Better EQ for Librem 14 speakers
For those of you who purchased the Librem 14, you’ll realize there is no EQ profile and the speakers sound extremely low quality.
I used Pulse Effects to create a basic EQ Profile that hits a broad range of music from Jazz, Electronic, spoken word etc. It’s not perfect, but it is DEFINITELY better than out of the box EQ, which is non-existent.
I have professional experience producing audio, as well as creating products for the world market. With the preset provided below, it will at least be up to par for what you’d expect a high quality product to have.
Engineers - for future reference, please do not neglect audio quality.
Here is the sound profile I created. Normally stored as a .json, and since I can’t attach files here it is:
Purism14.json
You can copy/paste this into a .json file, put it in the PulseEffects config file on your computer and load it into pulse effects, or better yet, Engineers - please use this as a starting point for tuning your audio output. It’s not that the speakers are crap - it’s that you should not expect them to sound good without tuning them.
(UPDATE: See v2.0 in comments below, better reduction of distortion along with volume maximizing)
    "spectrum": {
        "show": "true",
        "n-points": "100",
        "height": "120",
        "use-custom-color": "false",
        "fill": "true",
        "show-bar-border": "true",
        "sampling-freq": "10",
        "line-width": "2",
        "type": "Bars",
        "color": [
            "1",
            "1",
            "1",
            "1"
        "color-axis-labels": [
            "1",
            "1",
            "1",
            "1"
        "gradient-color": [
            "0",
            "0",
            "0",
            "1"
    "output": {
        "blocklist": "",
        "plugins_order": [
            "equalizer",
            "limiter",
            "autogain",
            "gate",
            "multiband_gate",
            "compressor",
            "multiband_compressor",
            "convolver",
            "bass_enhancer",
            "exciter",
            "crystalizer",
            "stereo_tools",
            "reverb",
            "delay",
            "deesser",
            "crossfeed",
            "loudness",
            "maximizer",
            "filter",
            "pitch",
            "rnnoise"
        "bass_enhancer": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "amount": "0",
            "harmonics": "8.5",
            "scope": "100",
            "floor": "20",
            "blend": "0",
            "floor-active": "false",
            "listen": "false"
        "compressor": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "mode": "Downward",
            "attack": "20",
            "release": "100",
            "release-threshold": "-200",
            "threshold": "-12",
            "ratio": "4",
            "knee": "-6",
            "makeup": "0",
            "boost-threshold": "-72",
            "sidechain": {
                "listen": "false",
                "type": "Feed-forward",
                "mode": "RMS",
                "source": "Middle",
                "preamp": "0",
                "reactivity": "10",
                "lookahead": "0"
            "hpf-mode": "off",
            "hpf-frequency": "10",
            "lpf-mode": "off",
            "lpf-frequency": "20000"
        "crossfeed": {
            "state": "false",
            "fcut": "700",
            "feed": "4.5"
        "deesser": {
            "state": "false",
            "detection": "RMS",
            "mode": "Wide",
            "threshold": "-18",
            "ratio": "3",
            "laxity": "15",
            "makeup": "0",
            "f1-freq": "6000",
            "f2-freq": "4500",
            "f1-level": "0",
            "f2-level": "12",
            "f2-q": "1",
            "sc-listen": "false"
        "equalizer": {
            "state": "true",
            "mode": "IIR",
            "num-bands": "30",
            "input-gain": "0",
            "output-gain": "13.699999999999999",
            "split-channels": "false",
            "left": {
                "band0": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-31.111111111111111",
                    "frequency": "22.59",
                    "q": "4.3600000000000003"
                "band1": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-26.868686868686872",
                    "frequency": "28.440000000000001",
                "band2": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-21.91919191919192",
                    "frequency": "35.799999999999997",
                "band3": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-16.262626262626267",
                    "frequency": "45.07",
                "band4": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-3.5353535353535364",
                    "frequency": "56.740000000000002",
                "band5": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "4.6484375",
                    "frequency": "71.430000000000007",
                "band6": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "3.8888888888888928",
                    "frequency": "89.930000000000007",
                "band7": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "1.0606060606060623",
                    "frequency": "113.20999999999999",
                "band8": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "1.4141414141414188",
                    "frequency": "142.53",
                "band9": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "frequency": "179.43000000000001",
                "band10": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-2.8282828282828305",
                    "frequency": "225.88999999999999",
                "band11": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "1.5494791666666714",
                    "frequency": "284.38",
                "band12": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "0.35353535353534937",
                    "frequency": "358.01999999999998",
                "band13": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "frequency": "450.72000000000003",
                "band14": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-12.727272727272723",
                    "frequency": "567.41999999999996",
                "band15": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-7.7777777777777821",
                    "frequency": "714.34000000000003",
                "band16": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-14.494949494949495",
                    "frequency": "899.28999999999996",
                "band17": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-15.202020202020201",
                    "frequency": "1132.1500000000001",
                "band18": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-12.020202020202021",
                    "frequency": "1425.29",
                "band19": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-10.959595959595958",
                    "frequency": "1794.3299999999999",
                "band20": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-4.9494949494949516",
                    "frequency": "2258.9299999999998",
                "band21": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-7.4242424242424256",
                    "frequency": "2843.8200000000002",
                "band22": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "frequency": "3580.1599999999999",
                "band23": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-10.252525252525256",
                    "frequency": "4507.1499999999996",
                "band24": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-3.1818181818181799",
                    "frequency": "5674.1599999999999",
                "band25": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "0.70707070707071296",
                    "frequency": "7143.3500000000004",
                "band26": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "1.7676767676767682",
                    "frequency": "8992.9400000000005",
                "band27": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-2.474747474747474",
                    "frequency": "11321.450000000001",
                "band28": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-10.606060606060606",
                    "frequency": "14252.860000000001",
                "band29": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                    "gain": "-8.1313131313131279",
                    "frequency": "17943.279999999999",
            "right": {
                "band0": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band1": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band2": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band3": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band4": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band5": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band6": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band7": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band8": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band9": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band10": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band11": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band12": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band13": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band14": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band15": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band16": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band17": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band18": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band19": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band20": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band21": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band22": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band23": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band24": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band25": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band26": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band27": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band28": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band29": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
        "exciter": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "amount": "0",
            "harmonics": "8.5",
            "scope": "7500",
            "ceil": "16000",
            "blend": "0",
            "ceil-active": "false",
            "listen": "false"
        "filter": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "frequency": "2000",
            "resonance": "-3",
            "mode": "12dB\/oct Lowpass",
            "inertia": "20"
        "gate": {
            "state": "false",
            "detection": "RMS",
            "stereo-link": "Average",
            "range": "-24",
            "attack": "20",
            "release": "250",
            "threshold": "-18",
            "ratio": "2",
            "knee": "9",
            "input": "0",
            "makeup": "0"
        "limiter": {
            "state": "false",
            "input-gain": "0",
            "limit": "0",
            "lookahead": "5",
            "release": "50",
            "auto-level": "false",
            "asc": "false",
            "asc-level": "0.5",
            "oversampling": "1",
            "output-gain": "0"
        "maximizer": {
            "state": "false",
            "release": "25",
            "ceiling": "0",
            "threshold": "0"
        "pitch": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "cents": "0",
            "semitones": "0",
            "octaves": "0",
            "crispness": "3",
            "formant-preserving": "false",
            "faster": "false"
        "reverb": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "room-size": "Large",
            "decay-time": "1.5",
            "hf-damp": "5000",
            "diffusion": "0.5",
            "amount": "-12",
            "dry": "0",
            "predelay": "0",
            "bass-cut": "300",
            "treble-cut": "5000"
        "multiband_compressor": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "freq0": "120",
            "freq1": "1000",
            "freq2": "6000",
            "mode": "LR8",
            "subband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "lowband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "midband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "highband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
        "loudness": {
            "state": "false",
            "fft": "4096",
            "std": "ISO226-2003",
            "input": "0",
            "volume": "0"
        "multiband_gate": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "freq0": "120",
            "freq1": "1000",
            "freq2": "6000",
            "mode": "LR8",
            "subband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "lowband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "midband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "highband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
        "stereo_tools": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "balance-in": "0",
            "balance-out": "0",
            "softclip": "false",
            "mutel": "false",
            "muter": "false",
            "phasel": "false",
            "phaser": "false",
            "mode": "LR > LR (Stereo Default)",
            "side-level": "0",
            "side-balance": "0",
            "middle-level": "0",
            "middle-panorama": "0",
            "stereo-base": "0",
            "delay": "0",
            "sc-level": "1",
            "stereo-phase": "0"
        "convolver": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "kernel-path": "",
            "ir-width": "100"
        "crystalizer": {
            "state": "false",
            "aggressive": "false",
            "input-gain": "0",
            "output-gain": "0",
            "band0": {
                "intensity": "12",
                "mute": "false",
                "bypass": "false"
            "band1": {
                "intensity": "10",
                "mute": "false",
                "bypass": "false"
            "band2": {
                "intensity": "8",
                "mute": "false",
                "bypass": "false"
            "band3": {
                "intensity": "6",
                "mute": "false",
                "bypass": "false"
            "band4": {
                "intensity": "4",
                "mute": "false",
                "bypass": "false"
            "band5": {
                "intensity": "2",
                "mute": "false",
                "bypass": "false"
            "band6": {
                "intensity": "0",
                "mute": "false",
                "bypass": "false"
            "band7": {
                "intensity": "-2",
                "mute": "false",
                "bypass": "false"
            "band8": {
                "intensity": "-4",
                "mute": "false",
                "bypass": "false"
            "band9": {
                "intensity": "-6",
                "mute": "false",
                "bypass": "false"
            "band10": {
                "intensity": "-8",
                "mute": "false",
                "bypass": "false"
            "band11": {
                "intensity": "-10",
                "mute": "false",
                "bypass": "false"
            "band12": {
                "intensity": "-12",
                "mute": "false",
                "bypass": "false"
        "autogain": {
            "state": "false",
            "detect-silence": "false",
            "use-geometric-mean": "true",
            "input-gain": "0",
            "output-gain": "0",
            "target": "-23",
            "weight-m": "1",
            "weight-s": "1",
            "weight-i": "1"
        "delay": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "time-l": "0",
            "time-r": "0"
        "rnnoise": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "model-path": "Standard RNNoise Model"
Pulse effects takes 25% of the CPU though so… might need to find another EQ solution. The frequencies in the json would still apply no matter what EQ it was however.
Woha! I was complaining about the sound quality on matrix, and I couldn’t believe it was possible to source such bad sounding speakers in 2021. It seems I was right.
You really did magic here! Thanks!
@nicole.faerber it is true that this is a bit CPU intensive. Do you think this can be applied at a firmware level?
If you start it as a service, without the GUI, it consumes 6% of CPU. Still not perfect, but better than 25%.
You can start it as systemd service with the following unit:
~❯ cat ~/.config/systemd/user/pulseeffects.service
[Unit]
Description=pulseeffects
[Service]
ExecStart=/usr/bin/pulseeffects --gapplication-service
ExecStopPost=/usr/bin/pulseeffects -q
[Install]
WantedBy=default.target
@Sachio222
Is this EQ supposed to make the speakers sound “flat” or just better to your ears? What was your methodology?
(Also, thanks for doing this EQing).
3 things mainly
  1. maximize bottom end without hitting distortion
  2. soften out all resonating “tinny” sounds from the mids. They cut like a harsh push to the ear drums.
  3. provide shimmer and presence in the highs without creating excess noise.
I put it up against several different tunes on YouTube and spotify as well as audiobooks and tried to find and average profile that would maximize the performance of these speakers and bring them up to something that brings out the content and doesn’t get in the way by coloring the sound with “hey I’m a $0.50 speaker!” And rather, “hey here’s your audio!”
Also it’s a pleasure. I hope they take this as an example for what the expectation is for how to handle audio.
Awesome! Can’t wait to try
Thanks :slight_smile:
Updated with a v2.0. Made it so that louder music like dubstep distorts less, and that in general, you don’t have to be on full volume to hear it well. Although it might be heavier on the processor, for sound it can’t be beat. Have been jamming out to some tunes for an hour now and it handles almost everything with ease.
Purism14_2.0.json
    "spectrum": {
        "show": "false",
        "n-points": "100",
        "height": "120",
        "fill": "true",
        "line-width": "2",
        "type": "Bars",
        "color": [
            "1",
            "1",
            "1",
            "1"
            "1",
            "1",
            "1",
            "1"
        "gradient-color": [
            "0",
            "0",
            "0",
            "1"
    "output": {
        "blocklist": "",
        "plugins_order": [
            "equalizer",
            "maximizer",
            "limiter",
            "compressor",
            "autogain",
            "gate",
            "multiband_gate",
            "convolver",
            "bass_enhancer",
            "exciter",
            "crystalizer",
            "stereo_tools",
            "reverb",
            "delay",
            "deesser",
            "crossfeed",
            "loudness",
            "filter",
            "pitch",
            "rnnoise"
        "bass_enhancer": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "amount": "0",
            "harmonics": "8.5",
            "scope": "100",
            "floor": "20",
            "blend": "0",
            "listen": "false"
        "compressor": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "-1.8",
            "mode": "Downward",
            "attack": "20",
            "release": "100",
            "threshold": "-12",
            "ratio": "4",
            "knee": "-6",
            "makeup": "0",
            "sidechain": {
                "listen": "false",
                "mode": "RMS",
                "source": "Middle",
                "preamp": "0",
                "reactivity": "10",
                "lookahead": "0"
            "hpf-mode": "off",
            "lpf-mode": "off",
        "crossfeed": {
            "state": "false",
            "fcut": "700",
            "feed": "4.5"
        "deesser": {
            "state": "false",
            "detection": "RMS",
            "mode": "Wide",
            "threshold": "-18",
            "ratio": "3",
            "laxity": "15",
            "makeup": "0",
            "f1-freq": "6000",
            "f2-freq": "4500",
            "f1-level": "0",
            "f2-level": "12",
            "f2-q": "1",
        "equalizer": {
            "state": "true",
            "mode": "IIR",
            "num-bands": "30",
            "input-gain": "0",
            "output-gain": "9.5999999999999996",
            "left": {
                "band0": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band1": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band2": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band3": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band4": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band5": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band6": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band7": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band8": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band9": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band10": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band11": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band12": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band13": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band14": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band15": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band16": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band17": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band18": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band19": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band20": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band21": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band22": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band23": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band24": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band25": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band26": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band27": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band28": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band29": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
            "right": {
                "band0": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band1": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band2": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band3": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band4": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band5": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band6": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band7": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band8": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band9": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band10": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band11": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band12": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band13": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band14": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band15": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band16": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band17": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band18": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band19": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band20": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band21": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band22": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band23": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band24": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band25": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band26": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band27": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band28": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
                "band29": {
                    "type": "Bell",
                    "mode": "RLC (BT)",
                    "slope": "x1",
                    "solo": "false",
                    "mute": "false",
        "exciter": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "amount": "0",
            "harmonics": "8.5",
            "scope": "7500",
            "ceil": "16000",
            "blend": "0",
            "listen": "false"
        "filter": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "resonance": "-3",
            "inertia": "20"
        "gate": {
            "state": "false",
            "detection": "RMS",
            "range": "-24",
            "attack": "20",
            "release": "250",
            "threshold": "-18",
            "ratio": "2",
            "knee": "9",
            "input": "0",
            "makeup": "0"
        "limiter": {
            "state": "false",
            "input-gain": "0.29999999999999999",
            "limit": "-0.20000000000000004",
            "lookahead": "5",
            "release": "27",
            "asc": "false",
            "asc-level": "0.71000000000000019",
            "output-gain": "0"
        "maximizer": {
            "state": "true",
            "release": "21",
            "ceiling": "-0.20000000000000001",
            "threshold": "-9.6999999999999815"
        "pitch": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "cents": "0",
            "semitones": "0",
            "octaves": "0",
            "crispness": "3",
            "faster": "false"
        "reverb": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "hf-damp": "5000",
            "diffusion": "0.5",
            "amount": "-12",
            "dry": "0",
            "predelay": "0",
            "bass-cut": "300",
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "freq0": "120",
            "freq1": "1000",
            "freq2": "6000",
            "mode": "LR8",
            "subband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "lowband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "midband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "highband": {
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
        "loudness": {
            "state": "false",
            "fft": "4096",
            "input": "0",
            "volume": "0"
        "multiband_gate": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "freq0": "120",
            "freq1": "1000",
            "freq2": "6000",
            "mode": "LR8",
            "subband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "lowband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "midband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
            "highband": {
                "reduction": "-24",
                "threshold": "-12",
                "ratio": "2",
                "attack": "150",
                "release": "300",
                "makeup": "0",
                "knee": "9",
                "detection": "RMS",
                "bypass": "false",
                "solo": "false"
        "stereo_tools": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "balance-in": "0",
            "balance-out": "0",
            "mutel": "false",
            "muter": "false",
            "phasel": "false",
            "phaser": "false",
            "side-level": "0",
            "stereo-base": "0",
            "delay": "0",
            "sc-level": "1",
            "stereo-phase": "0"
        "convolver": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "kernel-path": "",
            "ir-width": "100"
        "crystalizer": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "band0": {
                "intensity": "12",
                "mute": "false",
                "bypass": "false"
            "band1": {
                "intensity": "10",
                "mute": "false",
                "bypass": "false"
            "band2": {
                "intensity": "8",
                "mute": "false",
                "bypass": "false"
            "band3": {
                "intensity": "6",
                "mute": "false",
                "bypass": "false"
            "band4": {
                "intensity": "4",
                "mute": "false",
                "bypass": "false"
            "band5": {
                "intensity": "2",
                "mute": "false",
                "bypass": "false"
            "band6": {
                "intensity": "0",
                "mute": "false",
                "bypass": "false"
            "band7": {
                "intensity": "-2",
                "mute": "false",
                "bypass": "false"
            "band8": {
                "intensity": "-4",
                "mute": "false",
                "bypass": "false"
            "band9": {
                "intensity": "-6",
                "mute": "false",
                "bypass": "false"
            "band10": {
                "intensity": "-8",
                "mute": "false",
                "bypass": "false"
            "band11": {
                "intensity": "-10",
                "mute": "false",
                "bypass": "false"
            "band12": {
                "intensity": "-12",
                "mute": "false",
                "bypass": "false"
        "autogain": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "target": "-23",
            "weight-m": "1",
            "weight-s": "1",
            "weight-i": "1"
        "delay": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
            "time-l": "0",
            "time-r": "0"
        "rnnoise": {
            "state": "false",
            "input-gain": "0",
            "output-gain": "0",
You’re the man! I was about to write that I found that with some certain style of music the sound was distorted. The fix came before the complaint :slight_smile: thanks!
Also, do you know how to add it as a service if I installed from flatpak? I am using
/var/lib/flatpak/app/com.github.wwmm.pulseeffects
as my path, but not sure if that is valid.
There can be a tiny bit of distortion at full volume still for some tracks, but I chose that as a trade off to not needing to always be at full volume for other tracks. So you’ve got somewhere louder to go for some things.
UPDATE: although rethinking this… especially with accoustic music having heavy distortion in the subs. May just cut back the bass altogether.
I think if you use a DE that supports the .desktop files, the preference “start at login” should work. Unfortunately I don’t know flatpak very well, and I avoid them for anything system related
I installed the preset v2.0 and I can confirm I haven’t found a single track that is distorted.
I’m actually so pleased with the results of 2.0 :slight_smile: I get slight lower distortion at full volume, but it’s loud enough to play 1 or 2 clicks from the top fine.
I’ve been listening to music all day on this and the profile turned out great.
I realized the equalizer preset is applied to any output devices, which is definitely not what we want bluetooth speakers and headsets. You can use the autoload folder in ~/.config/PulseEffects like so
~/.config/PulseEffects/autoload❯ cat alsa_output.pci-0000_00_1f.3.analog-stereo.json
	"name": "librem14-eq-2.0"
~/.config/PulseEffects/autoload❯ cat bluez_output.C0_28_8D_F6_95_0B.a2dp-sink.json
    "name": "default"
To create the default profile, just disable all effects in pulseeffects, then save this profile as default. The name of the file is pulse module name you want, which can be found by running pactl list
Great trick… great avatar.
Wow, this is an amazing difference! I wonder if there is a way to make it the default without having to use CPU? In any case, thank you so much for posting this.
Finally located pulseefects config docs:
https://www.systutorials.com/docs/linux/man/5-pulse-daemon.conf/
On elementary OS. After copying your code, I’m getting an error…
● pulseeffects.service - pulseeffects
   Loaded: loaded (/home/USER/.config/systemd/user/pulseeffects.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2021-05-27 00:27:29 EDT; 18s ago
  Process: 3164 ExecStopPost=/usr/bin/pulseeffects -q (code=exited, status=1/FAILURE)
  Process: 3142 ExecStart=/usr/bin/pulseeffects (code=exited, status=1/FAILURE)
 Main PID: 3142 (code=exited, status=1/FAILURE)
May 27 00:27:29 ME systemd[3123]: Started pulseeffects.
May 27 00:27:29 ME pulseeffects[3142]: Unable to init server: Could not connect: Connection refused
May 27 00:27:29 ME pulseeffects[3142]: cannot open display:
May 27 00:27:29 ME systemd[3123]: pulseeffects.service: Main process exited, code=exited, status=1/FAILURE
May 27 00:27:29 ME pulseeffects[3164]: Unable to init server: Could not connect: Connection refused
May 27 00:27:29 ME pulseeffects[3164]: cannot open display:
May 27 00:27:29 ME systemd[3123]: pulseeffects.service: Control process exited, code=exited status=1
May 27 00:27:29 ME systemd[3123]: pulseeffects.service: Failed with result 'exit-code'.
It does not start as a service, but simply typing systemctl --user start pulseerfects.service works perfectly.
Do you have a tip as to what i might need to change to get this to load automagically?
