Oh wow, I totally missed that particular screen. As I said, I don’t have the modem on very often, and no settings under Mobile are visible when it’s off.
Thanks!
Can you confirm that SMS and data work with Truphone? Did you have to change any of the APN settings? Have you only been using LTE or have you tried with 2G or 3G?
the modem is not embedded in in the SoC, consider it similar to a Wifi module on a laptop, if it is not connected it is non existent for the (in this case) phone
At the moment chats will not show stored SMS if the modem is disabled, that issue is known, and it is being worked on:
But if you have an xmpp, telegram, matrix account in chatty, it will work even with the modem disabled.
XMPP support exists by default, telegram and matrix you would need to build the plugins from source, the matrix plugin is quite resource intensive atm.
If you have an Icon similar to this one in the top bar it means that there is no data (wifi or mobile data). You can toggle the “Mobile data” button in the mobile settings off and on once to see if that solves the issue
joao.azevedo amosbatto
I’ve got data with Truphone now. I removed the SIM and tried a different carrier, then reinserted the Truphone SIM. Everything works.
BTW, Amos, I don’t think AT&T (Truphone runs on them in the US) has 2G anymore, right?
I can confirm SMS and LTE for Red Pocket’s GSMA SIM, too.
For those who don’t know, Red Pocket resells AT&T, Tmobile, Sprint, AND Verizon… rather cheap!
Do you think this is a real option as a daily driver?
I mean how fast do android apps start compared to native ones… are they responsive enough to use it all the time? Or are they only an alternative for apps where there is no way around?
Whether this can be the main phone for you depends on your own requirements. Are you content with the available optimized apps and functions for now (see my thread about the current PureOS store app list)? Is 5-8 hours (depending on how heavy your use is) of battery life enough for you for the moment? Can you recharge at will? Are you OK with your voice sounding slightly muffled to call recipients (until Purism sorts that out)? Can you do without MMS (which may affect your ability to receive group messages and other types)? Do you mind the thickness and weight of the device?
I think it certainly can be one’s full-time phone; the Purism team is certainly improving the software every day. But it’s all relative.
As for Android apps, I don’t know if Anbox is available yet, so I can’t offer an opinion on that.
You’re welcome! The L5 caller’s voice is slightly muffled over cellular. And I don’t know if wifi calling is available yet. I don’t see a setting for it.
The “Librem Mail” app that Purism distributes for Android as part of Librem One is a fork off of K9 mail, so they should have some familiarity with it, at any rate…
I use that one too. It would be nice to have a very simple calendar with no connections to the big bad companies. The simpler the better. No need for bells and whistles. I even consider net sync to be a possible problem. And in Linux it is always easy to download and upload the calendar file.
