Please take some scaled images with a ruler!
I have designed a phone cover (and here), but cannot release the final design until I have dimensions and locations of switches. Thanks!
You mean like this one?
Looks 76x155mm-ish to me.
I remembered seeing this, and sure enough it was in one of the articles I added to the Librem 5 Chronology.
The slashgear one in this case.
More details on Gardinerâs interview with Todd, and checking out the Librem 5. This is from the Off Topical podcast.
A couple of notes of mine -
- No, he didnât get to keep the phone
- This was the very first phone to roll off the line.
- Todd has AT&T, and they did not have an AT&T signal, so did not make a call during their conversation. BUT, it does make calls. Todd had 2 Librem 5âs on him, and he showed the call log from one of the phones.
- Interesting - They are adding a âheat pipe systemâ to Birch, to help with heat. Aspenâs main cooling control is CPU throttling.
- Other than the heat pipe system, and updates to switch caps, the hardware is done.
My iPhone 6s took a nano SIM. The last phone I had that took a mini SIM was my Galaxy S3.
Thanks
I had looked up the SIM size for my older phone at first (iPhone 4s - which Iâve since given to one of my teenagers). I was being flighty yesterday.
So I should just be able to swap the SIM out
I wonder how difficult it would be to affix something thermally conductive and homemade to dissipate the heat. And if Purismâs heat pipe could be installed later when it becomes available.
Heat pipes are very specialized to the hardware. If Purism doesnât sell the part, I doubt that you can find generic heat pipes that you can use. You might be able to find a metal heat spreader for another phone model that you can use on the Librem 5, but you will probably have to look for a recent gaming phone or 5G phone to find a metal heat spreader. Most phones just use a graphite sheet to spread the heat.
Looks like I can buy a small pyrolytic graphite sheet or graphite flexible foil sheet from eBay and cut it to size. I already have thermal adhesive.
I would assume that the Aspen batch already has a graphite sheet for heat dissipation, because most phones today have that, so adding more sheets probably isnât going to help.
If they are planning to add heat pipes, then the Librem 5 needs serious cooling beyond what a graphite sheet can provide.
The i.MX8MQ processor wasnât designed for mobile phones, so it isnât surprising that Purism will need to add extra cooling. Luckily, this isnât going to cost Purism nearly as much today as it used to, because all of todayâs 5G and gaming phones need this kind of advanced cooling, so it is becoming a common part.
They showed a bare CPU in the picture, so i doubt i has anything.
Thanks, but this doesnât quite cut it by itself. Without a lot of estimation/interpolation, I canât get good measurements of thickness, bevel and position of switches/ports. Iâll probably just have to wait until I get mine in December.
It would be really nice if they would release the CAD files of the aluminum frame and back cover.
I would contact support directly and ask them. I think they just may let you get them.
Thatâs a good idea, Iâll give it a shot.
Please say if they do; I asked for 3D models a while ago but they said they werenât ready to release them yet, so if they do I should ask again.
