PureOS Crimson Question!
is pure os crimson its software package using debian testing main by default?
and is it true that I saw on wikipedia pure os. Pure os is said to be like hybrid stable and unstable?
Crimson uses Bookworm; Byzantium (current release) uses Bullseye. PureOS uses its own repositories.
There is no equivalent for Trixie.
Hybrid? I doubt it. Seems far more stable than unstable to me.
an article said on wikipedia that pure os is hybrid. example the pureos is stable but the software is base on debian testing more up todate than stable
Cite the reference.
i dont know if this true
Which in turn, cites this blog article:
Then, bringing it up to the present, we have this scenario:
  • Byzantium, which is stable
  • Crimson, which is rolling
The key terminology here is “hybrid point release and rolling release model”, not “hybrid stable and unstable”.
By the way, here is Crimson:
i search that point release is stable and rolling release is unstable. so it is hybrid
btw thank you for sending pureos crimson link
Your description of hybrid is vague and suggests that PureOS is some sort of amalgamation between stable and unstable repositories, so I had to clarify all ambiguities and terminologies.
Dear @dos i have,ad plans to start using My Librem 5 in Crimson, however i will never using my Librem 5 with Redhat-Plymouths on Booting, there are Hacks in U-boot to Hidden it or something else?
Thanks
/carlosgonz
You might want to take a look at /etc/default/flash-kernel, there are some params here that I think will disable plymouth.
I am not sure if making changes to this file alone is all that’s needed, or if there are additional steps to “flash” the kernel.
splash plymouth.ignore-serial-consoles
I have not tested this, but I think removing them will disable Plymouth.
I am using this this a reference. (sorry to link you to the Arch wiki, I know you aren’t a huge fan of that either :))
Thanks for the Info.
Anyone know if there are ARM builds for the phone somewhere? Also, what is the difference between Gnome & Gnome OEM?
Is there an ARM KDE build too?
The former sets up LUKS and user accounts before installation, the latter sets up LUKS and user accounts after installation.
No.
