I have released a 3rd beta of the Muscle Buddy strength training tool.
This release is significant to this forum as it is the first release that was tested and debugged for the Librem 5. This allowed me to fix Librem 5 touchscreen and rumbler issues.
The blog announcing this release can be found here.
For Librem 5 and 11 users I recommend using an AppImage instead of trying to use the source code releases. Also the AppImage’s have a GUI installer which can be used to setup the app on desktop environments.
Sorry, no flatpak yet. Maybe I will have mastered flatpaks in time for the next release.
Feel free to post feedback here!
Wow, cool! Did you manage to figure out how to publish the app for PureOS, as you asked previously here? I will see if I can try Muscle Buddy this weekend!
janvlug
I am working on it, but I am taking the slow path. After discussing on this forum and reading everything I could find on the PureOS Store, I decided I should focus on Flathub first.
I am concerned about going through all the work building a flatpak specifically for the PureOS Store and then have it be rejected.
I decided I am going to start with a generic flatpak and submit that to Flathub. The new Pantheon installer inside the AppImage makes it easier to configure the app for desktop now so beta 3 can be more easily run by a broader audience. If I can carry that feature over to a flatpak, then Flathub acceptance should be possible.
I would create a Librem 5 specific flatpak for the PureOS store derived from the Flathub afterwards.
In a nut shell, it is going to take some more time.
