@Quarnero
I just did as requested and uploaded a jpg file. Site still says …“is not authorized (authorized extension: jpg, jpeg, png, gif, webp)”
~s
I’m about to check this. Also and related to our next day conversation:
extension, as visible when opened within new Tab) was successful (I’ve made another post with upload today as well). Perhaps you might want to Save as
right away. Perhaps log out
from this Forum => log in
helps there.
EDIT: If you are indeed out of working space (and you never wanted to accept this as a fact), and if I’m guessing right (as I do not know for sure) and as you already introduced yourself to @marcf post, df -kh /
and expansion of /
partition related, are you out of /home
directory space there?
Furthermore, @Sharon, upload might therefore not work from Librem 5 (if available partition space is at its minimum) and by copy of this screenshot to some external USB drive (or external SD card device over USB-C port) you’ll be able to upload it (or attach it to the related E-mail) from another computer.
Nah! I have used Windows Phones keyboards for quite a few years. None of them were so hard to negotiate as the L5’s keyboard. Of course autocorrection makes a difference, but the L5’s keys are somehow smaller or at least more fiddly then the keys I was used to on my previous phones.
O, and in landscape orientation the keyboard takes up the whole screen. That makes typing a lot easier, for sure. But as you can’t see what you are typing, you still end up with loads or errors.
So, the keyboard is too small in portrait rotation, and to big in landscape orientation.
One thing I have noticed, is that there are two different keyboard layouts for the portrait orientation: one that shows when you have to enter the disk encryption password, and another that shows up most of the other times (like when you have to enter your sim password).
The first has black borders around the keys, the second does not have these borders.
I think the first one is a bit easier for typing than the second one.
This is for Mladen.Pejakovic @mladen
Wow, I renamed it to ml.jpg - not what we see above. But it’s the same image.
~s
Not sure at this moment how (and if I understand your screenshot correctly), yet quite sure that you can help yourself by using those two tools on your host computer, when your Librem 5 connected to it: Fix broken phoc.ini. Once picocom
runs there please introduce yourself to relevant (perhaps) content of: Tutorial: Full disk encryption on Librem5.
Second (similar resize partition approach related or at least to make more available/working space on this Librem 5 /home
) tool (using already installed uuu
package) that easily needed there would be (please search this Forum on how-to):
P.S. I’m continuing to guess what needed there but anyway trying to help somehow,
I don’t know whom you are responding to, but if it was me, the image is for @mladen regarding the camera screen no longer making it after opening Camera. He has already replied via email so soon, I may change be use the Solved button ~s
Others do have the same issue.
I’m not concerned about other devices - just this one. Comparing rocks to boulders - na.
It’s very simple. The keypad is extremely overly sensitive. If there is no way to adjust, I’l hook the L5 up to the tower, and use, similar to lapdock only using a better keyboard, and monitor, then I save a lot time changing each app so it fits on the screen without the need to be scrolling back and forth to get what is off-screen, IF, the device puts a scroll bar, most times not.
My Hoyoki arrived, to run phone through desktop.
Overly sensitive areas on keytab causes search box to appear with a cursor in it. Why? I didn’t press anything for that. Getting the cursor out of the search box is done by out of the search box is only by reboot, if one swipes/taps anything, and it stubbornly does nothing 2, 3 6 9 times, and finally does,the search box underneaths existing view shows up with cursor inside it. Only way to get cursor out is reboot.
The keytab is sensitive, when the pad is being read by the system. Something must be interfering, and blocking things while whatever takes over id done. That might be 2,3 4, 6 seconds.
Suggestions:
1 - create a means to edit the time between taps.
2 - Set a means with which to get the cursor out of the search box without having to do a cold start.
3 - whatever interrupts key-presses, permit L5 users to enable/disable it. If nothing is interrupting (I think there is), please recommend a good compatible anti-malware and virus detector.
4 - failing that, I’d rather spend the time of reinstalling OS than trying to remember what needs tweaked that works and stop what doesn’t.
What is Best Practice procedure to wipe it clean and start over OS again? I didn’t see any in https://docs.puri.sm/Librem_5.html
TIA
It’s there, under Troubleshooting > Reflashing the phone
That also links to the reflashing documentation in the developer docs.
Be advised that if you want to add LUKS encryption to the image, you have to specify it when installing. I didn’t; I just used the regular image. It was fairly easy.
If you need help with the actual process, you might want to start a new thread and ask questions as you go.
Thanks amarok for response.
Sorry to waste your time, but I thought it might be similar to dropping PurOS on a device and boot into the install. There goes another feature.
Thank you for your time.
~s
I was scared to do it at first, but it turned out to be pretty straightforward.
