Librem 5 - Battery Life - Impressive
I know I am posting a lot about the Librem 5 lately, but I feel like this stuff should be highlighted.
When looking at the battery life of the Librem 5 from the perspective of other phones you might be disappointed. I think this is fair, but just remember Purism has made a lot of progress and there is more to come.
That being said an angle I don’t think I have considered yet is that for the SoC the battery life we have already is very impressive. I’ll give you a frame of reference.
I have an MNT Reform which uses the same SoC as the Librem 5. It is a full up laptop and it is surprisingly capable. Mine has a LIFEPO battery capacity of 16,000 mAh. I can get about 4 hours of battery life out of it while continuously using it.
The Librem 5 has (I believe) a 4,500* mAh battery and gets about the same results, and while the Librem 5 has a much smaller screen, and is not powering a keyboard with backlighting or a trackball, it does have a cell modem and wifi/bt card. It also has a cameras, leds, GPS, ambient light sensor, gyro, and other sensors that it is powering.
In a single day I was able to bring the Reform with me fully charged. Use it for about an hour at lunch, and by the time I got home I had anywhere from 30-20% battery left. The same is happening with the Librem 5!!!
They use the same SoC but the Librem 5 has only 1/4th the battery capacity and is matching battery life with it and there are improvements still coming.
Edit: If you add a laptop dock solution to take advantage of the convergence on the go, you basically enable the phone to last all day without an issue. What I especially love about the laptop dock that @Kyle_Rankin talked about in this thread:
is that you can use it to buffer the amount of power needed during use, and NOT actively charge the phone, thus not wasting a charge cycle. This means you can charge at night. But also have a full mainline Linux computer with you at all times.
You’re not bothering me, I’m excited that people in batch E3 are getting working devices and I’m excited that E4 is (I hope :)) around the corner.
I agree. Another perspective is always welcome.
The battery says 4500 mAh, or at least mine does. However it may not be charging to 100% of that.
Purism please please make: BPP-L504 to improve battery life for Librem 5 via Resistance and Capacity.
