Wifi/bluetooth issues
I have tested with speedtest (command line, apt install speedtest-cli) and on the browser. Results were nearly identical (if I let the browser know my location). The bluetooth audio (playing local files from lollypop) was very choppy on 1.2, and very acceptable from 2.0 onwards. I only tested 2.4GHz, since I had a connection issue on 5GHz on 1.2 (which I did not further inverstigate in).
Does speedtest-cli do the tests against a server in Internet?
Yes, I would be concerned about that unless you have a 1 Gbit/sec fibre internet connection (and, ok, a 100 Mbit/sec internet connection would probably be adequate for this WiFi card on the 2.4 GHz band).
Regardless I would not test WiFi performance with a server on the internet and I would not test performance of your internet connection via WiFi.
OK i got the bug for issues between WPAN(bt) and WLAN(Wifi) on Redpine. I have the last firmware RS9116.NB0.NL.GNU.LNX.OSD.2.3.2.0003 there is a newer firmware (RS9116.NB0.NL.GNU.LNX.OSD.2.5.1.11) not yet shipped to L5.
I found that Redpine driver it has too many issues to work on AP and WPAN, so changing the router from AP to AD_HOC protocol everything work good on Librem 5. I found too that Redpine driver it required that WPAN devices get connected first than WLAN devices, so doing this step you can get wifi and bt working at the same time without issues for stutering or interruptions.
I hope that @dos ship the newer firmware fast to Librem 5 to get better compatibilities with AP 4+c Routers.
Mmm i have one more idea to trick AP work on Librem 5, but i untested. Like connect the Librem 5 on AP with less 3 clients on the Router but first connect bt client then wifi to router. I unable to do this test ATM.
I got lot of confused because something it not matching on Redpine on Driver and Firmware like:
Current ’ sudo dmesg | grep redpine ’ it showing like
redpine_91x: FW Version|: 1.2.20.0 < – THIS NUMBER CONFUSE ME because has to be matched with driver version.
redpine_91x: RSI FW Version|: 0000.1.2.0.0502
redpine_91x: Driver Version|: RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
I guess that this need to be like
redpine_91x: FW Version: 2.0.0.0024
redpine_91x: RSI FW Versio|: 2.0.0.0024
Seems like that RPS file only ship firmware not driver, then the Firmware need to match with version Driver, it seems that current Librem 5 kernel it shipping driver version: 2.0.0.0024 so we need burn the correct firmware like *2.0.0.0024.rps even if burn *2.0.0.0024.rps it not show matching on dmesg redpine, then the braves peoples can be confused, and making malfuntion on bt and wlan.
Just reporting to you my current output (without any comment from my side, need to go out now anyway), but still and hopefully helping you somehow:
FW Version : 3.2.2.16
RSI FW Version : 1610.3.2.2.0003
Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
uname -r
5.17.0-1-librem5
@Quarnero Yeah you are running a wrong Firmware too same like me before, then i catched later the wrong.
On Linux 5.17 still shipping redpine driver RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024 so you need burn again the correct Firmware like: https://source.puri.sm/Librem5/redpine-firmware-nonfree/-/raw/master/files/firmware/RS9116_NLINK_WLAN_BT_IMAGE.FW2.0.0.24.rps
Thanks! I’ll replace firmware that I’m currently running this upcoming weekend.
I also observed that Firmware and Driver version do not match. This seems to be normal. Apparently only Firmware is shipped in the file.
@pit The newer firmware 2.5 already there but we stil need driver so i guess we will see the driver on Linux5.17.+
No, it’s a separate thing and doesn’t necessarily have to match, Redpine just releases their firmwares and kernel drivers together with the same versioning. Generally the way firmware version numbers are stored differs between firmware versions and formats, which is why things can look a bit weird there. In any case, the firmware version 2.0.0.0024 is being reported (after loading) as:
FW Version        : 0.2.0.16
RSI FW Version        :  1610.0.2.0.0024
There are other firmware versions available and having them on your device isn’t wrong or bad. There’s 1.0.5, 1.2.1, 1.2.20, 2.0.0.24, 2.3.2.3 and 2.5.1.11, and in my experience each comes with its own set of quirks and issues :stuck_out_tongue_winking_eye:
I believe the versions that are most commonly used at this moment are 1.2.20 and 2.0.0.24. I don’t think that we have ever switched to 2.3.2.3 for new devices, and 2.5.1.11 has been released just a few days ago, so it’s way too early to say anything about it.
I tested the version 2.5.1.11 (see here). Results:
  • bluetooth and wifi work at the same time
  • wifi has full speed (on 2.4GHz)
  • no new errors detected (but only tested for some minutes)
Thanks for helping to solve this issue @irvinewade, @guru, @dos, @Captain_Morgan, @carlosgonz, @Quarnero, @angus.ainslie.
Have you only downloaded the file to /lib/firmware/ and rebooted, or does it need another kernel/driver? I’m on
uname -r
5.16.0-1-librem5
Interesting but fails to open the rps file for me, hence cannot install new firmware to test.
@guru I downloaded, renamed to RS9116_NLINK_WLAN_BT_IMAGE.rps and rebooted. I am on the same kernel.
@Captain_Morgan rename the file to RS9116_NLINK_WLAN_BT_IMAGE.rps
thanks for that reminder -that worked and caused the install process to proceed, however on my L5 it did not like the new driver, either it didnt install or the driver isnt compatible, or i wonder if i have to change the operating mode to something other than 13 since it gives a warning that only prior versions 2.# support mode 13. (bluetooth doesnt work at all now, FW version doesnt show normal value)
Operation mode should be 5. Note that it has to be adjusted twice in the file /etc/modprobe.d/librem5-devkit.conf
Installed older driver and changed to operating mode 5, but bluetooth doesnt show in notification anymore (BT symbol greyed out cannot be toggled):
(weird it doesnt let me add png or jpg files saying the ones i upload arent supported formats even though they are)
Service seems up and running:
sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-04-01 11:23:20 PDT; 12min ago
Docs: man:bluetoothd(8)
Main PID: 979 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 3125)
have you tried sudo systemctl restart bluetooth?
have you tried toggling the hwks?
what does rfkill and dmesg say?
Yes the service runs, software all installed, i figured out the controller isnt running:
#bluetoothctl
power on
No Default Controller Available.
My guess is that during driver flashing it flashed the wifi but not bluetooth part of the driver or somehow it got knocked out.
What i tried:
  1. install older version of driver (flashing the newest (1day old) version caused this issue in the first place)
  2. switch from 13 to 5 operating mode
  3. toggle all HW switches (all off, all on)
  4. reboot
  5. tried to install newest driver again, bluetooth controller still not back to life.
One question, once the driver file is copied into firmware after download i have been changing the file permissions to read/write for all, not sure thats needed?
As previously mentioned i download the firmware driver then:
while modem is on
cd ~/Downloads
sudo rm /lib/firmware/RS9116*
sudo mv RS9116* /lib/firmware/RS9116_NLINK_WLAN_BT_IMAGE.rps
power off phone without usb charger plugged in
power on
lsusb output (which one is the bluetooth device?):
Bus 001 Device 006: ID 2020:2060 Qualcomm, Incorporated Qualcomm CDMA Technologies MSM
Bus 001 Device 003: ID 0424:4041 Microchip Technology, Inc. (formerly SMSC) Hub and media card controller
Bus 001 Device 002: ID 0424:2640 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
rfkill list output
generated an error interestingly…
rfkill ./include/xalloc.h:74: xstr dup : Assertion ‘str’ failed.
dmesg redpine output:
Sorry for the gigantic log:
[ 19.400757] redpine_91x: rsi_probe: ***** 9116 Module *****
[ 19.401028] redpine_91x: redpine_hal_device_init: oper_mode = 5, coex_mode = 2
[ 19.402219] redpine_91x: Received Board Version Number: 10
[ 19.403390] redpine_91x: rsi_load_firmware: Loading file RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 19.408040] redpine_91x: FW Length = ================================================
[ 19.408075] redpine_91x: FW Version : 2.3.0.0
[ 19.408080] redpine_91x: RSI FW Version : 1610.2.3.2.0003
[ 19.408086] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
[ 19.408090] redpine_91x: Operating mode : 5 [Wi-Fi STA + BT EDR]
[ 19.408094] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 19.408098] redpine_91x: ================================================
[ 19.488606] redpine_91x: *** Flash ================================================
[ 24.548408] redpine_91x: FW Version : 3.2.2.16
[ 24.548418] redpine_91x: RSI FW Version : 1610.3.2.2.0003
[ 24.548426] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
[ 24.548432] redpine_91x: Operating mode : 5 [Wi-Fi STA + BT EDR]
[ 24.548438] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 24.548443]
[ 458.587524] redpine_91x: rsi_sdio_check_buffer_status: Failed to read status register
[ 458.587790] redpine_91x: ##### RSI SDIO device disconnected #####
[ 460.685458] redpine_91x: rsi_probe: ***** 9116 Module *****
[ 460.685649] redpine_91x: redpine_hal_device_init: oper_mode = 5, coex_mode = 2
[ 460.686823] redpine_91x: Received Board Version Number: 10
[ 460.687930] redpine_91x: rsi_load_firmware: Loading file RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 460.688239] redpine_91x: FW Length = 131584 ================================================
[ 460.688263] redpine_91x: FW Version : 2.3.0.0
[ 460.688269] redpine_91x: RSI FW Version : 1610.2.3.2.0003
[ 460.688277] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
[ 460.688282] redpine_91x: Operating mode : 5 [Wi-Fi STA + BT EDR]
[ 460.688288] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 460.688293] redpine_91x: ================================================
[ 460.761562] redpine_91x: *** Flash CRC passed ***
[ 460.763807] redpine_91x: ***** Loaded Firmware *****
[ 465.897169] redpine_91x: ================================================
[ 465.897192] redpine_91x: ================ RSI Version Info ==============
[ 465.897197] redpine_91x: ================================================
[ 465.897201] redpine_91x: FW Version : 3.2.2.16
[ 465.897226] redpine_91x: RSI FW Version : 1610.3.2.2.0003
[ 465.897234] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
[ 465.897240] redpine_91x: Operating mode : 5 [Wi-Fi STA + BT EDR]
[ 465.897246] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 465.897252]
sudo dmesg | egrep -i ‘blue|firm’ (output right after trying to install latest BT driver and upon reboot)
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 3.482292] cdns-mhdp-imx 32c00000.hdmi: [drm:cdns_mhdp_read_fw_version [cdns_mhdp_drmcore]] firmware version: 50d385ac
[ 18.535443] imx-sdma 302c0000.sdma: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 18.535466] imx-sdma 302c0000.sdma: external firmware not found, using ROM firmware
[ 18.625196] imx-sdma 30bd0000.sdma: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 18.625219] imx-sdma 30bd0000.sdma: external firmware not found, using ROM firmware
[ 19.086827] Bluetooth: Core ver 2.22
[ 19.086922] NET: Registered PF_BLUETOOTH protocol family
[ 19.086926] Bluetooth: HCI device and connection manager initialized
[ 19.086945] Bluetooth: HCI socket layer initialized
[ 19.086954] Bluetooth: L2CAP socket layer initialized
[ 19.086988] Bluetooth: SCO socket layer initialized
[ 19.296131] redpine_91x: rsi_load_firmware: Loading file RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 19.301131] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 19.417391] redpine_91x: device firmware doesn’t match proceed to upgrade …
[ 19.442542] redpine_91x: Burn Command Pass… Upgrading the firmware
[ 20.424854] imx-sdma 30bd0000.sdma: sdma firmware not ready!
[ 20.637318] 0x000000030000-0x000000200000 : “firmware”
[ 22.394470] redpine_91x: Firmware upgradation Done
[ 25.697698] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.697744] Bluetooth: BNEP socket layer initialized
[ 27.622353] redpine_91x: ***** Loaded Firmware *****
[ 32.736118] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 40.874969] redpine_91x: EAPOL 4 confirm
[ 52.581525] redpine_91x: EAPOL 4 confirm
