Today liquid cooler with a modded staff for g34 arrive :slight_smile: Next months
  • a new case
  • powerful opteron 62** cpu
  • a little more ram
and I will retry
The previous try was a fail because…
  • too much noise
  • too hot/warm air very stinky make me headaches
I will report how liquid cooler works (hope fine)
I continue improvements my raptor computer too, i found a way to use a gtx750 on SFF, this a milestone to me, as for now i using gtx745 which work incredible, but gtx750 is OMG, even more i will use my OMG GTX750 Zotac(only to fit) with GnuLinux 7.0 which will added tons improvement on nouveau. I cant wait for.
The problems of those cards is they have a fan to cool the gpu and I hate fans, I see some news configurations use liquid cooler also for gpu. Personally I still remind the old pc of 2000-2006 with the cpu monocore with really noisy fans, I also remind the nightmare of “case vibration” and my tries to regulate screws and insert piece of paper to try to quiet that damns machines :slight_smile:
But GPU fan do not make noise, it pretty noiseless.
But there is one fanless:
GTX750 is most OMG GNU GPU for sure.
Enjoy!
Great idea they had. Even occupy too much space. It will fit in kgpe-d16? I need a configuration like this
slot1 empty
slot2 gpu
slot3 gpu (I need for retrogaming, gpu passtrough :wink: )
slot4 usb3 controller (the via controller works really good)
The best question: 3d will works with libre kernel? and video rendering? I have tried the gt710 with libre kernel recently and gave me error with firmware (3d disabled works but without 3d is useless)
with standard kernel require a proprietary firmware and h264 hw rendering fail.
Yes it work 3D, but no audio support sadly, looks like there is issues on Nouveau.
Just installed Zotac GTX 750 LP on Raptor yesterday, it work a lot better than GTX745, however i have noticied that gtx750 do not enable the full cores on the chip, so i going to upgrade it to super rare Zotac GTX 750ti LP, however i not sure how to quick found this omg gpu.
To be honest i still do NOT have a Real Browser for PowerPC either LE or BE. GnuIcecat still missing JIT and LTO for PowerPC, however it work OK, but not BUTTER
Raptor Computer System initially added full support for PowerPC on ChromiumBrowser, however i do not like Chromium either is compatible with Gnu trisquel 12 out-of-the-box.
The PowerPC Browser Arcticfox is stopped thanks to MacOS 10.5
To be honest i really love :heart: powerpc, sadly thanks to x86-garbage the community support is very low.
FF JIT WIP
I may super happy if Gnu Icecat supported JIT for PPC.
EDIT:
Ok so there are not a real Browser BigEndian, ATM. Either a real GPU BigEndian.
ATM Netsurf browser work OK on my Power5 BE.
A question: i have this ram and gave me a lot of problems
rdimm gnuboot image: don’t boot
coreboot: boot sometimes
udimm gnuboot image: never tested
I see you recommend to use udimm image of gnuboot, is not rdimm image the correct one?
Today finally the pieces arrived
New case thermaltake 500 the tower
Two liquid coolers Zalman LQ310 (warning! the Zalman Lq310 don’t support the g34 socket, you have to mod the “retain” and pray, i avoid every responsibility in hw damage)
Two news cpu 6828SE
udimm ram :expressionless: because with rdimm don’t boot :frowning:
The pc is really silent and look the temps :wink:
temp1:        +44.2°C  (high = +70.0°C, hyst = +65.0°C)
                       (crit = +85.0°C, hyst = +80.0°C)  sensor = thermal diode
temp7:        +21.0°C  (high = +70.0°C, hyst = +65.0°C)
                       (crit = +85.0°C, hyst = +80.0°C)  sensor = AMD AMDSI
temp8:        +20.8°C  (high = +70.0°C, hyst = +65.0°C)
Comparing with old very hateful noisy “coolers” when the temps became 40° in idle after some minutes.
I spend a lot of money (circa 500€) but I’m satisfied.
The pc has those “noisy” values
not quiet as passive cooler of ryzen :frowning:
but really quiet compared to “silent” fans :slight_smile:
New values with thermal paste and new fans noctua “silent”
temp7:        +17.8°C  (high = +70.0°C, hyst = +65.0°C)
temp8:        +22.0°C  (high = +70.0°C, hyst = +65.0°C)
external temp is over 32°C, must tested under stress.
Under stress…
stress --cpu 32 --timeout 300
stress: info: [2746] dispatching hogs: 32 cpu, 0 io, 0 vm, 0 hdd
temp1:        +47.0°C  (high = +70.0°C, hyst = +65.0°C)
temp7:        +33.8°C  (high = +70.0°C, hyst = +65.0°C)
temp8:        +39.2°C  (high = +70.0°C, hyst = +65.0°C)
Consider the number 2 liquid is probably defective and I had already ordered a replace.
Under 4 minutes of stress with load at 32(!)
temp1:        +47.5°C  (high = +70.0°C, hyst = +65.0°C)
temp7:        +37.5°C  (high = +70.0°C, hyst = +65.0°C)
temp8:        +44.8°C  (high = +70.0°C, hyst = +65.0°C)
What paste name?
Share all cores or there are just 2?
It is incredible result under stress.
I have Heat issues on Raptor computer which hit 80c, this make to not active the super agressive IBM WOF, so i never try wof due to heat manager issues.
I have spent a lot for this pc, now i’m near finish. I have buy this thermal paste
Those fans (must be two for every liquid cooler otherwise is not possible to use pc under heavy load)
For liquid coolers is ok the Zalman lq310 (near impossible to find even used), or better Lq320 (impossible to find :frowning: )
The most important thing: found a store or similar which can mod the “attach” of Zalman for socket g34, I was lucky and I bought one with modded attachs. In next months I will put pics
Congratulations" :partying_face:
All cores of course 32 (16+16)
The results are good, considering i had to replace one defective liquid cooler (but works acceptable atm).
Pc turned on 18-20°
Pc under stress 38 (good cooler) 44 (bad cooler but is ok) 4 minutes with 32 cores at 100%
Pc after stress returning to normal 25-30° C
With the old configuration (i report just for information)
passive cooler with no fans: (sic!): 40-45° idle 70-80° under stress with pc turning off automatically
passive cooler with fans: just a little better than no-fans but if you try to reduce noise of fans (unacceptable) with fancontrol the temps are like no-fans with same turning off
liquid cooler with one fan only: idle is perfect 18-25° under stress go fast towards 60-70°, trying to compile qt6=thermal trotting and turning off :expressionless: consider also a very bad thermal paste
liquid cooler with two fans+good thermal paste: already said
A more better configuration
Modern aio of 120mm 240 better, but you have the knowledge to mood the “attach” to adapt to the g34 socket, is not impossible, there are also some good “workers of metal” which can do the work, aio is better if rechargable.
To avoid: passive cooling, is impossible with a tpw of 140
Fans are ok only if you sustain the noise and is not my case, I love silence.
p.s
Notice for liquid cooler, the Zalman lq310-315-320 are similar to “asetek” so there are some other aio compatibles and more easy to find: for example the Corsair h80i. Of course you have to mod-adapt the “attach” to fill the g34 socket.
Interesting.
I love fancy fan noise. I do not like silence because it disable my ears to track cpu workloads via ears.
I use w and sensors for monitoring temps and load
What is that?
Also explain me how you get to in to bmc? as i remember well you doing on different way than me on Raptor.
I know sensors, but i not: w
I don’t use the kgpe-d16 with bmc, I have ordered another one without bmc (don’t make problems, but make interference with fancontrol and fill the dmesg of error messages because bmc and Linux driver for temp try to access the “sensors” at same time).
W is historical Unix command, report the load
me@laptop:~$ w
00:45:59 up 58 min, 7 users, load average: 0,50, 0,66, 0,60
New release of coreboot for kgpe-d16, available in 3 versions:
vgaboot+ucode (proprietary blobs)
text mode only (blobs free)
actually gnuboot don’t show grub menu even in serial/text mode (with or without the sgabios/seabios switch) and hang sometimes on boot (must be turn off and turnon pc 5 10 and even 15 times!) I don’t tried this new rom, I will try it tomorrow or next two days, will be work? I hope! (I remind last coreboot rom used was a disaster: no serial output, no fancontrol)
