L11 Arrived Today! First Impressions & a potential QC issue
At long last (not nearly as long as others), my Librem 11 arrived today after only 3 months. So far I am extremely happy with the device and performance, with one major exception.
I can’t get any sound output to work without connecting a USB-C device with HDMI output. No sound comes out of any internal speakers, nor do headphones work when connected. Sound appears to be playing based on the “vu meter” in Sound Settings, but nothing is heard.
dmesg does not reveal any errors at boot, and I am continuing to investigate and put in a proper support ticket if it comes to it.
Other than that, again, I am very pleased.
Oh, and there was an extra, tiny screw attached to the body of the tablet when I unboxed it, perhaps a stowaway from the factory. :slight_smile:
I will see if I can figure out this sound problem, hopefully without having to rebuild the OS.
More to come…
I would recommend contacting Purism Support. support@puri.sm This is a brand new device with operating system pre-installed and I imagine you didn’t have a chance to mess with much before noticing this issue.
As a sanity check, you could try a PureOS USB live boot, just to confirm that the problem occurs with an unmodified system.
You might also try a USB audio dongle (with headphones, or with powered speakers) if you have such a dongle.
I’m thinking the same Wade. And no, i’m at like minute 56 with the device, so no major tinkering beyond doing just what you said.
If I connect a USB-C dongle to the tablet, and toggle HDMI output in Sound settings, the output works flawlessly, even while simultaneously streaming YT to a second 34" display through the same USB-C.
My suspicion, as a crusty PC repair man, is that someone forgot to seat a ribbon cable or similar, however to your point, I am not busting out the iFixit kit unless instructed. There’s too much money invested at my fingertips to void anything remotely close to a warranty.
I’m still poking around to be sure its not something stupid (its always something stupid).
(I already double checked the mute button)
Yes, I assumed that you already checked the obvious things like muted in the various places that it might be muted.
I agree that you should not open it up to check cable connections etc., particularly as it is not easy to open up.
Just as a further rando suggestion … does the problem go away if you create a new user, log in as that new user and then try internal sound output again?
Actually, I hadn’t thought of that, HOWEVER, I was already doing all of this troubleshooting under a new account (with admin privs) I had created. I have also already removed admin privs from the default purism account.
Its like i’m paranoid or something…
I did just try to log back in as that user to see if audio works and it did not.
In the meantime, I have also put in a support ticket as well.
Hmmm. OK. That’s a busy 56 minutes. :slight_smile: In that case, I would definitely say: Live Boot (for fault isolation)
Linux is not totally consistent as to what “permissions” might be relevant for sound output.
Another idea is to turn off and on the Librem 11 to see if anything changes.
I’ll add my experience as well: I also received my Librem 11 today and also do not hear any sound played from the internal speakers and headphone jack. I’ve sent an email to Purism support for now. I’m using kernel version 6.1.0-15.
Edit: When I plug in headphones, I don’t see it recognized in the system settings to switch output devices, unlike a different device like the Librem 5 and Librem 14.
It makes me feel better that its not me.
In other news, update: Live Gnome USB made no difference. Downloaded the latest PureOS iso fresh and booted to the desktop without issue, same test, same outcome. Going to try Live KDE Plasma USB to see if its a Gnome being Gnome thing.
I don’t have an L14 on hand, but I appreciate the idea. :wink:
I did however shut the L11 all the way down and boot it back up more than once, same outcome.
I found my old USB C to 3.5mm headphone adapter and audio over USB works. I don’t have Bluetooth headphones so I can’t test this method.
Attempting to boot to the KDE Plasma ISO from PureOS site, I see this on boot, currently stuck at this screen for ~5min. I’m letting it sit in case magic happens…
That appeared to be a ghost, however some Internet sleuthing has me believing this to be a kernel or maybe module init issue. After installing alsa-utils I ran alsa-info and get the following output:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.1
!!Script ran on: Wed Jan 31 03:14:28 UTC 2024
!!Linux Distribution
!!DMI Information
Manufacturer:      Purism
Product Name:      librem_11
Product Version:   1.0
Firmware Version:  PureBoot-Release-28.1
System SKU:
Board Vendor:      Purism
Board Name:        librem_11
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 	 15
/sys/bus/acpi/devices/BOOT0000:00/status 	 15
/sys/bus/acpi/devices/GXTP7380:00/status 	 15
/sys/bus/acpi/devices/INT33D6:00/status 	 15
/sys/bus/acpi/devices/INT34C8:00/status 	 15
/sys/bus/acpi/devices/MXC6655:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0303:00/status 	 15
/sys/bus/acpi/devices/PNP0C09:00/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/device:34/status 	 15
!!Kernel Information
Kernel release:    6.1.0-15-amd64
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k6.1.0-15-amd64
Library version:
Utilities version:  1.2.8
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - Yes
No sound servers found.
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xbddd8000 irq 141
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Jasper Lake HD Audio [8086:4dc8] (rev 01)
	DeviceName: Multimedia audio controller
!!Modprobe options (Sound related)
snd_pcsp: index=-2
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	ctl_dev_id : N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 1
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
	|-- controlC0
	|   |-- dev
	|   |-- device -> ../../card0
	|   |-- power
	|   |-- subsystem -> ../../../../../../class/sound
	|   `-- uevent
	|-- device -> ../../../0000:00:1f.3
	|-- hwC0D0
	|   |-- afg
	|   |-- chip_name
	|   |-- clear
	|   |-- dev
	|   |-- driver_pin_configs
	|   |-- hints
	|   |-- init_pin_configs
	|   |-- init_verbs
	|   |-- mfg
	|   |-- modelname
	|   |-- power
	|   |-- power_off_acct
	|   |-- power_on_acct
	|   |-- reconfig
	|   |-- revision_id
	|   |-- subsystem_id
	|   |-- uevent
	|   |-- user_pin_configs
	|   |-- vendor_id
	|   `-- vendor_name
	|-- hwC0D2
	|   |-- afg
	|   |-- chip_name
	|   |-- clear
	|   |-- dev
	|   |-- hints
	|   |-- init_pin_configs
	|   |-- init_verbs
	|   |-- mfg
	|   |-- modelname
	|   |-- power
	|   |-- power_off_acct
	|   |-- power_on_acct
	|   |-- reconfig
	|   |-- revision_id
	|   |-- subsystem_id
	|   |-- uevent
	|   |-- user_pin_configs
	|   |-- vendor_id
	|   `-- vendor_name
	|-- id
	|-- input19
	|   |-- capabilities
	|   |-- event15
	|   |-- id
	|   |-- inhibited
	|   |-- modalias
	|   |-- name
	|   |-- phys
	|   |-- power
	|   |-- properties
	|   |-- subsystem -> ../../../../../../class/input
	|   |-- uevent
	|   `-- uniq
	|-- input20
	|   |-- capabilities
	|   |-- event16
	|   |-- id
	|   |-- inhibited
	|   |-- modalias
	|   |-- name
	|   |-- phys
	|   |-- power
	|   |-- properties
	|   |-- uevent
	|   `-- uniq
	|-- input21
	|   |-- capabilities
	|   |-- event17
	|   |-- id
	|   |-- inhibited
	|   |-- modalias
	|   |-- name
	|   |-- phys
	|   |-- power
	|   |-- properties
	|   |-- uevent
	|   `-- uniq
	|-- input22
	|   |-- capabilities
	|   |-- event18
	|   |-- id
	|   |-- inhibited
	|   |-- modalias
	|   |-- name
	|   |-- phys
	|   |-- power
	|   |-- properties
	|   |-- uevent
	|   `-- uniq
	|-- input23
	|   |-- capabilities
	|   |-- event19
	|   |-- id
	|   |-- inhibited
	|   |-- modalias
	|   |-- name
	|   |-- phys
	|   |-- power
	|   |-- properties
	|   |-- uevent
	|   `-- uniq
	|-- input24
	|   |-- capabilities
	|   |-- event20
	|   |-- id
	|   |-- inhibited
	|   |-- modalias
	|   |-- name
	|   |-- phys
	|   |-- power
	|   |-- properties
	|   |-- uevent
	|   `-- uniq
	|-- number
	|-- pcmC0D0c
	|   |-- dev
	|   |-- pcm_class
	|   |-- power
	|   `-- uevent
	|-- pcmC0D0p
	|   |-- dev
	|   |-- pcm_class
	|   |-- power
	|   `-- uevent
	|-- pcmC0D3p
	|   |-- dev
	|   |-- pcm_class
	|   |-- power
	|   `-- uevent
	|-- pcmC0D7p
	|   |-- dev
	|   |-- pcm_class
	|   |-- power
	|   `-- uevent
	|-- pcmC0D8p
	|   |-- dev
	|   |-- pcm_class
	|   |-- power
	|   `-- uevent
	|-- pcmC0D9p
	|   |-- dev
	|   |-- pcm_class
	|   |-- power
	|   `-- uevent
	|-- power
	|   |-- async
	|   |-- autosuspend_delay_ms
	|   |-- control
	|   |-- runtime_active_kids
	|   |-- runtime_active_time
	|   |-- runtime_enabled
	|   |-- runtime_status
	|   |-- runtime_suspended_time
	|   `-- runtime_usage
	|-- subsystem -> ../../../../../class/sound
	`-- uevent
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC269VC
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0269
Subsystem Id: 0x10ec0269
Revision Id: 0x100203
No Modem Function Group found
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Master Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC269VC Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
  Amp-Out vals:  [0x57 0x57]
  Converter: stream=1, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Converter: stream=0, channel=0
  PCM:
    formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
  Amp-In vals:  [0x97 0x97]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Mic Playback Volume", index=0, device=0
  Control: name="Mic Playback Switch", index=0, device=0
  Control: name="Beep Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=4, ofs=0
  Control: name="Beep Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 5
     0x18 0x19 0x1a 0x1b 0x1d
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Audio Mixer] wcaps 0x20010a: Mono Amp-In
  Amp-In vals:  [0x00] [0x80]
  Connection: 2
     0x02 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Control: name="Internal Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00000020: IN
  Pin Default 0x90a60130: [Fixed] Mic at Int N/A
    Conn = Digital, Color = Unknown
    DefAssociation = 0x3, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Master Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x00010014: OUT EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x90170110: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 2
     0x0c* 0x0d
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x0001001c: OUT HP EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Connection: 2
     0x0c* 0x0d
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40050c: Mono Amp-Out
  Amp-Out vals:  [0x80]
  Pincap 0x00000010: OUT
  Pin Default 0x40000000: [N/A] Line Out at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x00:
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Mic Boost Volume", index=0, device=0
  Pincap 0x00003734: IN OUT Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x04a11020: [Jack] Mic at Ext Right
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=01, enabled=1
  Connection: 2
     0x0c* 0x0d
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN VREF_HIZ
  Connection: 2
     0x0c* 0x0d
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pincap 0x0000373c: IN OUT HP Detect
    Misc = NO_PRESENCE
  Connection: 2
     0x0c* 0x0d
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
    Misc = NO_PRESENCE
  Connection: 2
     0x0c* 0x0d
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x40e38105: [N/A] Reserved at Ext N/A
    Conn = ATAPI, Color = Purple
    DefAssociation = 0x0, Sequence = 0x5
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000014: OUT Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=37
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00]
  Connection: 7
     0x18 0x19 0x1a 0x1b 0x1d 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 6
Codec: Intel Jasperlake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086281a
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled KAE
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0x1a]: 16 24 32
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pincap 0x0b000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 10 Jan 30 21:50 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  8 Jan 30 21:50 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116,  9 Jan 30 21:50 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116,  3 Jan 30 22:06 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  2 Jan 30 22:06 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  4 Jan 30 21:52 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116,  5 Jan 30 21:52 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116,  6 Jan 30 21:52 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116,  7 Jan 30 21:52 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116,  1 Jan 30 21:50 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Jan 30 21:50 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Jan 30 21:50 .
drwxr-xr-x 3 root root 280 Jan 30 21:50 ..
lrwxrwxrwx 1 root root  12 Jan 30 21:50 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VC Analog [ALC269VC Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 0/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xbddd8000 irq 141'
  Mixer name	: 'Realtek ALC269VC'
  Components	: 'HDA:10ec0269,10ec0269,00100203 HDA:8086281a,80860101,00100000'
  Controls      : 45
  Simple ctrls  : 12
Simple mixer control 'Master',0
  Capabilities: pvolume pswitch
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 87
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Capture channels: Front Left - Front Right
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Mono:
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 0 [0%] [-17.25dB] [off]
  Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface MIXER
		name 'Master Playback Volume'
		value.0 87
		value.1 87
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Master Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.4 {
		iface MIXER
		name 'Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.5 {
		iface MIXER
		name 'Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.6 {
		iface MIXER
		name 'Capture Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 63'
			dbmin -1725
			dbmax 3000
			dbvalue.0 -1725
			dbvalue.1 -1725
	control.7 {
		iface MIXER
		name 'Capture Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.8 {
		iface MIXER
		name 'Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.9 {
		iface MIXER
		name 'Internal Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.10 {
		iface MIXER
		name 'Beep Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.11 {
		iface MIXER
		name 'Beep Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.12 {
		iface CARD
		name 'Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.13 {
		iface CARD
		name 'Internal Mic Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface CARD
		name 'Speaker Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.15 {
		iface PCM
		name 'Playback Channel Map'
		value.0 3
		value.1 4
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.16 {
		iface PCM
		name 'Capture Channel Map'
		value.0 3
		value.1 4
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.17 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.18 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.19 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.20 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.21 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.22 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.23 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.24 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.25 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.26 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.28 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.29 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.30 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.31 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.32 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.34 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.35 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.36 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.37 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.38 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.39 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.40 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.41 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.42 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.43 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.44 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.45 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac
aesni_intel
af_alg
algif_hash
algif_skcipher
ansi_cprng
autofs4
battery
binfmt_misc
bluetooth
bnep
btbcm
btintel
btmtk
btrfs
btrtl
btusb
button
ccm
cec
cfg80211
cmac
configfs
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crc64
crc64_rocksoft
crc64_rocksoft_generic
crc_t10dif
crct10dif_common
crct10dif_generic
crct10dif_pclmul
cryptd
crypto_simd
ctr
dm_crypt
dm_mod
drbg
drm
drm_buddy
drm_display_helper
drm_kms_helper
ecc
ecdh_generic
efi_pstore
evdev
ext4
fuse
ghash_clmulni_intel
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_hid_acpi
i915
idma64
industrialio
industrialio_triggered_buffer
int340x_thermal_zone
intel_cstate
intel_lpss
intel_lpss_pci
intel_pmc_core
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_vbtn
ip_set
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
jitterentropy_rng
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
loop
mac80211
mbcache
mc
mxc4005
nf_conntrack
nf_defrag_ipv4
nf_defrag_ipv6
nf_nat
nf_reject_ipv4
nf_reject_ipv6
nf_tables
nfnetlink
nft_chain_nat
nft_compat
nft_ct
nft_fib
nft_fib_inet
nft_fib_ipv4
nft_fib_ipv6
nft_reject
nft_reject_inet
nvme
nvme_core
pcspkr
pinctrl_jasperlake
processor_thermal_device
processor_thermal_device_pci_legacy
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
raid6_pq
rc_core
rfcomm
rfkill
scsi_common
scsi_mod
sd_mod
serio_raw
sg
sha1_ssse3
sha256_ssse3
sha512_generic
sha512_ssse3
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_icl
snd_sof_utils
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
t10_pi
ttm
tun
uas
usb_common
usb_storage
usbcore
usbhid
uvcvideo
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
xor
xt_MASQUERADE
xt_mark
xt_tcpudp
zram
zsmalloc
zstd_compress
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x90a60130
0x14 0x90170110
0x15 0x411111f0
0x17 0x40000000
0x18 0x04a11020
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40e38105
0x1e 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[   20.982967] intel_rapl_common: Found RAPL domain psys
[   20.998822] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[   20.998857] snd_hda_intel 0000:00:1f.3: NHLT table not found
[   20.999099] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   21.000254] gsmi: no gsmi handler in firmware
[   21.078253] thermal thermal_zone1: failed to read out thermal zone (-61)
[   21.101142] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   21.101151] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   21.101153] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   21.101156] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   21.101157] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   21.101158] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[   21.101160] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   21.113828] Bluetooth: Core ver 2.22
[   21.113874] Bluetooth: SCO socket layer initialized
[   21.147747] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[   21.147797] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[   21.147837] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[   21.147872] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[   21.147907] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[   21.147943] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[   21.235456] iwlwifi 0000:00:14.3: base HW address: c4:23:60:68:1e:3d
!!Packages installed
ii  alsa-topology-conf                    1.2.5.1-2                            all          ALSA topology configuration files
ii  alsa-ucm-conf                         1.2.8-1                              all          ALSA Use Case Manager configuration files
ii  alsa-utils                            1.2.8-1                              amd64        Utilities for configuring and using ALSA
When did you place the order?
If you do the math, I bet you or even ChatGPT could figure that out!
January 31 minus 3 months = ~October 31st
More specifically, it was November 5th. So yeah, splitting hairs, 2 months and 3 weeks, give or take a couple days or so.
That’s what I wanted to know — specifically.
Because I placed my order on the 30th of October. Still awaiting shipping :frowning_face:.
If you haven’t already, I would recommend an email to support@ , I’ve had a running thread with Mladen since the original “3 week” lead time for shipping when I bought it. Perhaps in this case the squeeky wheel did get the grease!
More sleuthing today: [Solved] Audio card driver problems Debian 11 (Creative Sound Blaster Recon3Di). - Debian User Forums
“journalctl | grep audio” output:
Jan 31 09:52:12 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
Jan 31 09:52:12 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jan 31 09:52:12 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jan 31 09:52:12 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
Jan 31 09:52:12 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: inputs:
Jan 31 09:52:12 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
Jan 31 09:52:12 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
Jan 31 09:52:12 cw11 bluetoothd[719]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Jan 31 09:52:12 cw11 bluetoothd[719]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Jan 31 09:52:12 cw11 bluetoothd[719]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Jan 31 09:53:08 cw11 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Jan 31 09:53:09 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
Jan 31 09:53:09 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jan 31 09:53:09 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jan 31 09:53:09 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
Jan 31 09:53:09 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: inputs:
Jan 31 09:53:09 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
Jan 31 09:53:09 cw11 kernel: snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
Jan 31 09:53:09 cw11 bluetoothd[731]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Jan 31 09:53:09 cw11 bluetoothd[731]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Jan 31 09:53:09 cw11 bluetoothd[731]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Jan 31 09:53:27 cw11 callaudiod[1664]: Card ‘alsa_card.pci-0000_00_1f.3’ lacks speaker and/or earpiece port, skipping…
Jan 31 09:53:27 cw11 callaudiod[1664]: No suitable card found, stopping here…
Forwarding the following comment here, in case it is helpful:
I would recommend checking all settings and routings using “pavucontrol”. Sometimes output is hard routed to a single output if e.g. all other “defaults” are disabled.
Thanks, but that’s a pulseaudio specific utility, no? Does that still work with Pipewire?
Edit: Installed and no difference. “Speakers” is the only visible output/playback option, and although the device appears to think it is producing sound based on the “vu meter” in pavucontrol, no sound is heard either through the internal speakers or through the 3.5mm jack.
