L5 and PureOS Store
I finally received my L5 about a month ago and am relearning how Linux works. I have two questions:
I haven’t been able to install any additional apps or, do any updates as the PureOS Store is missing.
I’m not even sure if it was there when I first turned the phone on. I’ve tried the following, done of which worked:
sudo apt update sudo apt upgrade
sudo apt full-upgrade`
sudo apt install pureos-desktop
restarted the computer/phone after each command.
Do I need a super secret decoder ring first?
How do I stop the USBGuard Authenication promt from appearing every time I wake the phone up or turn it on?
Thank you.
Maybe: Pure is store disappeared after update L5
Tap Settings → Privacy → Screen Lock, then toggle off “Forbid new USB devices”.
Thank you. worked perfectly!
