No internet connection
By uninstalling a bunch of apps. :wink:
I’m glad that you now have a working phone. Unfortunately that means that we will likely never understand how your phone got into that state.
That may well do the trick but a less aggressive approach is to follow: [Hint] Remove Icons
Which is most appropriate depends on the specific application.
Outright uninstalling reduces your attack surface and your disk space usage so if you are highly confident that you will never use it, this may be the best approach but it is then more hassle to get the application back if the situation changes.
Editing your private copy of the .desktop file means that you are masking (and losing) any changes that get made by a future update to the .desktop file but it is trivial to get the application back if the situation changes.
With either approach there isn’t actually a sane way, as far as I am aware, for the non-technical user to tackle this.
If you are going to uninstall things then you need to be able to map desktop icon to name of package, which is sometimes easy and sometimes not so easy.
If you are going to edit .desktop files then you need to be able to map desktop icon to name of .desktop file.
