Is there any chance that puri.sm add support for spare parts in their store. For now we just can buy power supply, but it should be nice to buy battery for instance.
If it is too difficult it may be easy and helpful to list somewhere precise specifications (at least Manufacturer and Product number) of some important part of each librem (battery, power supply, keyboard, touchpad, etc.).
I asked the question because I forgot to respect advices given in https://puri.sm/forums/topic/advice-on-battery-use/#post-4427 and my battery seems already to be less less efficient (to say it in nice words) even only 7 months after I received my librem-13
Meanwhile, do you plan to offer some kind of wiki service somewhere so that we can store informations about configuring/running librem boxes as well as some technical details on it?
Some informations are present here in posts of the forum or elsewhere (github, etc.) but difficult to find due to the nature of the tool (forum not knowledge base).
Apart from my battery, I just lose one of the rubber pad of my librem13v1 (which render the everyday use very annoying) and would like to replace it.
If you are not able to sell such spare parts directly, maybe you could publish a list of all spare parts references (in some kind of exploded view) of all of your products on your website. It will also ease the work of users to have links to manufacturer/reseller of such parts.
Finally that would be a major advance to transparency and openess.
I also agree with that. Unfortunately, I don’t think this is going to happen in the immediate future (maybe in the next month or so) because of how busy everyone is right now. I know there is talk of offering spare parts, and I know talk of a wiki keeps coming back every month or so.. the will is there, the problem is the limited resources (not enough hours in a day).
@Bruno, There are plenty of rubber pads you can find on ebay or similar, they usually come in packs of 4 or 10 or something like that, so you don’t need to buy the exact same part (should be easy to measure though), you could just remove the other 3 and replace them all with the new rubber feet you buy.
