Reprogram Shift Key on Librem 14
Is there a way to reprogram the pgup key to work as a Shift function. I’m using my Librem 14 largely as a content writer and am having difficulty adjusting to the small Shift key. Its driving me nuts. Jumping from one page line to another - and in and out of programs. Please advise.
I believe the answer to your question is addressed in this thread:
You can do this easily by modifying the keymap in the Librem EC source code, then reflashing the EC firmware.
The file is located in this location:
librem-ec/src/board/purism/librem_14/keymap/default.c
It’s possible to do it using just udev. To do that create /etc/udev/hwdb.d/99-librem14.hwdb with the following content:
# Librem14v1 keyboard
evdev:input:b0011v0001p0001*
  KEYBOARD_KEY_3A=leftctrl # CapsLOCK -> LCTRL (if requred)
  KEYBOARD_KEY_C8=rightshift # UP -> RSHIFT
Then issue:
$ sudo systemd-hwdb update # updates hwdb.bin
$ sudo udevadm trigger # reloads hwdb.bin to the system
Thank you all - very helpful.
