Hi,
If I were to use an external microphon, where to plug it in?
Which device?
The Librem laptops (L13 and L15) currently sadly do not support external microphones, at least if you are looking for a 3.5mm jack mic. You can though of course attach something that has USB, which I would recommend for quality reasons anyway - there are USB headsets for example.
The new Librem Mini does support mic input on the 3.5mm headphone jack.
Cheers
nicole
See also
and
Thanks for link @kieran , I will come back to solving this issue during the one week break at the end of this semester (4 weeks left). I will also give a procedure update, at that time, in my original thread regarding my VM use situation & Yeti USB Microphone.
