Turning the L5 off or rebooting takes about 2 minutes.
Pressing the volume control reveals the linux console, where systemd says: “A stop job is running …”, where it sits and waits for a timeout. Unfortunately, it is not clear, where it hangs.
Which image are you using? Did you reflash?
That’s been an issue for all computers since time immemorial. Usually a process is running that won’t die. Since the L5 is now the computer in your pocket, expect the problem to also migrate there. Hopefully holding the power button down is a hard kill switch?
Thank you for looking at this, @dcz.
I think i have the situation from the start, i.e. already with the factory image. I’ve then upgraded, updated. I did not flash any image, so the installation should be default due to the repository, with a minimum of extra software, most notably a ssh-server added.
Hmm, i include the shutdown section of the log:
Feb 19 13:21:50 pureos systemd-logind[511]: Power key pressed.
Feb 19 13:21:51 pureos systemd-logind[511]: Watching system buttons on /dev/input/event9 (SEM USB Keyboard System Control)
Feb 19 13:21:51 pureos systemd-logind[511]: Watching system buttons on /dev/input/event8 (SEM USB Keyboard Consumer Control)
Feb 19 13:21:51 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 1.
Feb 19 13:21:51 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
Feb 19 13:21:52 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 1.
Feb 19 13:21:52 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
Feb 19 13:21:53 pureos kernel: rfkill: input handler enabled
Feb 19 13:21:53 pureos bluetoothd[716]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc
Feb 19 13:21:53 pureos bluetoothd[716]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc
Feb 19 13:21:53 pureos systemd-logind[511]: Session 1 logged out. Waiting for processes to exit.
Feb 19 13:21:53 pureos systemd-logind[511]: Failed to restore VT, ignoring: Input/output error
Feb 19 13:21:53 pureos systemd[1]: phosh.service: Main process exited, code=killed, status=11/SEGV
Feb 19 13:21:53 pureos systemd[1]: phosh.service: Failed with result 'signal'.
Feb 19 13:21:53 pureos NetworkManager[507]: <info> [1613737313.4042] device (wlan0): supplicant interface state: scanning -> inactive
Feb 19 13:21:53 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 1.
Feb 19 13:21:53 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
Feb 19 13:21:53 pureos systemd[1]: session-1.scope: Succeeded.
Feb 19 13:21:53 pureos systemd-logind[511]: Removed session 1.
Feb 19 13:21:53 pureos polkitd(authority=local)[504]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.57, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C.UTF-8) (disconnected from bus)
Feb 19 13:21:53 pureos dbus-daemon[505]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.1321" (uid=1000 pid=5016 comm="/usr/bin/pulseaudio --daemonize=no ") interface="org.freedesktop.DBus.ObjectManager" member="GetManagedObjects" error name="(unset)" requested_reply="0" destination="org.bluez" (uid=0 pid=716 comm="/usr/lib/bluetooth/bluetoothd ")
Feb 19 13:21:54 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 1.
Feb 19 13:21:54 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
Feb 19 13:21:55 pureos systemd-logind[511]: Power key pressed.
Feb 19 13:21:55 pureos systemd-logind[511]: Powering Off...
Feb 19 13:21:55 pureos systemd-logind[511]: System is powering down.
Feb 19 13:21:55 pureos systemd[1]: Stopping User Manager for UID 1000...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Graphical Interface.
Feb 19 13:21:55 pureos systemd[1]: Stopping Disk Manager...
Feb 19 13:21:55 pureos systemd[1]: Stopping Daemon for power management...
Feb 19 13:21:55 pureos systemd[1]: Stopping Availability of block devices...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Timers.
Feb 19 13:21:55 pureos systemd[1]: man-db.timer: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Daily man-db regeneration.
Feb 19 13:21:55 pureos systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Feb 19 13:21:55 pureos systemd[1]: apt-daily-upgrade.timer: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Daily apt upgrade and clean activities.
Feb 19 13:21:55 pureos systemd[1]: logrotate.timer: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Daily rotation of log files.
Feb 19 13:21:55 pureos systemd[1]: apt-daily.timer: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Daily apt download activities.
Feb 19 13:21:55 pureos systemd[1]: Stopped target System Time Synchronized.
Feb 19 13:21:55 pureos bluetoothd[716]: Terminating
Feb 19 13:21:55 pureos kernel: redpine_91x: RSI `hci0' flush
Feb 19 13:21:55 pureos kernel: redpine_91x: RSI HCI DEVICE "hci0" closed
Feb 19 13:21:55 pureos kernel: redpine_91x: rsi_hci_close: device `hci0' not running
Feb 19 13:21:55 pureos systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Feb 19 13:21:55 pureos systemd[1]: systemd-rfkill.socket: Succeeded.
Feb 19 13:21:55 pureos ModemManager[541]: <info> caught signal, shutting down...
Feb 19 13:21:55 pureos udisksd[513]: udisks daemon version 2.8.1 exiting
Feb 19 13:21:55 pureos ModemManager[541]: Cannot read from istream: connection broken
Feb 19 13:21:55 pureos systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] QMI endpoint hangup: removed
Feb 19 13:21:55 pureos ModemManager[541]: <info> [modem0] connection to qmi-proxy for /dev/cdc-wdm0 lost, reprobing
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Releasing 'voice' client with flags 'release-cid'...
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Unregistered 'voice' client with ID '2'
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Releasing 'pdc' client with flags 'release-cid'...
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Unregistered 'pdc' client with ID '1'
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Releasing 'loc' client with flags 'release-cid'...
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Unregistered 'loc' client with ID '1'
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Releasing 'uim' client with flags 'release-cid'...
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Unregistered 'uim' client with ID '1'
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Releasing 'wms' client with flags 'release-cid'...
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Unregistered 'wms' client with ID '1'
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Releasing 'nas' client with flags 'release-cid'...
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Unregistered 'nas' client with ID '1'
Feb 19 13:21:55 pureos systemd[1]: Stopping Location Lookup Service...
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Releasing 'dms' client with flags 'release-cid'...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Sound Card.
Feb 19 13:21:55 pureos ModemManager[541]: [/dev/cdc-wdm0] Unregistered 'dms' client with ID '1'
Feb 19 13:21:55 pureos systemd[1]: Stopping Accounts Service...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Host and Network Name Lookups.
Feb 19 13:21:55 pureos systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Closed LVM2 poll daemon socket.
Feb 19 13:21:55 pureos systemd[1]: Stopped Phosh, a shell for mobile phones.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Bluetooth.
Feb 19 13:21:55 pureos systemd[1]: Stopping Bluetooth service...
Feb 19 13:21:55 pureos systemd[1]: Stopping IIO Sensor Proxy service...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Multi-User System.
Feb 19 13:21:55 pureos systemd[1]: Stopping Login Service...
Feb 19 13:21:55 pureos systemd[1]: Stopping Modem Manager...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Login Prompts.
Feb 19 13:21:55 pureos systemd[1]: Stopping Serial Getty on ttyGS0...
Feb 19 13:21:55 pureos systemd[1]: Stopping Getty on tty1...
Feb 19 13:21:55 pureos systemd[1]: Stopping Serial Getty on ttymxc0...
Feb 19 13:21:55 pureos systemd[1]: Stopping Regular background program processing daemon...
Feb 19 13:21:55 pureos blkdeactivate[5030]: Deactivating block devices:
Feb 19 13:21:55 pureos systemd[1]: run-user-1000-doc.mount: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Unmounted /run/user/1000/doc.
Feb 19 13:21:55 pureos bluetoothd[716]: Stopping SDP server
Feb 19 13:21:55 pureos systemd[1]: cron.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos bluetoothd[716]: Exit
Feb 19 13:21:55 pureos systemd[1]: cron.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Regular background program processing daemon.
Feb 19 13:21:55 pureos systemd[1]: accounts-daemon.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Accounts Service.
Feb 19 13:21:55 pureos systemd[1]: udisks2.service: Succeeded.
Feb 19 13:21:55 pureos NetworkManager[507]: <info> [1613737315.2811] bluez5: NAP: removed interface 88:DA:1A:B6:5D:90
Feb 19 13:21:55 pureos systemd[1]: Stopped Disk Manager.
Feb 19 13:21:55 pureos systemd[1]: iio-sensor-proxy.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: iio-sensor-proxy.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped IIO Sensor Proxy service.
Feb 19 13:21:55 pureos systemd[1]: serial-getty@ttymxc0.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: serial-getty@ttymxc0.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Serial Getty on ttymxc0.
Feb 19 13:21:55 pureos systemd[1]: getty@tty1.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: getty@tty1.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Getty on tty1.
Feb 19 13:21:55 pureos systemd[1]: serial-getty@ttyGS0.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: serial-getty@ttyGS0.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Serial Getty on ttyGS0.
Feb 19 13:21:55 pureos systemd[1]: bluetooth.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Bluetooth service.
Feb 19 13:21:55 pureos systemd[1]: upower.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: upower.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Daemon for power management.
Feb 19 13:21:55 pureos systemd[1]: colord.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: colord.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Feb 19 13:21:55 pureos systemd[1]: geoclue.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: geoclue.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Location Lookup Service.
Feb 19 13:21:55 pureos systemd[1]: Starting Show Plymouth Power Off Screen...
Feb 19 13:21:55 pureos systemd[1]: Removed slice system-getty.slice.
Feb 19 13:21:55 pureos systemd[1]: Removed slice system-serial\x2dgetty.slice.
Feb 19 13:21:55 pureos systemd[1]: user@1000.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped User Manager for UID 1000.
Feb 19 13:21:55 pureos systemd[1]: Stopping User Runtime Directory /run/user/1000...
Feb 19 13:21:55 pureos systemd[1]: Received SIGRTMIN+20 from PID 5054 (plymouthd).
Feb 19 13:21:55 pureos systemd[1]: blk-availability.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Availability of block devices.
Feb 19 13:21:55 pureos systemd[1]: run-user-1000.mount: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Unmounted /run/user/1000.
Feb 19 13:21:55 pureos systemd[1]: user-runtime-dir@1000.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped User Runtime Directory /run/user/1000.
Feb 19 13:21:55 pureos systemd[1]: Removed slice User Slice of UID 1000.
Feb 19 13:21:55 pureos systemd[1]: Stopping Permit User Sessions...
Feb 19 13:21:55 pureos systemd[1]: systemd-user-sessions.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Permit User Sessions.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Remote File Systems.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Network.
Feb 19 13:21:55 pureos systemd[1]: Stopping WPA supplicant...
Feb 19 13:21:55 pureos systemd[1]: Stopping Network Manager...
Feb 19 13:21:55 pureos NetworkManager[507]: <info> [1613737315.4121] caught SIGTERM, shutting down normally.
Feb 19 13:21:55 pureos systemd[1]: Stopping Raise network interfaces...
Feb 19 13:21:55 pureos systemd[1]: Stopping Network Name Resolution...
Feb 19 13:21:55 pureos systemd[1]: systemd-resolved.service: Succeeded.
Feb 19 13:21:55 pureos NetworkManager[507]: <info> [1613737315.4219] device (cdc-wdm0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Feb 19 13:21:55 pureos systemd[1]: Stopped Network Name Resolution.
Feb 19 13:21:55 pureos ModemManager[541]: <info> ModemManager is shut down
Feb 19 13:21:55 pureos systemd[1]: Stopping Network Service...
Feb 19 13:21:55 pureos systemd[1]: systemd-networkd.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Network Service.
Feb 19 13:21:55 pureos systemd[1]: ModemManager.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Modem Manager.
Feb 19 13:21:55 pureos systemd[1]: networking.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Raise network interfaces.
Feb 19 13:21:55 pureos NetworkManager[507]: <info> [1613737315.4634] exiting (success)
Feb 19 13:21:55 pureos systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-networkd.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Feb 19 13:21:55 pureos systemd[1]: systemd-networkd.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-networkd.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Feb 19 13:21:55 pureos systemd[1]: systemd-networkd.socket: Failed with result 'resources'.
Feb 19 13:21:55 pureos systemd[1]: Started Show Plymouth Power Off Screen.
Feb 19 13:21:55 pureos wpa_supplicant[506]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Feb 19 13:21:55 pureos systemd[1]: Stopping Authorization Manager...
Feb 19 13:21:55 pureos wpa_supplicant[506]: wlan0: CTRL-EVENT-TERMINATING
Feb 19 13:21:55 pureos systemd[1]: wpa_supplicant.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped WPA supplicant.
Feb 19 13:21:55 pureos systemd[1]: polkit.service: Main process exited, code=killed, status=15/TERM
Feb 19 13:21:55 pureos systemd[1]: polkit.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Authorization Manager.
Feb 19 13:21:55 pureos kernel: [drm] Connector status: 0
Feb 19 13:21:55 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 1.
Feb 19 13:21:55 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
Feb 19 13:21:55 pureos systemd[1]: NetworkManager.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Network Manager.
Feb 19 13:21:55 pureos systemd[1]: systemd-logind.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Login Service.
Feb 19 13:21:55 pureos systemd[1]: Stopped target User and Group Name Lookups.
Feb 19 13:21:55 pureos systemd[1]: Stopping D-Bus System Message Bus...
Feb 19 13:21:55 pureos systemd[1]: dbus.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped D-Bus System Message Bus.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Basic System.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Sockets.
Feb 19 13:21:55 pureos systemd[1]: systemd-ask-password-plymouth.path: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Slices.
Feb 19 13:21:55 pureos systemd[1]: Removed slice User and Session Slice.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Paths.
Feb 19 13:21:55 pureos systemd[1]: dbus.socket: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Closed D-Bus System Message Bus Socket.
Feb 19 13:21:55 pureos systemd[1]: Stopped target System Initialization.
Feb 19 13:21:55 pureos systemd[1]: systemd-sysctl.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Apply Kernel Variables.
Feb 19 13:21:55 pureos systemd[1]: systemd-modules-load.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Load Kernel Modules.
Feb 19 13:21:55 pureos systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Feb 19 13:21:55 pureos systemd[1]: Stopping Load/Save Random Seed...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Local Encrypted Volumes.
Feb 19 13:21:55 pureos systemd[1]: systemd-ask-password-wall.path: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Swap.
Feb 19 13:21:55 pureos systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:backlight-dsi...
Feb 19 13:21:55 pureos systemd[1]: Stopping Network Time Synchronization...
Feb 19 13:21:55 pureos systemd[1]: systemd-timesyncd.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Network Time Synchronization.
Feb 19 13:21:55 pureos systemd[1]: systemd-random-seed.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Load/Save Random Seed.
Feb 19 13:21:55 pureos systemd[1]: systemd-backlight@backlight:backlight-dsi.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:backlight-dsi.
Feb 19 13:21:55 pureos systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
Feb 19 13:21:55 pureos systemd[1]: systemd-update-utmp.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Feb 19 13:21:55 pureos systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Create Volatile Files and Directories.
Feb 19 13:21:55 pureos systemd[1]: Stopped target Local File Systems.
Feb 19 13:21:55 pureos systemd[1]: Unmounting /boot...
Feb 19 13:21:55 pureos systemd[1]: Unmounting /media/purism/3032-6534...
Feb 19 13:21:55 pureos systemd[1]: boot.mount: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Unmounted /boot.
Feb 19 13:21:55 pureos systemd[1]: systemd-fsck@dev-disk-by\x2duuid-5687b3c9\x2dc5ee\x2d4ea8\x2da8a7\x2d019b158c3ef0.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped File System Check on /dev/disk/by-uuid/5687b3c9-c5ee-4ea8-a8a7-019b158c3ef0.
Feb 19 13:21:55 pureos systemd[1]: Removed slice system-systemd\x2dfsck.slice.
Feb 19 13:21:55 pureos systemd[1]: media-purism-3032\x2d6534.mount: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Unmounted /media/purism/3032-6534.
Feb 19 13:21:55 pureos systemd[1]: Reached target Unmount All Filesystems.
Feb 19 13:21:55 pureos systemd[1]: Stopping Clean the /media/purism/3032-6534 mount point...
Feb 19 13:21:55 pureos systemd[1]: Stopped target Local File Systems (Pre).
Feb 19 13:21:55 pureos systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Feb 19 13:21:55 pureos systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Create Static Device Nodes in /dev.
Feb 19 13:21:55 pureos systemd[1]: systemd-sysusers.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Create System Users.
Feb 19 13:21:55 pureos systemd[1]: systemd-remount-fs.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Remount Root and Kernel File Systems.
Feb 19 13:21:55 pureos systemd[1]: systemd-fsck-root.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped File System Check on Root Device.
Feb 19 13:21:55 pureos systemd[1]: clean-mount-point@media-purism-3032\x2d6534.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Stopped Clean the /media/purism/3032-6534 mount point.
Feb 19 13:21:55 pureos systemd[1]: Removed slice system-clean\x2dmount\x2dpoint.slice.
Feb 19 13:21:55 pureos systemd[1]: Reached target Shutdown.
Feb 19 13:21:55 pureos systemd[1]: Reached target Final Step.
Feb 19 13:21:55 pureos systemd[1]: systemd-poweroff.service: Succeeded.
Feb 19 13:21:55 pureos systemd[1]: Started Power-Off.
Feb 19 13:21:55 pureos systemd[1]: Reached target Power-Off.
Feb 19 13:21:55 pureos systemd[1]: Shutting down.
Feb 19 13:21:55 pureos kernel: printk: systemd-shutdow: 36 output lines suppressed due to ratelimiting
Feb 19 13:21:55 pureos systemd-shutdown[1]: Syncing filesystems and block devices.
Feb 19 13:21:55 pureos systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Feb 19 13:21:55 pureos systemd-journald[341]: Journal stopped
I’d better do not comment it, as i cannot see the hanging process from it.
If you think it is a local issue, i’m willing to try any test that you suggest.
Not sure. I’ve always seen regular shutdowns in the logs after holding the power key.
How did you shut down before taking this log? Are you sure that the log comes from a long shut down?
Can you try journalctl --user?
No, i did a reboot over ssh.
Following the snippet from the log that i think you want to see. Before, i pressed the reboot button on the phone’s status bar. More completely the console on the phone showed “A stop job is running for User Manager for UID 0” for two minutes.
-- Logs begin at Mon 2021-02-22 15:58:45 CET, end at Mon 2021-02-22 16:09:39 CET. --
Feb 22 15:58:45 pureos systemd[665]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
Feb 22 15:58:45 pureos systemd[665]: pulseaudio.service: Failed with result 'exit-code'.
Feb 22 15:58:45 pureos systemd[665]: pulseaudio.service: Service RestartSec=100ms expired, scheduling restart.
Feb 22 15:58:45 pureos systemd[665]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
Feb 22 15:58:45 pureos systemd[665]: Stopping Wys, a daemon for voice call audio...
Feb 22 15:58:45 pureos systemd[665]: Stopped Sound Service.
Feb 22 15:58:45 pureos systemd[665]: Starting Sound Service...
Feb 22 15:58:45 pureos systemd[665]: wys.service: Succeeded.
Feb 22 15:58:45 pureos systemd[665]: Stopped Wys, a daemon for voice call audio.
Feb 22 15:58:46 pureos systemd[665]: Started Wys, a daemon for voice call audio.
Feb 22 15:58:46 pureos pulseaudio[1569]: W: [pulseaudio] pid.c: Stale PID file, overwriting.
Feb 22 15:58:47 pureos systemd[665]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Feb 22 15:58:47 pureos systemd[665]: Stopping Virtual filesystem service - digital camera monitor...
Feb 22 15:58:47 pureos systemd[665]: Stopping Virtual filesystem service...
Feb 22 15:58:47 pureos systemd[665]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Feb 22 15:58:47 pureos systemd[665]: Stopping D-Bus User Message Bus...
Feb 22 15:58:47 pureos gthd[686]: Could not acquire the 'org.sigxcpu.Thermal' service name
Feb 22 15:58:47 pureos systemd[665]: Stopping Evolution address book service...
Feb 22 15:58:47 pureos systemd[665]: Stopping Evolution calendar service...
Feb 22 15:58:47 pureos systemd[665]: Stopping Virtual filesystem service - disk device monitor...
Feb 22 15:58:47 pureos systemd[665]: Stopping Virtual filesystem service - GNOME Online Accounts monitor...
Feb 22 15:58:47 pureos systemd[665]: Stopped target Default.
Feb 22 15:58:47 pureos systemd[665]: Stopping Gthd Service...
Feb 22 15:58:47 pureos systemd[665]: Stopping Wys, a daemon for voice call audio...
Feb 22 15:58:47 pureos systemd[665]: Stopping Evolution source registry...
Feb 22 15:58:47 pureos systemd[665]: gvfs-daemon.service: Main process exited, code=killed, status=15/TERM
Feb 22 15:58:47 pureos systemd[665]: gvfs-daemon.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Virtual filesystem service.
Feb 22 15:58:47 pureos systemd[665]: gvfs-udisks2-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 15:58:47 pureos systemd[665]: gvfs-udisks2-volume-monitor.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Virtual filesystem service - disk device monitor.
Feb 22 15:58:47 pureos systemd[665]: gthd.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Gthd Service.
Feb 22 15:58:47 pureos systemd[665]: gvfs-afc-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 15:58:47 pureos systemd[665]: gvfs-afc-volume-monitor.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Feb 22 15:58:47 pureos systemd[665]: gvfs-gphoto2-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 15:58:47 pureos systemd[665]: gvfs-gphoto2-volume-monitor.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Virtual filesystem service - digital camera monitor.
Feb 22 15:58:47 pureos systemd[665]: gvfs-goa-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 15:58:47 pureos systemd[665]: gvfs-goa-volume-monitor.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Virtual filesystem service - GNOME Online Accounts monitor.
Feb 22 15:58:47 pureos systemd[665]: gvfs-mtp-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 15:58:47 pureos systemd[665]: gvfs-mtp-volume-monitor.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Feb 22 15:58:47 pureos systemd[665]: evolution-source-registry.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Evolution source registry.
Feb 22 15:58:47 pureos systemd[665]: evolution-addressbook-factory.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Evolution address book service.
Feb 22 15:58:47 pureos systemd[665]: evolution-calendar-factory.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped Evolution calendar service.
Feb 22 15:58:47 pureos systemd[665]: dbus.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Stopped D-Bus User Message Bus.
Feb 22 15:58:47 pureos pulseaudio[1569]: E: [pulseaudio] main.c: Failed to acquire org.PulseAudio1: org.freedesktop.DBus.Error.Disconnected: Connection is closed
Feb 22 15:58:47 pureos systemd[665]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
Feb 22 15:58:47 pureos systemd[665]: pulseaudio.service: Failed with result 'exit-code'.
Feb 22 15:58:47 pureos systemd[665]: Stopped Sound Service.
Feb 22 15:58:47 pureos wys[1570]: Error in PulseAudio context: Connection terminated
Feb 22 15:58:47 pureos systemd[665]: wys.service: Main process exited, code=exited, status=1/FAILURE
Feb 22 15:58:47 pureos systemd[665]: wys.service: Failed with result 'exit-code'.
Feb 22 15:58:47 pureos systemd[665]: Stopped Wys, a daemon for voice call audio.
Feb 22 15:58:47 pureos systemd[665]: Stopped target Basic System.
Feb 22 15:58:47 pureos systemd[665]: Stopped target Paths.
Feb 22 15:58:47 pureos systemd[665]: Stopped target Timers.
Feb 22 15:58:47 pureos systemd[665]: Stopped target Sockets.
Feb 22 15:58:47 pureos systemd[665]: gpg-agent.socket: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Closed GnuPG cryptographic agent and passphrase cache.
Feb 22 15:58:47 pureos systemd[665]: gpg-agent-browser.socket: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Feb 22 15:58:47 pureos systemd[665]: dbus.socket: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Closed D-Bus User Message Bus Socket.
Feb 22 15:58:47 pureos systemd[665]: gpg-agent-extra.socket: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Feb 22 15:58:47 pureos systemd[665]: dirmngr.socket: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Closed GnuPG network certificate management daemon.
Feb 22 15:58:47 pureos systemd[665]: gpg-agent-ssh.socket: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Feb 22 15:58:47 pureos systemd[665]: pulseaudio.socket: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Closed Sound System.
Feb 22 15:58:47 pureos systemd[665]: Reached target Shutdown.
Feb 22 15:58:47 pureos systemd[665]: systemd-exit.service: Succeeded.
Feb 22 15:58:47 pureos systemd[665]: Started Exit the Session.
Feb 22 15:58:47 pureos systemd[665]: Reached target Exit the Session.
Feb 22 15:58:47 pureos systemd[667]: pam_unix(systemd-user:session): session closed for user purism
-- Reboot --
Hmm, looks for me like a pulseaudio restart is attempted during reboot…
who here believes that long-pressing the power-OFF button (for three seconds) should bring up the terminal with the command ? :
sudo shutdown --poweroff now
the problem with that is that it DOES requires the current user to KNOW the root password or have some sort of WHEEL to do that …
for more information do :
info shutdown
OR in the case of a restart/reboot it should be a long press (for two seconds), or a list drop-down of GUI-text-options for the shutdown command. then :
sudo shutdown -r now
Okay, that log indicates PulseAudio crashing, but doesn’t show anything certain yet. The biggest issue is that it only covers about 3 seconds, and so it doesn’t include the moment of shutdown.
What’s interesting are full logs, from shutdown request to boot (so more than 2 minutes), of both of those:
journalctl from a 2-minute shutdown (that will print out the culprit)journalctl --user from a 2-minute shutdown (may or may not help)Hope this one is more conclusive. Again, reboot is triggered from the power menu in the status bar. I think the snippet starts with the short power press i did to get to the display.
Feb 22 17:02:15 pureos systemd-logind[531]: Power key pressed.
Feb 22 17:02:15 pureos phoc[594]: [backend/drm/drm.c:972] Skipping pageflip on output 'DSI-1'
Feb 22 17:02:15 pureos gsd-color[849]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
Feb 22 17:02:22 pureos calls[961]: gtk_application_uninhibit: assertion 'cookie > 0' failed
Feb 22 17:02:23 pureos systemd[1]: Stopping User Manager for UID 0...
Feb 22 17:02:23 pureos systemd[1223]: Stopped target Default.
Feb 22 17:02:23 pureos gthd[1238]: Could not acquire the 'org.sigxcpu.Thermal' service name
Feb 22 17:02:23 pureos systemd[1223]: Stopping D-Bus User Message Bus...
Feb 22 17:02:23 pureos systemd[1223]: Stopping Gthd Service...
Feb 22 17:02:23 pureos systemd[1223]: Stopping Wys, a daemon for voice call audio...
Feb 22 17:02:23 pureos systemd[1223]: gthd.service: Succeeded.
Feb 22 17:02:23 pureos systemd[1223]: Stopped Gthd Service.
Feb 22 17:02:23 pureos systemd[1223]: dbus.service: Succeeded.
Feb 22 17:02:23 pureos systemd[1223]: Stopped D-Bus User Message Bus.
Feb 22 17:02:50 pureos gnome-session[694]: gnome-session-binary[694]: WARNING: Unable to open shell end session dialog: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.gnome.SessionManager.EndSessionDialog” on object at path /org/gnome/SessionManager/EndSessionDialog
Feb 22 17:02:50 pureos gnome-session-binary[694]: WARNING: Unable to open shell end session dialog: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.gnome.SessionManager.EndSessionDialog” on object at path /org/gnome/SessionManager/EndSessionDialog
Feb 22 17:02:50 pureos gnome-session-binary[694]: Entering running state
Feb 22 17:02:50 pureos phosh[739]: Failed to reboot: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._g_2dio_2derror_2dquark.Code19: Operation was cancelled
Feb 22 17:02:50 pureos gnome-session[694]: **
Feb 22 17:02:50 pureos gnome-session[694]: ERROR:../gnome-session/gsm-manager.c:3673:on_shutdown_prepared: assertion failed: (manager->priv->phase == GSM_MANAGER_PHASE_QUERY_END_SESSION)
Feb 22 17:02:50 pureos pulseaudio[626]: ICE default IO error handler doing an exit(), pid = 626, errno = 11
Feb 22 17:02:50 pureos systemd-logind[531]: System is rebooting.
Feb 22 17:02:50 pureos kernel: rfkill: input handler enabled
Feb 22 17:02:50 pureos phosh[594]: Aborted
Feb 22 17:02:50 pureos systemd[610]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
Feb 22 17:02:50 pureos phosh[594]: (EE) failed to read Wayland events: Broken pipe
Feb 22 17:02:50 pureos bluetoothd[659]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc
Feb 22 17:02:50 pureos systemd[610]: pulseaudio.service: Failed with result 'exit-code'.
Feb 22 17:02:50 pureos bluetoothd[659]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc
Feb 22 17:02:50 pureos phosh[739]: Error flushing display: Broken pipe
Feb 22 17:02:50 pureos gnome-clocks[959]: Lost connection to Wayland compositor.
Feb 22 17:02:50 pureos calls[961]: Error reading events from display: Broken pipe
Feb 22 17:02:50 pureos squeekboard[938]: Error reading events from display: Broken pipe
Feb 22 17:02:50 pureos chatty[963]: Error reading events from display: Broken pipe
Feb 22 17:02:50 pureos evolution-alarm[962]: Error reading events from display: Broken pipe
Feb 22 17:02:50 pureos systemd[1]: Stopping Availability of block devices...
Feb 22 17:02:50 pureos systemd[1]: Stopped target Bluetooth.
Feb 22 17:02:50 pureos systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Feb 22 17:02:50 pureos systemd[1]: Stopping Location Lookup Service...
Feb 22 17:02:50 pureos systemd[1]: Stopping Session 1 of user purism.
Feb 22 17:02:50 pureos systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Closed LVM2 poll daemon socket.
Feb 22 17:02:50 pureos systemd[1]: Stopped target Graphical Interface.
Feb 22 17:02:50 pureos systemd[1]: Stopped target Multi-User System.
Feb 22 17:02:50 pureos ModemManager[570]: <info> caught signal, shutting down...
Feb 22 17:02:50 pureos systemd[1]: Stopping Modem Manager...
Feb 22 17:02:50 pureos ModemManager[570]: Cannot read from istream: connection broken
Feb 22 17:02:50 pureos systemd[1]: Stopping OpenBSD Secure Shell server...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] QMI endpoint hangup: removed
Feb 22 17:02:50 pureos systemd[1]: Stopping Phosh, a shell for mobile phones...
Feb 22 17:02:50 pureos ModemManager[570]: <info> [modem1] connection to qmi-proxy for /dev/cdc-wdm0 lost, reprobing
Feb 22 17:02:50 pureos systemd[1]: Stopping Regular background program processing daemon...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Releasing 'voice' client with flags 'release-cid'...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Unregistered 'voice' client with ID '1'
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Releasing 'pdc' client with flags 'release-cid'...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Unregistered 'pdc' client with ID '1'
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Releasing 'loc' client with flags 'release-cid'...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Unregistered 'loc' client with ID '1'
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Releasing 'uim' client with flags 'release-cid'...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Unregistered 'uim' client with ID '1'
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Releasing 'wms' client with flags 'release-cid'...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Unregistered 'wms' client with ID '1'
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Releasing 'nas' client with flags 'release-cid'...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Unregistered 'nas' client with ID '1'
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Releasing 'dms' client with flags 'release-cid'...
Feb 22 17:02:50 pureos ModemManager[570]: [/dev/cdc-wdm0] Unregistered 'dms' client with ID '1'
Feb 22 17:02:50 pureos sshd[587]: Received signal 15; terminating.
Feb 22 17:02:50 pureos bluetoothd[659]: Terminating
Feb 22 17:02:50 pureos systemd[1]: Stopping Disk Manager...
Feb 22 17:02:50 pureos systemd[1]: Stopping Bluetooth service...
Feb 22 17:02:50 pureos systemd[1]: Stopped target Sound Card.
Feb 22 17:02:50 pureos systemd[1]: Stopped target Host and Network Name Lookups.
Feb 22 17:02:50 pureos systemd[1]: systemd-rfkill.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 22 17:02:50 pureos systemd[1]: Stopping Accounts Service...
Feb 22 17:02:50 pureos kernel: redpine_91x: RSI `hci0' flush
Feb 22 17:02:50 pureos kernel: redpine_91x: RSI HCI DEVICE "hci0" closed
Feb 22 17:02:50 pureos kernel: redpine_91x: rsi_hci_close: device `hci0' not running
Feb 22 17:02:50 pureos systemd[1]: Stopping Daemon for power management...
Feb 22 17:02:50 pureos systemd[1]: Stopping IIO Sensor Proxy service...
Feb 22 17:02:50 pureos systemd[1]: Stopped target Login Prompts.
Feb 22 17:02:50 pureos systemd[1]: Stopping Getty on tty1...
Feb 22 17:02:50 pureos systemd[1]: Stopping Serial Getty on ttymxc0...
Feb 22 17:02:50 pureos systemd[1]: Stopped target Timers.
Feb 22 17:02:50 pureos systemd[1]: man-db.timer: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Daily man-db regeneration.
Feb 22 17:02:50 pureos systemd[1]: apt-daily-upgrade.timer: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Daily apt upgrade and clean activities.
Feb 22 17:02:50 pureos systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Feb 22 17:02:50 pureos systemd[1]: apt-daily.timer: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Daily apt download activities.
Feb 22 17:02:50 pureos systemd[1]: logrotate.timer: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Daily rotation of log files.
Feb 22 17:02:50 pureos systemd[1]: Stopped target System Time Synchronized.
Feb 22 17:02:50 pureos systemd[1]: Stopping Serial Getty on ttyGS0...
Feb 22 17:02:50 pureos udisksd[549]: udisks daemon version 2.8.1 exiting
Feb 22 17:02:50 pureos systemd[1]: accounts-daemon.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Accounts Service.
Feb 22 17:02:50 pureos systemd[1]: cron.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: cron.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Regular background program processing daemon.
Feb 22 17:02:50 pureos systemd[1]: udisks2.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Disk Manager.
Feb 22 17:02:50 pureos bluetoothd[659]: Stopping SDP server
Feb 22 17:02:50 pureos bluetoothd[659]: Exit
Feb 22 17:02:50 pureos systemd[1]: ssh.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped OpenBSD Secure Shell server.
Feb 22 17:02:50 pureos blkdeactivate[1280]: Deactivating block devices:
Feb 22 17:02:50 pureos systemd[1]: getty@tty1.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: getty@tty1.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Getty on tty1.
Feb 22 17:02:50 pureos NetworkManager[552]: <info> [1614009770.3920] bluez5: NAP: removed interface 88:DA:1A:B6:5D:90
Feb 22 17:02:50 pureos systemd[1]: serial-getty@ttymxc0.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: serial-getty@ttymxc0.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Serial Getty on ttymxc0.
Feb 22 17:02:50 pureos systemd[1]: serial-getty@ttyGS0.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: serial-getty@ttyGS0.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Serial Getty on ttyGS0.
Feb 22 17:02:50 pureos systemd[1]: colord.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: colord.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Feb 22 17:02:50 pureos systemd[1]: iio-sensor-proxy.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: iio-sensor-proxy.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped IIO Sensor Proxy service.
Feb 22 17:02:50 pureos systemd[1]: geoclue.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: geoclue.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Location Lookup Service.
Feb 22 17:02:50 pureos systemd[1]: Removed slice system-serial\x2dgetty.slice.
Feb 22 17:02:50 pureos systemd[1]: Starting Show Plymouth Reboot Screen...
Feb 22 17:02:50 pureos systemd[1]: Removed slice system-getty.slice.
Feb 22 17:02:50 pureos polkitd(authority=local)[537]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.57, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C.UTF-8) (disconnected from bus)
Feb 22 17:02:50 pureos systemd[1]: Received SIGRTMIN+20 from PID 1294 (plymouthd).
Feb 22 17:02:50 pureos systemd[1]: bluetooth.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Bluetooth service.
Feb 22 17:02:50 pureos systemd[1]: upower.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: upower.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Daemon for power management.
Feb 22 17:02:50 pureos systemd[1]: blk-availability.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Availability of block devices.
Feb 22 17:02:50 pureos NetworkManager[552]: <info> [1614009770.5261] modem-manager: ModemManager no longer available
Feb 22 17:02:50 pureos NetworkManager[552]: <info> [1614009770.5263] device (cdc-wdm0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Feb 22 17:02:50 pureos ModemManager[570]: <info> ModemManager is shut down
Feb 22 17:02:50 pureos systemd[1]: phosh.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[1]: phosh.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Phosh, a shell for mobile phones.
Feb 22 17:02:50 pureos systemd[1]: ModemManager.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Modem Manager.
Feb 22 17:02:50 pureos systemd[1]: Stopping Authorization Manager...
Feb 22 17:02:50 pureos systemd[1]: session-1.scope: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Session 1 of user purism.
Feb 22 17:02:50 pureos systemd[1]: Stopping User Manager for UID 1000...
Feb 22 17:02:50 pureos systemd[1]: Stopping Login Service...
Feb 22 17:02:50 pureos systemd[610]: pulseaudio.service: Service RestartSec=100ms expired, scheduling restart.
Feb 22 17:02:50 pureos systemd[610]: pulseaudio.service: Stop job pending for unit, delaying automatic restart.
Feb 22 17:02:50 pureos systemd[610]: Stopping Evolution address book service...
Feb 22 17:02:50 pureos systemd[610]: Stopping Virtual filesystem service - disk device monitor...
Feb 22 17:02:50 pureos systemd[610]: Stopped target Default.
Feb 22 17:02:50 pureos gthd[627]: Could not acquire the 'org.sigxcpu.Thermal' service name
Feb 22 17:02:50 pureos gvfsd[750]: A connection to the bus can't be made
Feb 22 17:02:50 pureos systemd[610]: Stopping D-Bus User Message Bus...
Feb 22 17:02:50 pureos systemd[610]: Stopping Evolution source registry...
Feb 22 17:02:50 pureos systemd[1]: polkit.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[610]: Stopping Virtual filesystem service - GNOME Online Accounts monitor...
Feb 22 17:02:50 pureos systemd[610]: Stopping Virtual filesystem service...
Feb 22 17:02:50 pureos systemd[610]: Stopped Sound Service.
Feb 22 17:02:50 pureos systemd[1]: polkit.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Authorization Manager.
Feb 22 17:02:50 pureos systemd[610]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Feb 22 17:02:50 pureos wys[624]: Wys started with modem `MODEM'
Feb 22 17:02:50 pureos systemd[610]: Stopping Wys, a daemon for voice call audio...
Feb 22 17:02:50 pureos systemd[610]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Feb 22 17:02:50 pureos systemd[610]: Stopping Virtual filesystem service - digital camera monitor...
Feb 22 17:02:50 pureos systemd[610]: Stopping Evolution calendar service...
Feb 22 17:02:50 pureos systemd[610]: Stopping Gthd Service...
Feb 22 17:02:50 pureos systemd[610]: gthd.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Gthd Service.
Feb 22 17:02:50 pureos systemd[610]: wys.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Wys, a daemon for voice call audio.
Feb 22 17:02:50 pureos systemd[610]: gvfs-daemon.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[610]: gvfs-daemon.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Virtual filesystem service.
Feb 22 17:02:50 pureos systemd[610]: gvfs-udisks2-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[610]: gvfs-udisks2-volume-monitor.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Virtual filesystem service - disk device monitor.
Feb 22 17:02:50 pureos systemd[610]: gvfs-afc-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[610]: gvfs-afc-volume-monitor.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Feb 22 17:02:50 pureos systemd[610]: gvfs-gphoto2-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd-logind[531]: Session 1 logged out. Waiting for processes to exit.
Feb 22 17:02:50 pureos systemd[610]: gvfs-gphoto2-volume-monitor.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Virtual filesystem service - digital camera monitor.
Feb 22 17:02:50 pureos systemd[610]: gvfs-goa-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[610]: gvfs-goa-volume-monitor.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Virtual filesystem service - GNOME Online Accounts monitor.
Feb 22 17:02:50 pureos systemd[610]: gvfs-mtp-volume-monitor.service: Main process exited, code=killed, status=15/TERM
Feb 22 17:02:50 pureos systemd[610]: gvfs-mtp-volume-monitor.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Feb 22 17:02:50 pureos systemd[610]: evolution-source-registry.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Evolution source registry.
Feb 22 17:02:50 pureos systemd[610]: evolution-addressbook-factory.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Evolution address book service.
Feb 22 17:02:50 pureos systemd[610]: evolution-calendar-factory.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped Evolution calendar service.
Feb 22 17:02:50 pureos systemd[610]: dbus.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Stopped D-Bus User Message Bus.
Feb 22 17:02:50 pureos systemd[610]: Stopped target Basic System.
Feb 22 17:02:50 pureos systemd[610]: Stopped target Timers.
Feb 22 17:02:50 pureos systemd[610]: Stopped target Sockets.
Feb 22 17:02:50 pureos systemd[610]: gpg-agent-ssh.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Feb 22 17:02:50 pureos systemd[610]: dirmngr.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Closed GnuPG network certificate management daemon.
Feb 22 17:02:50 pureos systemd[610]: gpg-agent-extra.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Feb 22 17:02:50 pureos systemd[610]: gpg-agent.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Closed GnuPG cryptographic agent and passphrase cache.
Feb 22 17:02:50 pureos systemd[610]: pulseaudio.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Closed Sound System.
Feb 22 17:02:50 pureos systemd[610]: gpg-agent-browser.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Feb 22 17:02:50 pureos systemd[610]: Stopped target Paths.
Feb 22 17:02:50 pureos systemd[610]: dbus.socket: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Closed D-Bus User Message Bus Socket.
Feb 22 17:02:50 pureos systemd[610]: Reached target Shutdown.
Feb 22 17:02:50 pureos systemd[610]: systemd-exit.service: Succeeded.
Feb 22 17:02:50 pureos systemd[610]: Started Exit the Session.
Feb 22 17:02:50 pureos systemd[610]: Reached target Exit the Session.
Feb 22 17:02:50 pureos systemd[611]: pam_unix(systemd-user:session): session closed for user purism
Feb 22 17:02:50 pureos systemd[1]: systemd-logind.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped Login Service.
Feb 22 17:02:50 pureos systemd[1]: user@1000.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped User Manager for UID 1000.
Feb 22 17:02:50 pureos systemd[1]: Started Show Plymouth Reboot Screen.
Feb 22 17:02:50 pureos systemd[1]: Stopping User Runtime Directory /run/user/1000...
Feb 22 17:02:50 pureos systemd[1223]: run-user-1000.mount: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: run-user-1000.mount: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Unmounted /run/user/1000.
Feb 22 17:02:50 pureos systemd[1]: user-runtime-dir@1000.service: Succeeded.
Feb 22 17:02:50 pureos systemd[1]: Stopped User Runtime Directory /run/user/1000.
Feb 22 17:02:50 pureos systemd[1]: Removed slice User Slice of UID 1000.
Feb 22 17:02:55 pureos kernel: [drm] Connector status: 0
Feb 22 17:03:14 pureos dhclient[1020]: DHCPREQUEST for 192.168.0.129 on wlan0 to 192.168.0.20 port 67
Feb 22 17:03:14 pureos dhclient[1020]: DHCPACK of 192.168.0.129 from 192.168.0.20
Feb 22 17:03:14 pureos NetworkManager[552]: <info> [1614009794.8879] dhcp4 (wlan0): address 192.168.0.129
Feb 22 17:03:14 pureos NetworkManager[552]: <info> [1614009794.8881] dhcp4 (wlan0): plen 16 (255.255.0.0)
Feb 22 17:03:14 pureos NetworkManager[552]: <info> [1614009794.8881] dhcp4 (wlan0): gateway 192.168.0.1
Feb 22 17:03:14 pureos NetworkManager[552]: <info> [1614009794.8882] dhcp4 (wlan0): lease time 600
Feb 22 17:03:14 pureos NetworkManager[552]: <info> [1614009794.8882] dhcp4 (wlan0): nameserver '192.168.0.20'
Feb 22 17:03:14 pureos NetworkManager[552]: <info> [1614009794.8882] dhcp4 (wlan0): domain name 'localnet'
Feb 22 17:03:14 pureos NetworkManager[552]: <info> [1614009794.8883] dhcp4 (wlan0): state changed bound -> bound
Feb 22 17:03:14 pureos dbus-daemon[551]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=552 comm="/usr/sbin/NetworkManager --no-daemon ")
Feb 22 17:03:14 pureos dbus-daemon[551]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Feb 22 17:03:14 pureos dhclient[1020]: bound to 192.168.0.129 -- renewal in 229 seconds.
Feb 22 17:03:30 pureos wpa_supplicant[561]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-24 noise=9999 txrate=1000
Feb 22 17:03:53 pureos systemd[1223]: wys.service: State 'stop-sigterm' timed out. Killing.
Feb 22 17:03:53 pureos systemd[1223]: wys.service: Killing process 1239 (wys) with signal SIGKILL.
Feb 22 17:03:53 pureos systemd[1223]: wys.service: Main process exited, code=killed, status=9/KILL
Feb 22 17:03:53 pureos systemd[1223]: wys.service: Failed with result 'timeout'.
Feb 22 17:03:53 pureos systemd[1223]: Stopped Wys, a daemon for voice call audio.
Feb 22 17:03:53 pureos systemd[1223]: Stopped target Basic System.
Feb 22 17:03:53 pureos systemd[1223]: Stopped target Paths.
Feb 22 17:03:53 pureos systemd[1223]: Stopped target Timers.
Feb 22 17:03:53 pureos systemd[1223]: Stopped target Sockets.
Feb 22 17:03:53 pureos systemd[1223]: gpg-agent-browser.socket: Succeeded.
Feb 22 17:03:53 pureos systemd[1223]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Feb 22 17:03:53 pureos systemd[1223]: dbus.socket: Succeeded.
Feb 22 17:03:53 pureos systemd[1223]: Closed D-Bus User Message Bus Socket.
Feb 22 17:03:53 pureos systemd[1223]: gpg-agent.socket: Succeeded.
Feb 22 17:03:53 pureos systemd[1223]: Closed GnuPG cryptographic agent and passphrase cache.
Feb 22 17:03:53 pureos systemd[1223]: dirmngr.socket: Succeeded.
Feb 22 17:03:53 pureos systemd[1223]: Closed GnuPG network certificate management daemon.
Feb 22 17:03:53 pureos systemd[1223]: gpg-agent-ssh.socket: Succeeded.
Feb 22 17:03:53 pureos systemd[1223]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Feb 22 17:03:53 pureos systemd[1223]: gpg-agent-extra.socket: Succeeded.
Feb 22 17:03:53 pureos systemd[1223]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Feb 22 17:03:53 pureos systemd[1223]: Reached target Shutdown.
Feb 22 17:03:53 pureos systemd[1223]: systemd-exit.service: Succeeded.
Feb 22 17:03:53 pureos systemd[1223]: Started Exit the Session.
Feb 22 17:03:53 pureos systemd[1223]: Reached target Exit the Session.
Feb 22 17:03:53 pureos systemd[1224]: pam_unix(systemd-user:session): session closed for user root
Feb 22 17:03:53 pureos systemd[1]: user@0.service: Succeeded.
Feb 22 17:03:53 pureos systemd[1]: Stopped User Manager for UID 0.
Feb 22 17:03:53 pureos systemd[1]: Stopping User Runtime Directory /run/user/0...
Feb 22 17:03:53 pureos systemd[1]: run-user-0.mount: Succeeded.
Feb 22 17:03:53 pureos systemd[1]: Unmounted /run/user/0.
Feb 22 17:03:53 pureos systemd[1]: user-runtime-dir@0.service: Succeeded.
Feb 22 17:03:53 pureos systemd[1]: Stopped User Runtime Directory /run/user/0.
Feb 22 17:03:53 pureos systemd[1]: Removed slice User Slice of UID 0.
Feb 22 17:03:53 pureos systemd[1]: Stopping Permit User Sessions...
Feb 22 17:03:53 pureos systemd[1]: systemd-user-sessions.service: Succeeded.
Feb 22 17:03:53 pureos systemd[1]: Stopped Permit User Sessions.
Feb 22 17:03:53 pureos systemd[1]: Stopped target Remote File Systems.
Feb 22 17:03:53 pureos systemd[1]: Stopped target Network.
Feb 22 17:03:53 pureos systemd[1]: Stopping WPA supplicant...
Feb 22 17:03:53 pureos kernel: [drm] Connector status: 0
Feb 22 17:03:53 pureos kernel: wlan0: deauthenticating from e4:95:6e:40:dd:94 by local choice (Reason: 3=DEAUTH_LEAVING)
Feb 22 17:03:53 pureos kernel: redpine_91x: rsi_mac80211_set_key: RSI del key
Feb 22 17:03:53 pureos kernel: redpine_91x: rsi_hal_key_config: Cipher 0x0 key_type: 2 key_len: 0
Feb 22 17:03:53 pureos systemd[1]: Stopping Network Name Resolution...
Feb 22 17:03:53 pureos wpa_supplicant[561]: wlan0: CTRL-EVENT-DISCONNECTED bssid=e4:95:6e:40:dd:94 reason=3 locally_generated=1
Feb 22 17:03:53 pureos systemd[1]: Stopping Network Manager...
Feb 22 17:03:53 pureos wpa_supplicant[561]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/1
Feb 22 17:03:53 pureos NetworkManager[552]: <info> [1614009833.9544] caught SIGTERM, shutting down normally.
Feb 22 17:03:53 pureos systemd[1]: Stopping Raise network interfaces...
Feb 22 17:03:53 pureos systemd-networkd[305]: wlan0: Lost carrier
Feb 22 17:03:53 pureos systemd[1]: Stopped target User and Group Name Lookups.
Feb 22 17:03:53 pureos systemd-timesyncd[522]: No network connectivity, watching for changes.
Feb 22 17:03:53 pureos systemd[1]: networking.service: Succeeded.
Feb 22 17:03:53 pureos systemd[1]: Stopped Raise network interfaces.
Feb 22 17:03:53 pureos systemd[1]: systemd-resolved.service: Succeeded.
Feb 22 17:03:53 pureos systemd[1]: Stopped Network Name Resolution.
Feb 22 17:03:53 pureos NetworkManager[552]: <info> [1614009833.9993] dhcp4 (wlan0): canceled DHCP transaction, DHCP client pid 1020
Feb 22 17:03:53 pureos NetworkManager[552]: <info> [1614009833.9994] dhcp4 (wlan0): state changed bound -> done
Feb 22 17:03:53 pureos NetworkManager[552]: <info> [1614009833.9995] device (wlan0): DHCPv4: 480 seconds grace period started
Feb 22 17:03:53 pureos systemd[1]: Stopping Network Service...
Feb 22 17:03:54 pureos NetworkManager[552]: <info> [1614009834.0039] dhcp6 (wlan0): canceled DHCP transaction, DHCP client pid 1090
Feb 22 17:03:54 pureos NetworkManager[552]: <info> [1614009834.0040] dhcp6 (wlan0): state changed bound -> done
Feb 22 17:03:54 pureos NetworkManager[552]: <info> [1614009834.0042] device (wlan0): DHCPv6: 480 seconds grace period started
Feb 22 17:03:54 pureos systemd[1]: systemd-networkd.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Network Service.
Feb 22 17:03:54 pureos NetworkManager[552]: <info> [1614009834.0099] exiting (success)
Feb 22 17:03:54 pureos wpa_supplicant[561]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Feb 22 17:03:54 pureos systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-networkd.service/start is destructive (reboot.target has 'start' job queued, but 'stop' is included in transaction).
Feb 22 17:03:54 pureos systemd[1]: systemd-networkd.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-networkd.service/start is destructive (reboot.target has 'start' job queued, but 'stop' is included in transaction).
Feb 22 17:03:54 pureos wpa_supplicant[561]: wlan0: CTRL-EVENT-TERMINATING
Feb 22 17:03:54 pureos systemd[1]: systemd-networkd.socket: Failed with result 'resources'.
Feb 22 17:03:54 pureos systemd[1]: wpa_supplicant.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped WPA supplicant.
Feb 22 17:03:54 pureos systemd[1]: NetworkManager.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Network Manager.
Feb 22 17:03:54 pureos systemd[1]: Stopping D-Bus System Message Bus...
Feb 22 17:03:54 pureos systemd[1]: dbus.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped D-Bus System Message Bus.
Feb 22 17:03:54 pureos systemd[1]: Stopped target Basic System.
Feb 22 17:03:54 pureos systemd[1]: systemd-ask-password-plymouth.path: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Feb 22 17:03:54 pureos systemd[1]: Stopped target Paths.
Feb 22 17:03:54 pureos systemd[1]: Stopped target Slices.
Feb 22 17:03:54 pureos systemd[1]: Removed slice User and Session Slice.
Feb 22 17:03:54 pureos systemd[1]: Stopped target Sockets.
Feb 22 17:03:54 pureos systemd[1]: dbus.socket: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Closed D-Bus System Message Bus Socket.
Feb 22 17:03:54 pureos systemd[1]: Stopped target System Initialization.
Feb 22 17:03:54 pureos systemd[1]: Stopping Network Time Synchronization...
Feb 22 17:03:54 pureos systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Feb 22 17:03:54 pureos systemd[1]: Stopped target Swap.
Feb 22 17:03:54 pureos systemd[1]: systemd-sysctl.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Apply Kernel Variables.
Feb 22 17:03:54 pureos systemd[1]: systemd-modules-load.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Load Kernel Modules.
Feb 22 17:03:54 pureos systemd[1]: Stopping Load/Save Random Seed...
Feb 22 17:03:54 pureos systemd[1]: Stopped target Local Encrypted Volumes.
Feb 22 17:03:54 pureos systemd[1]: systemd-ask-password-wall.path: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Feb 22 17:03:54 pureos systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:backlight-dsi...
Feb 22 17:03:54 pureos systemd[1]: systemd-timesyncd.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Network Time Synchronization.
Feb 22 17:03:54 pureos systemd[1]: systemd-random-seed.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Load/Save Random Seed.
Feb 22 17:03:54 pureos systemd[1]: systemd-update-utmp.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Feb 22 17:03:54 pureos systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Create Volatile Files and Directories.
Feb 22 17:03:54 pureos systemd[1]: Stopped target Local File Systems.
Feb 22 17:03:54 pureos systemd[1]: Unmounting /media/purism/03c1c0fd-68ed-417a-b7e0-a36acfeb7a99...
Feb 22 17:03:54 pureos systemd[1]: Unmounting /boot...
Feb 22 17:03:54 pureos systemd[1]: systemd-backlight@backlight:backlight-dsi.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:backlight-dsi.
Feb 22 17:03:54 pureos systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
Feb 22 17:03:54 pureos systemd[1]: boot.mount: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Unmounted /boot.
Feb 22 17:03:54 pureos systemd[1]: systemd-fsck@dev-disk-by\x2duuid-5687b3c9\x2dc5ee\x2d4ea8\x2da8a7\x2d019b158c3ef0.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped File System Check on /dev/disk/by-uuid/5687b3c9-c5ee-4ea8-a8a7-019b158c3ef0.
Feb 22 17:03:54 pureos systemd[1]: Removed slice system-systemd\x2dfsck.slice.
Feb 22 17:03:54 pureos systemd[1]: media-purism-03c1c0fd\x2d68ed\x2d417a\x2db7e0\x2da36acfeb7a99.mount: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Unmounted /media/purism/03c1c0fd-68ed-417a-b7e0-a36acfeb7a99.
Feb 22 17:03:54 pureos systemd[1]: Reached target Unmount All Filesystems.
Feb 22 17:03:54 pureos systemd[1]: Stopped target Local File Systems (Pre).
Feb 22 17:03:54 pureos systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Feb 22 17:03:54 pureos systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Create Static Device Nodes in /dev.
Feb 22 17:03:54 pureos systemd[1]: systemd-sysusers.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Create System Users.
Feb 22 17:03:54 pureos systemd[1]: systemd-remount-fs.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Remount Root and Kernel File Systems.
Feb 22 17:03:54 pureos systemd[1]: Stopping Clean the /media/purism/03c1c0fd-68ed-417a-b7e0-a36acfeb7a99 mount point...
Feb 22 17:03:54 pureos systemd[1]: clean-mount-point@media-purism-03c1c0fd\x2d68ed\x2d417a\x2db7e0\x2da36acfeb7a99.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Stopped Clean the /media/purism/03c1c0fd-68ed-417a-b7e0-a36acfeb7a99 mount point.
Feb 22 17:03:54 pureos systemd[1]: Removed slice system-clean\x2dmount\x2dpoint.slice.
Feb 22 17:03:54 pureos systemd[1]: Reached target Shutdown.
Feb 22 17:03:54 pureos systemd[1]: Reached target Final Step.
Feb 22 17:03:54 pureos systemd[1]: systemd-reboot.service: Succeeded.
Feb 22 17:03:54 pureos systemd[1]: Started Reboot.
Feb 22 17:03:54 pureos systemd[1]: Reached target Reboot.
Feb 22 17:03:54 pureos systemd[1]: Shutting down.
Feb 22 17:03:54 pureos systemd[1]: Hardware watchdog 'imx2+ watchdog', version 0
Feb 22 17:03:54 pureos systemd[1]: Set hardware watchdog to 10min.
Feb 22 17:03:54 pureos kernel: watchdog: watchdog0: watchdog did not stop!
Feb 22 17:03:55 pureos kernel: printk: systemd-shutdow: 45 output lines suppressed due to ratelimiting
Feb 22 17:03:55 pureos systemd-shutdown[1]: Syncing filesystems and block devices.
Feb 22 17:03:55 pureos systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Feb 22 17:03:55 pureos systemd-journald[286]: Journal stopped
-- Reboot --
What kernel version are you using?
uname
root@pureos:~# uname -a
Linux pureos 5.9.0-1-librem5 #1 SMP PREEMPT Tue Jan 19 07:36:15 PST 2021 aarch64 GNU/Linux
Could you post the output from this?
journalctl --user -u wys.service
purism@pureos:~$ journalctl --user -u wys.service
-- Logs begin at Mon 2021-02-22 15:58:45 CET, end at Mon 2021-02-22 17:47:01 CET. --
-- Reboot --
Feb 22 16:00:33 pureos systemd[588]: Started Wys, a daemon for voice call audio.
Feb 22 16:01:35 pureos wys[605]: Wys started with modem `MODEM'
Feb 22 16:01:35 pureos systemd[588]: Stopping Wys, a daemon for voice call audio...
Feb 22 16:01:35 pureos systemd[588]: wys.service: Succeeded.
Feb 22 16:01:35 pureos systemd[588]: Stopped Wys, a daemon for voice call audio.
Feb 22 16:01:35 pureos systemd[588]: Started Wys, a daemon for voice call audio.
Feb 22 16:01:35 pureos wys[1182]: Error in PulseAudio context: Connection terminated
Feb 22 16:01:35 pureos systemd[588]: wys.service: Main process exited, code=exited, status=1/FAILURE
Feb 22 16:01:35 pureos systemd[588]: wys.service: Failed with result 'exit-code'.
-- Reboot --
Feb 22 16:03:23 pureos systemd[658]: Started Wys, a daemon for voice call audio.
-- Reboot --
Feb 22 16:53:59 pureos systemd[610]: Started Wys, a daemon for voice call audio.
-- Reboot --
Feb 22 17:04:10 pureos systemd[612]: Started Wys, a daemon for voice call audio.
This combo will provide some reboot needed power to the Librem 5 (charge it otherwise as well):
