A couple months ago I had my Dell wireless keyboard and mouse hooked up to my L5 via a small apple usb-c hub.
Recently, it will not connect to my mouse even when using a variety of hubs available.
I even tried using a usb-c to usb-a direct adapter and it still wonât work.
I have not tried using a wired mouse but I did try another wireless mouse that did not work.
It will connect to a TV I have access to via a usb-c to hdmi adapter.
lsusb returns the adapter showing but not the mouse
It could be a bug, or you have to follow some kind of an order.
First add your usb-c to usb-a adapter, and then attach the Mice and keyboard a few seconds later. I think this may be some race condition. Because it worked last time.You say you proved the Hardware with another system, so it just can be a software issue.
Can it be some kind of a power issue and about Voltage related too? Have Checks and error Messages aside ASwyD2 - however it can be a kernel driver issue. But if you do not know how to boot a specific Kernel on a Linux system try to be careful. Keep in mind that it could be some random cable brake issue, by a random wire expose/attache in the first place. Have a Check List to exclude every unlikely possibility first. Yes it could be a bad official purism update too.
So this means a wireless keyboard and mouse combo using a nano receiver? As distinct from a fully wireless keyboard and mouse (Bluetooth)?
If the former, I assume that you have fault isolated the nano receiver in another computer? Batteries not flat in the keyboard or mouse? Mouse not faulty? Proprietary pairing problem?
Are you implying that the keyboard works? Or the keyboard doesnât work either?
You might try a USB flash drive, as something simpler than USB-C to HDMI and simpler than a nano receiver.
Yes
All checked on a PC
No the keyboard does not work either.
I will try that. Thanks
I donât know how to check.
There isnât any cables
Running Linux?
No. Windows 11 ![]()
@Ick
Is this similar to the problem you had in this thread
FWIW, this can work with the Librem 5.
When I plug in the USB-C to USB-A adapter to the Librem 5, root hubs appear in lsusb output.
When I plug in the Logitech nano receiver to the adapter, the nano receiver appears in lsusb output. NB: Logitech, not Dell. So not a definitive test. At this point a cursor appears on the screen also.
When I switch on the keyboard (which has a built-in trackpad), there is no change to lsusb output at all - but of course the keyboard can now be used and the cursor on the screen can be moved using the trackpad.
That is to say, lsusb -v output for the receiver reports the existence of two HIDs, the keyboard and the mouse, even when there arenât any because the keyboard is switched off. (So I guess maybe the nano receiver hides the state transitions of the keyboard/mouse appearing and disappearing. Perhaps this is OK since these are only input devices. They just donât generate any input when switched off.)
However, if I understand your situation, the nano receiver doesnât even ever appear. (I like to capture lsusb output so that if something âused to workâ and now âdoesnâtâ then I have something to compare with.)
Edit: PS byzantium, kernel 6.6.0-1-librem5
After restarting phone everything works as usual. So if it doesnât work for you, itâs something different. Also I used journalctl --system to look at logs. I had a lot of spam log when error happens.
Itâs too early to be sure, but I guess itâs something different. Since Kernel 6.6 an error seems to be fixed (too early to say), but Iâve got another error that seem to be caused by flashing my keyboard plus connecting via Bluetooth as next step. It seems that Bluetooth itself makes no troubles anymore (as I said âtoo early to be sureâ), but the combination of both steps. And Iâm sure you didnât flash your devices. Restarting phone and connecting via Bluetooth or USB shouldnât make any troubles anymore (at least I hope so).
This is it without anything attached:
purism@pureos:~$ lsusb
Bus 001 Device 004: ID 2020:2060 Qualcomm, Incorporated Qualcomm CDMA Technologies MSM
Bus 001 Device 003: ID 0424:4041 Microchip Technology, Inc. (formerly SMSC) Hub and media card controller
Bus 001 Device 002: ID 0424:2640 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
This is with the adapter attached:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
This is it with the nano chip plugged in:
lsusb -v with everything attached
purism@pureos:~$ lsusb -v
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 6.06
iManufacturer 3 Linux 6.6.0-1-librem5 xhci-hcd
iProduct 2 xHCI Host Controller
iSerial 1 xhci-hcd.4.auto
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2020
idProduct 0x2060
bcdDevice 0.00
iManufacturer 3 Qualcomm, Incorporated
iProduct 2 Qualcomm CDMA Technologies MSM
iSerial 4
bLength 9
bDescriptorType 2
wTotalLength 0x0091
bNumInterfaces 5
iConfiguration 1
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 3
bInterfaceSubClass 254
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x88 EP 8 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0424 Microchip Technology, Inc. (formerly SMSC)
idProduct 0x4041 Hub and media card controller
bcdDevice 2.09
iManufacturer 1 Generic
iProduct 2 Ultra Fast Media Reader
iSerial 3 000008264001
bLength 9
bDescriptorType 2
wTotalLength 0x0020
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 96mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idProduct 0x2640 USB 2.0 Hub
bcdDevice 9.02
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 6.06
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
bcdDevice 6.06
iSerial 1 xhci-hcd.5.auto
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 6.06
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
In other words nothing? no change? not recognised?
(So the lsusb -v output is not relevant. I actually just meant lsusb -v on the one specific device, the nano receiver.)
Maybe take a look at the system journal to see whether anything gets reported when you plug in the nano receiver.
Do you have another Linux system that you could use to try the nano receiver on?
No, sadly
It has worked previously on my L5 though.
How would I get the journalctl narrowed down to the usb?
You mean journalctl ?
Probably something like journalctl -b 0 | grep zzz where zzz is suitable to pick out the approximate time when you plugged in the nano receiver. For more specificity you can use --since= and/or --until= with journalctl but you will probably need to read the man page for the details.
Iâm not finding anything that points to the nano receiver
Iâll probably work on it more in the morning. Thanks
Oh.. its USB with Bluetooth Dongle. OK. This way you can have two Systems which need to cooperate and likely another third one to take care, if your Keyboard is still working (Keyboard Hardware Check) and if its Battery is full (if it has some kind of Accumulator).
For the USB-BT-Dongle, you have to Check if your Kernel support that Dongle, but iâam not sure if there is something like a special driver needed for (some Bluetooth Device, cause i have not much Hardware to test) - if its worked before is more unlikely.
Your lsusb did not list any USB-Device through, after attaching or it needs more time. And its different if you have it attached before boot or just hot plug it later.
This way its good to have another Linux System to check, like what driver Modules got load and what Log-messages it tell after attaching. - Yes Computers are kind of complex.
But maybe, your device care about connected Bluetooth addresses and will only pair with a few. In that case you should have to take care about the dongle (and its Hardware Address), or other Devices in range, you already paired it with. And how you can flush the Hardware Pairings list, to connect to another device. I am sad to tell, but this is Hardware dependable and on Linux/Windows and Mac as OS, maybe Operating-System-individual too. And it may be different if you have only one Device in Range or more.
That was why i talk about some List for a check. And the empty battery will made it more complex.
Think your issue is less complex, cause its often just one rival, like have to many BT Devices connected near and use this with 3 or more Devices.
As covered in a number of posts above, probably not bluetooth.
Thatâs an interesting question. Because of this topic I had a look at some Dell wireless keyboard / mouse combos. It seems that some of them offer both of the following:
- Bluetooth direct to a host that has Bluetooth hardware, and
- nano receiver plugged into a USB port
(but presumably not both at the same time)
(It seems that the main motivation of the latter is that many systems donât support Bluetooth in the early boot environment. So if you routinely need a keyboard to boot the computer, that is a problem. Obviously the nano receiver is also essential for those computers that donât even have Bluetooth hardware.)
Does this imply that the nano receiver is simply a Bluetooth dongle? No, very likely itâs not. Does this imply that the nano receiver uses Bluetooth in some form? No, not necessarily. Would it be efficient design for the nano receiver to use Bluetooth in some form? Yes. It is my suspicion that the nano receiver is basically using Bluetooth but it pairs automatically and then just pretends that the host is looking at a USB keyboard and mouse. Of course with blackbox hardware we may never know.
Yeah my Dad has one of those. It is very handy, but it wouldnât connect to the L5 via bluetooth(redpine card).
It says that it is 2.4 but can we trust what they say?
I had not heard of dual 2.4 GHz / bluetooth devices.
Sounds like a two edged sword of convenience and complicated trouble shooting / OS support.
I have always been frustrated by the ambiguity of the term â2.4 GHz wirelessâ because bluetooth and some wifi are also 2.4 GHz and all three are wireless.
Mine isnât bluetooth, but yeah.
