Librem 13 LCD panel "flickers"
Hi all,
my laptop LCD panel seems defective. The image “flickering” every now and then (say every 5/10 minutes), i.e. the image intermittently breaks on horizontal lines.
I’ve filmed the issue here: https://youtu.be/TqdGEs0wQWU , The camera did not capture all the details I could see with my naked eye but it should be more evident at seconds 5 and 12.
Has anyone had this issue with their monitor and/or has any clue about how to fix it?
Hi Alessandro,
it usually is one of two things:
  1. current driver is a bit buggy
  2. loose connectors
For bug 0 you just need to wait updates. For bug 1 you should be brave to open librem and check connectors to display and make them “tight” if needed.
Thanks for the feedback Zlatan, I feel relieved it sounds fixable.
