The pandemic is history, why are the delays in order deliveries continuing?
Tell you what. If you can prove this assertion, I’ll take your side.
I am going to transmit the problem to the authorities so that they are the ones to investigate the situation. I think that there are so many people affected that they will investigate it. I’m not a policeman, I’m just stating a fact. The authorities are the ones who have the capacity to investigate it.
Correction: you’re making a guess accusation, and when called out on it, you refuse to present any evidence. I’m sorry, but this is the third warning, and you’re getting a time out for not understading the forum rules. See you (hopefully with improved discussion skills) after the holiday.
I reload ammo. I was looking at getting a reloading press, and some parts had lead times of 68 weeks…yes you read that right. And from an old well established company. If you think everyone can plan for every possible outcome you’re dreaming. I’m amazed I got a phone at all and it gets better with every OS update. Pretty amazing feat for a designed from the ground up phone dealing with a global chip shortage. The much bigger customers get their chips ahead of Purism. If you think what they have accomplished is easy I suggest you set up your own company and design your own phone.
