Still no dogwood?
@Kyle_Rankin, can I ask your personal opinion as a user, of the experience (and forgetting exactly how many mAh battery may have etc.)? Provided, that no huge surprices come up anymore, does Dogwood seem to be close to Evergreen on hardware?
We have a post on Evergreen that will hopefully get published in a few days that should answer your question :slight_smile:
Two Dogwood owners
https://mastodon.technology/@eyecreate/104699325361779737
How are calls & texts working?
I’ve not had the chance to test that personally. I don’t have a phone plan right now and likely won’t until spring.
I will ask now since I know others will ask you eventually - can you tell us about battery life?
I’ve not actively tested it, but I can tell you it is only a few hours right now. I would assume 6 to 8 with the baseband and camrea/mic off. I can tell you I’ve passed out without with it at full charge and on that setting it was fully drained before I woke up. I can test it out tommorow, but seeing the progress they have made on it already I’d assume it will be longer before evergreen comes out.
The most notable thing I’ve had to deal with so far has been the fact I had to use SCP to send files to it after setting up the SSH server myself. Not the worst thing I’ve had to do to send files onto a system before, but I was fairly shocked they have not gotten MTP working yet as far as I can tell.
I’ve set up a shell script to print the battery %, the battery life in the less human readable form that it has, and the time in in a CVS file to share with you all, I’ve had it running a few hours with it as a cron job that runs every minute. Currently it’s at idle in lockdown mode. I’ll keep letting it do that for the next few hours then post the file here. I’ll likely collect it regularly like this for the next few weeks on different setting to see the current state of the battery. If you’ed like I can post the shell script when I post the CVS file.
EDIT: https://github.com/dylanlester-librem/Librem5-battery-data I had to use a github account I made on the fly to host the files as I could not upload them here directly.
Thanks for all the updates dylanlesterpvcs, it is very much appreciated, please keep them coming.
Connecting back to separate topic (Planning ahead: what and how to report on L5 when the time comes) close to this: could it be possible to add a column or two to that script for more info? Load average would give some indication how much use device is getting (for instance cat /proc/loadavg , all five or just the first and fourth) selected in the script. And maybe data transferred (total cumulative up/down or individually by method/radio)?
General thoughts on this continued in the separate data gathering thread…
@dylanlesterpvcs,
If you have a scale, I would appreciate it if you could weigh Dogwood. Birch and Chestnut weighed 230 grams, but Dogwood has a higher-capacity battery and added a back metal plate for better heat dissipation and a plastic plate over the M.2 cards, so I expect that the weight has changed.
It would be cool if you could post the output from these commands:
sudo dmesg
sudo apt install lshw
sudo lshw
sudo apt install sysbench
sysbench --test=cpu --threads=1 run
sysbench --test=cpu --threads=4 run
sysbench --test=memory run
sysbench --test=fileio --file-test-mode=seqwr run
sudo apt install lm-sensors
sensors
@amosbatto could not get sysbench even installed as it could not find it in the repos, as for lm-sensors, it returned an error when I tried to run it. THe output from dmesg and lshw along with anything that lm-sensors might have spit out in a file called request.md it is really a txt file. https://github.com/dylanlester-librem/Librem5-battery-data
Thanks @dylanlesterpvcs.
It looks like lshw shows the temperature info, so lm-sensors isn’t needed.
I’m surprised that there is no sysbench package. Is there a hardinfo package? That has some basic benchmarking.
Looking at your dmesg log, I’m struck by how long it takes to bring up the Wi-Fi (11.6 seconds) and the cellular modem (18.9 seconds), but everything else seems to boot really fast. It looks like the GNSS still isn’t being used.
Hi @Kyle_Rankin ! Just as a follow up to your last post, do you have a sense of timing for the publication of that next Evergreen update? Thanks!
I’m working on it! :slight_smile:
A graph from @dylanlesterpvcs data, battery charge overlaid with CPU load averages over 400 minutes. Shows a quick drop after some use and I quess there was some activity after you plugged it in to recharge…?
I am convinced that when the Librem5 is finally shipped, sales will increase. Many people wait for it to be on the market to buy it.
Regards
The time in seconds shows the gaps when I had the phone off to charge etc. if you graph the second column vs the time data in seconds itself you’ll see the raw battery data the phone sees I’ll be it at one minute intervals. The data is appended every minute the phone is on. It has gaps like that one you noticed any time I turn off the phone. those will be very clear if you graph the data vs the time in seconds. I’ll be making a graph myself for all of you to see in a few minutes that should give you a better idea of how long the batter lasts.
I’ll check it to see if it has a Hardinfo package in a few hours.
