In the past hour or so, off the charger at 93%, now 82%. More in line with the 10% per hour I guess.
I did another battery test today. Draining from 95% charge to 18% charge took 7 hours 45 minutes, so realistically about 8+ hours of “on” time.
This was with mobile disabled in the settings, wifi on, and the phone dormant on the table, with just an occasional peek at the battery level.
With SD card inside?
µSD card, yes.
… and smartcard?
No. I don’t have one of those.
If your Wireless Access Point gives you the choice of the 2.4 GHz band and the 5 GHz band and if the 2.4 GHz band is viable for you then you should be able to make a minor improvement in time between charges by selecting the 2.4 GHz band.
However realistically, until Purism implements some kind of sleep mode on the SoC, 10% per hour is about what you are going to get.
Purism recently added power manager to SD card slot, so if you do not have a SD card inside the SD card controller it power off so save battery. Linux 5.15 it close to Librem 5 it come with more power save.
Very nice work of Purism.
Actually, I was on 2.4GHz. (Although I realize you were responding to someone else. Or perhaps to both of us.)
Today I did a similar test, this time on the mobile network, with wifi off. Over 7 hours, the battery drained from 93% to 20%, so again, about 10% per hour (10.4% in this case).
The phone was sitting in two different places indoors throughout the day, with a strong signal in one room, and a weaker signal in the other. I was checking the battery level about once per hour, slightly more frequently than during my wifi test, and also opening the settings screen and browser a couple of times to confirm the data connection. I typically keep the brightness level at about 75% to save power when the screen is on.
Network: A T-mobile MVNO set to 4G; unknown distance from towers, unknown strength/quality of network connection.
µSD inserted, no smart card.
Bluetooth off, as in yesterday’s test.
