It's a burning phone
I checked the thermals this morning. Weather is pleasant and cool at the coast. (Mi dispiace, @fiacco!)
BEFORE CHARGING (phone idle, not plugged in):
vpu-thermal 35.00° C
gpu-thermal 35.00° C
cpu-thermal 35.00° C
max170xx_battery 31.40° C
bq25890-charger 27.50° C
AFTER CHARGING COMPLETED:
vpu-thermal 42.00° C
gpu-thermal 42.00° C
cpu-thermal 41.00° C
max170xx_battery 41.40° C
bq25890-charger 35.00° C
However, I had a look at the thermals day before yesterday when the phone was not doing much and was not charging, and I saw a reading of 85.00° C for the charger (all else normal). The ambient temperature was not hot at all, so either that reading was kept in memory from the last charge event, or it’s just some kind of bug in the sensor.
Next time I charge I’ll check the surface temperature of the charger and charging port with a laser thermometer and let you guys know the reading.
No, typically in top pocket, sometimes in coat pocket.
Anyway I will keep an eye out for the rogue 85C. Sounds like it’s just an error.
I also think that there is a bug on the temperature indication.
Yesterday I was running Stellarium (which worked for the 1st time, by the way) and I saw the red led blinking.
One of the temperatures was displayed at 42 degrees. A few minutes later the led went off and the temperature was 85 degrees!
A little later, the same temperature was displayed again at 42 degrees.
Could you please PM to me as well? :smiley: Because the temperatures in Athens are at the 40ies and the phone is cooking even on standby with no app running and the screen locked and off.
Now, this was with a spare battery (not the one included in the phone). Unfortunately I made this trip to Athens with the spare battery only. Now I returned to my island and the temperatures are milder (around 30 C).
While in Athens the phone would overheat easily especially when charging it and the charging led was blinking in a random and not normal way. So I was forced to shut it down to avoid damage. After a while I found a temporary solution… I charged it laying it flat on the house heat radiators (which although not in use are filled with water) so I was able to safely charge it this way.
But even while not charging and not using it overheats when the ambient temperature is around 40ies (Celsius). I think that suspend must be implemented soon. Because you can charge it on a radiator but we need to use the phone, and can not carry the heat radiator with us. :sweat_smile:
By the way…, I have heard nothing about suspend all these months. Like it is out of discussion…
This morning, with the phone on, and lying idle on the table for an hour or so, my readings show:
bq25890-charger 85.00° C
vpu-thermal 38.00° C
gpu-thermal 38.00° C
cpu-thermal 38.00° C
max170xx_battery 35.10° C
Room temperature is cool. I haven’t charged since yesterday.
Result with laser thermometer after 100% charge (same electrical outlet I always use):
Surface of Wall charger 28.00° C
Charging port 28.00° C
Usage/Thermal readings:
vpu-thermal 41.00° C
gpu-thermal 41.00° C
max170xx_battery 38.30° C
bq25890-charger 34.00° C
And cooling down gradually.
I really think that 85.00° C reading in the display must be some kind of reporting bug.
I’m curious about this too, will link to a new thread to see if anyone has any thoughts or updates
FWIW, I have just let the phone charge from 0% to 40% at full speed (~1.6A) and the battery temperature got to 36.5°C, with ambient at around 26°C. The more charged the battery is the lower the charging current gets (it approaches an asymptote), so it usually would get cooler in later stages of charging.
After reading this topic, the 85°C thing definitely looks like a reporting issue and not an actual temperature. I haven’t seen it myself so far on any of my devices, I’ll try to keep my eye on it.
For the reference, max170xx_battery and bq25890-charger entries are somewhat confusingly named, so in case anyone wonders: bq25890-charger value is taken from the thermistor that’s inside the battery, while max170xx_battery is the internal temperature of the battery gauge chip which is on the phone’s PCB (and therefore gets warm from the SoC’s heat much easier and is actually much more related to that than to battery’s temperature).
Lol! I did wonder how the charger’s temperature could be read by the phone. But it is a superphone, after all. :stuck_out_tongue:
“Charger” is a bit overloaded term - the phone contains a charging chip (bq25895) which is the part that’s actually connected to the battery’s thermistor (which is why it’s bq25890 driver that exports this value). From the phone’s perspective, what you call “charger” is actually a “power supply” :slight_smile:
What about the aluminum case? The hottest area is the top half on either side. It would be great to have a measure during the charging process and after having played with some heavy software for a while. Of course I owe you one more beer :smiley:
I’ll measure that for you today when I charge again. (Could you make it a bottle of Nero d’Avola instead? :yum:)
Edit: spelling
Ah! This topic is getting expensive!
With wifi and mobile settings on, I started charging at 40% with the phone placed on a mostly non-heat-conductive surface (so as to avoid heating or cooling the phone’s exterior).
Thermals at beginning of charging time:
Two hours later (approximately 80% charge):
At 90% charge, I initiated the following:
.short 4-second .mp4 on repeat, display constant/on
.Firefox open in background
.streaming music on continuous play
.a few terminal commands and install
.software store check for updates
A short time later, at 95% charge, the red LED started blinking, so I unplugged and took the following readings (left/right = as facing screen):
Screen, center: 43.9° C
Left edge, lower: 26.4° C
Left edge, upper: 28.3° C
Top edge: 27.0° C
Right edge, upper: 27.4° C
Right edge, lower: 28.4° C
Bottom edge: 26.3° C
Back cover, center: 40.2° C
Battery surface, back removed: 39.7° C
Modem cover: 40.7° C
Wifi/BT card cover: 42.0° C
Thermals:
Powered off, then 17 minutes later:
Great job!
Funny, I bet that the sides were warmer.
Maybe so. The frame is, after all, essentially a heat sink.
It was definitely starting to overheat with all those processes running while also charging.
For what it’s worth, the blinking red LED while charging means that the charging controller did its job and paused charging due to high battery temperature (I don’t remember the exact threshold but IIRC it was slightly above 40°C). There’s no need to unplug it in such condition since the charging is already stopped and the phone stays powered from USB, so the battery stays mostly unused (at least unless there’s a power peak that can’t be handled by USB alone). After unplugging you start to draw power from the battery back.
The CPU is set to start thermal throttling at 50°C - first by limiting the frequency to 1.0GHz, and then starting at 60°C by idle injection. Additionally, the GPU gets throttled at 65°C as well. The critical temperature at which the SoC is forcibly shut down is 90°C (I have hit that in the past on devkit and some early batches when compiling some big stuff, but so far never on Dogwood or Evergreen). These values are set in the device tree: https://source.puri.sm/Librem5/linux-next/-/blob/pureos/byzantium/arch/arm64/boot/dts/freescale/imx8mq.dtsi#L246
Since the CPU throttling temperature is higher than maximum charging temperature, it’s perfectly normal for blinking LED to happen when the SoC is under prolonged load - inevitably some of that heat will start to reach the battery at some point (and charging will make it heat up on its own as well, so it will happen faster while charging). Usually it’s enough to just stop the CPU activity and lock the screen for it to resume charging after a short moment - of course that depends on external conditions since the heat has to escape somewhere, so don’t wrap you phone with warm blankets in such condition :wink:
Thanks for the explanation, @dos …good stuff. I usually try to stop charging at around 80-85%, when I catch it in time, just to hopefully extend the battery’s useful lifetime. Then again, I’m not relying on the L5 to get me through the day, like some here are.
What we need is a nitrogen-cooled phone case for the L5. :slightly_smiling_face:
It would be good if that info could find its way into: https://docs.puri.sm/Librem_5/Troubleshooting/LEDs.html
(I would do it but I think that area is not community-editable.)
So right now “flashing red” means “Contact Purism” whereas at least a customer could go into Usage / Thermals and decide whether the likely cause is over-temperature, or instead it is really something that the customer can’t do anything further with without contacting Purism.
You’re right, that part of the docs needs to be clarified.
FYI, these docs live in Librem5 / librem5-user-docs-common · GitLab where issues and merge requests can be created.
