Continuing the discussion from [MyL5] Librem 5 Evergreen: first impressions:
Full quote of new owner @l5newbie
@l5newbie Thanks for your summary, I think most of them are valid points! I just stumbled upon this one:
How do you mean that? On Android I get e.g. ö by long press o and thought this is normal behaviour? Is that different from the umlaut menu on the Librem 5 you mentioned?
Hi @l5newbie, I made a new topic of your post top better be able to respond.
Those are good observations, e.g. with the sliding inconsistency. Only thing I could think of is that itâs on purpose that a tap is not sufficient on the lock screen. So that it doesnât unlock to easily. But the dock could/should slide maybe?
Most of your comments seem to be related to keyboard things, so @dcz might be interested to respond.
Also, have a look at this post (or the whole topic):
Iâm also interested in the German keyboard, although not the Austrian ![]()
The lock screen requires that I swipe the upwards arrow, tapping doesnât work.
On the PinePhone using distros that have Phosh this also drove me crazy - after getting used to tapping arrows when the device is unlocked to bring down/up menus the switch in behavior on the lockscreen took some getting used to.
I agree with a few others that itâs probably to keep things more secure when the phone is in a pocket or the like but still was something that bothered me initially.
Thanks for the writeup, enjoyed hearing your thoughts!
(Observations based on my Samsung Android phone, there are other keyboards I guess.) Thatâs normal behavior for, e.g. an English keyboard. It also works on a German keyboard, but the German keyboard also has a separate Ă key.
Yes. The German Librem 5 keyboard has a separate button labeled âĂ€Ăâ which you must tap to open a separate âkeyboardâ with all kinds of special characters. There you can tap one (and this separate keyboard then closes and you get back to the main one). The Librem 5 keyboard has no âlong pressâ behavior like Android or âpull downâ behavior like iOS.
I actually donât mind the swipe. I would like to be able to swipe in the main UI as well. But most of all I would like things to be consistent.
Update es.yaml (!195) · Merge requests · Librem5 / squeekboard · GitLab
Thatâs the thing: You need to open a merge request to add keyboard definitions. The German one for example is at data/keyboards/de.yaml · master · Librem5 / squeekboard · GitLab. BUT a superior definition (lots of them, actually) is also already present on the Librem 5, in /usr/share/X11/xkb/symbols/de. These files must be where all the keyboard names are taken from. But then I claim that the actual keyboard layout data should also come from these files, rather than slowly duplicating individual ones one by one and in an incompatible way.
Poking around there I also found that there is also a âwideâ German keyboard definition which does have actual Ă, Ă, etc. keys: data/keyboards/de_wide.yaml · master · Librem5 / squeekboard · GitLab. I just have no idea how to select this from the Settings app.
Oh. I hope long press for characters is on the future roadmap. ![]()
In some cases it just reflects the fact that there is more work to be done.
I didnât have a problem with the mail client however. It seemed to work normally and intuitively for me (and I havenât ever used it before).
A fair point. Itâs not at all a helpful name. However that is the name and Purism is not the author so for a variety of reasons it might not be appropriate to change the name.
The icon is an envelope (or stack of envelopes in an in-tray). Seems fair to me??? Maybe the edges of the envelope need to be harsher?
This is the offending icon:
(converted from svg to png - seems this forum doesnât allow svg???)
In case it helps, at least you will know: Geary (e-mail client) - Wikipedia
Seconded. I donât see why the user is not free to have even a 4-digit code.
Maybe Settings / Notifications / Notification Feedback
choices are: Silent, Vibration only, Sound and Vibration
(doesnât seem to offer âSound onlyâ but at least try Silent and see whether that changes what you want to change)
Which band? 2.4 or 5 GHz?
Youâll be able to - the only reason it reacts to taps instead of swipes at the moment is that swiping there isnât implemented yet as itâs much more complicated to implement there than on the lockscreen. It was always supposed to react to swipes in the designs, tapping is just a stop gap.
The âGerman (Austria)â keyboard has no umlaut keys at all.
We donât have an Austrian layout in Squeekboard. It will fall back to German instead of US in v1.12.
it seems to import some information from the XKB symbols database, since I can select an âEnglish (intl, with AltGr dead keys)
The keyboard imports layout names, but no layouts. What youâre setting is the global keyboard and what youâre seeing is a fallback. Alternative layouts currently broken (#261) · Issues · Librem5 / squeekboard · GitLab This will not change, xkb layouts are incompatible with phone screen sizes.
Iâm not saying that the layouts should be imported 1:1, but the locations of the letter keys (including umlauts etc.) could be used for the main keyboard view. xkb layouts for typical Latin/Cyrillic/Greek have about 9-11 letters per row. Up to 11 letters per row is a common number for Android phone keyboards (e.g., the Samsung German keyboard) and absolutely usable. The Librem 5 Russian keyboard has 11 letters in one row as well. Would 12 be too much? Maybe, but (a) thatâs not an argument against using the xkb layout for German (11 letters in the home row), and (b) the Sailfish OS Russian keyboard has 12 letters in a row and looks usable.
I see what you mean. I guess that could be a good starting point, but it would produce broken layouts: Cyrillic phonetic has letters in weird places, including the number row, and actually 13 keys in the top row:
Ń1234567890-Ń
ŃĐČĐ”ŃŃŃŃĐžĐŸĐżŃŃŃ
so that would need some dedicated work. Once weâre past that, weâd need to figure out a way to deal with dead keys. Thatâs a matter of more work of course. Once we have that, we only have to deal with managing levels (like AltGr). Thatâs nothing that canât be done with work.
In comparison, the work needed to even parse the layouts is insignificant.
But it all adds up, and thatâs a problem.
Iâm going to be happy if someone writes a layout converter though, even not working for some layouts. Those could provide a starting point for layout makers.
2.4 GHz. The channel width is set to âautoâ in the router, I donât know how to tell if it actually uses 20 or 40 MHz.
vibrate on keyboard key presses
Setting that to Silent does disable they keyboard vibration. But it also disables all other sound and vibration on notifications, e.g., when I set a timer in the Clocks app.
Which modem did you choose and does it work with A1 or Drei?
No modem, this is about wifi. Another 2.4 GHz wifi network (tethering from one of my other phones) works without any issues. I havenât installed a SIM yet, so no experience with how mobile networks work.
OK. Honestly, I didnât even think about this. My Librem 5 connected to the WiFi out-of-the-box. However it is using the 5 GHz band (which in turn has defaulted on the access point to 40 MHz channel width).
Is 5 GHz an option for you to try?
Otherwise I suppose you are waiting for that merge request to see whether it makes a difference.
