Librem 5 Fir Batch
Yes something strange happened. Because no make sense.
Thanks.
I still believe on the plus, in fact FIR GPU could be better for Librem 5 because ship display 720p.
FIR SoC contains massive accelerator, which enable high video camera 60fps recording at low power, it can not be on evergreen soc and a lot more good things.
FIR L2 cache is 512 but (ECC) and a RAM Bus is much faster as 4000 MT/s than 3200 MT/s(8M,QUAD)Evergreen.
Also Fir ship coprocessor Arm Cortex-M7-768KB,OCRAM(ECC)Shared-as-L3 at 800 MHz than 8M,QUAD,Evergreen Arm Cortex-M3-256KB,OCRAM(NoECC)NoShared at 266 MHz
Also 8M,QUAD,Evergreen L2 cache is 1Mb but (NoECC), also is 1MB due to Leakage on 2D Silicon as 28nm is near to 20nm-2D-full-crash.
Also Fir ship 3D Silicon next-gen as RK3588.
I said gc7000 to reach real gles3.2 and full desktop-class level also gc7000 still for mobile and embedded.
As far i know GC7L is 16 shares on 2 cores and GC7UL is 8 shares on 1 cores.
So looks like you wrong about.
Librem5 is Hybrid, as ship Mobile and Embedded capabilities, but to me and just to me the Librem5 will be so-much better on Embedded mode than Mobile mode. As Mobile is not ready yet but GDAWN is very promising as it will ship as first time a Main NEWPIPELINE which will unlock all the system bottlenecks.
So as Librem5 it is Embedded, Gnu PureOS Mobile can be a Firmware install, so this mean
close-all-doors-and-windows and any holes that LEAKAGE Librem 5 full performance into Gnu PureOS Mobile Firmware, so this mean gnu pureos is no more generic or compat to Librem14-or-whatever. So PureOS Mobile will Fully ENGINEERED BIN for L5, so waydroid,flatpak,firefox and a lot more sotware just gone(bye,bye :waving_hand: for L5) :smiling_face_with_sunglasses:
I not talking about opensources blackboxes.
Kinda
I would like brakedown more put i full busy a.t.m on PowerPC.
Thanks for reply my post.
Yes, I should have written “cores” instead of “shaders”. There are 4 Vega shaders in each Vec4 core. I will fix that in my prior post. I was following sites like this one that describe the GC7000Lite as having “4 shaders”.
Yes, you are right. It’s 5.7". I will edit that post.
@amosbatto what about: Librem 5 Fir → Librem 5 Solo
Librem_5_Solo by i.MX 8QuadMax SoCs. ??
Unlike the i.MX 8M series which uses an SPL U-Boot, the i.MX 8 series requires a bunch of blobs to be able to boot, which is why Purism rejected the i.MX 8 QuadMax back in Aug. 2017 when it first announced the Librem 5. The 8 QuadMax also has poor single-core performance compared to the RK3399 which was used in the PinePhine Pro. I don’t see much point in using the 8 QuadMax, since it is a 28nm planar chip released in 2016. Its two Cortex-A72 cores are now 9 generations old, and the four Cortex-A53 cores is tech that ARM first released in 2012.
If your goal is software freedom, the best choice for a Linux phone is probably using the RK3399S (which is what PINE64 used in the PinePhone Pro), but you will need to add an extra chip to handle DisplayPort Alt Mode, because the RK3399S requires the proprietary dptx.bin firmware blob at boot for DisplayPort Alt Mode. You get horrible battery life, two outdated Cortex-A72 cores from 2015 and four Cortex-A53 cores from 2012, and a chip that was released in 2016.
The second freest option is probably the 14nm i.MX 8M Plus, which requires the Synopsys DDR timing training blob at boot. You won’t be able to use the NPU, ISP and hardware video encoding without blobs, but you don’t need the NPU, and the image processing and video encoding can be done in software. You will have to add another chip for DisplayPort Alt Mode and the GC7000 UltraLite GPU is crappy and video out is not good quality.
The next freest option is the RK3588S. Like the i.MX 8M Quad and i.MX 8M Plus, the RK3588S needs to execute a proprietary Synopsys DDR timing training blob at boot. The RK3588S can now use the free Panthor driver for the GPU, but it requires the proprietary mali_csffw.bin firmware, which is loaded from the /lib/firmware/ directory at boot. All the other blobs for the RK3588S have either been replaced or they aren’t necessary. There is now a FOSS driver for the NPU. The proprietary MPP library for hardware video encoding can be replaced with software video encoding, and Collabora is working on free drivers for the ISP and hardware video encode, so software video processing and encoding probably won’t be necessary in the future. Collabora has developed a FOSS version for the Trusted Firmware-A (TF-A), that can replace the proprietary bl31.elf firmware. The HDMI blob in the bl31.elf isn’t necessary if using DisplayPort Alt Mode for video out. The proprietary bl32.bin firmware is not necessary if not using the hardware-enforced security features or encryption keys.
The i.MX 95 is less free than the RK3588S, and I don’t think that any group is working on freeing the drivers for the i.MX 95 like Collabora is doing for the RK3588.
The RK3588S doesn’t have a secondary processor like the Cortex-M4 in the i.MX 8M Quad, that can be used to boot the system and handle a firmware-jail, so RYF certification won’t be possible, but the Librem 5 never got RYF certification, so that ship has already sailed. However, with the RK3588S you get a phone with the processing power to actually function like a modern smartphone. Most people simply won’t buy a phone that can’t shoot decent video. If we want Linux phones to ever break out of their tiny niche and actually be considered a viable alternative to Android and iOS, Linux phones need a good processor.
The other thing is that Purism now has real competition. The Jolla Phone (2026) sold out its first batch of 10,000 units in the first 48 hours that Jolla opened preorders for the phone. If the Liberux NEXX or the Dawndrums Divine D. come to market with the RK3588S, I doubt Purism will be able to sell its next gen Librem phone if it has a low-performance SoC like the i.MX 8M Plus or RK3399S.
