s not actually a new USB device, but rather the controller repeatedly switching between host and device mode for some reason. Perhaps the charger does not handle data role signalling correctly.
Yup, no problem here.
I got access to an Apple USB-C charger from a MacBook Pro and my Librem 5 charged without issues, no crazy loop in upowerd.
Now the information is registered and if anyone else has this problem, the reference is here.
Thank you, everyone.
I confirm. The same problem happened for me with another Lenovo charger, model ADLX65YLC3D.
Feb 28 07:34:24 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 1.
Feb 28 07:34:24 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
Operating systems are funny.
Here is some off-topic: Now I can’t find all the wifi AP’s with my Win10 laptop, after I cleaned it with Privatezilla. But Wifi works with both 2.4GHz and 5GHz AP’s. It is just some random AP’s (about 70% of them) that are not getting listed. I guess I need to install Debian for this laptop too.
I tried another Lenovo charger recently and it also failed the same way.
