Purism do allow and support coupon trading from old Librem5 orders.
I thought you blocked me. What gives???
Good link. However, this link did not describe the process of “transferring order and then taking coupon instead of phone” … this link described the process of “taking coupon instead of phone and transferring coupon”. Same result, but different thing.
My tablet arrived last week. Yay! I’m very excited. As has been discussed in a couple of threads here, the chassis is thought to be a ready available, off the shelf, model used to get tablets out the door quicker. I like the case and keyboard design. However, I’d like to find another case style where the keyboard can be set aside. As it is thought to be a common chassis model, surely there are other options to try. Please share if you know of any.
Many Thanks!
So question, is the internal hardware closer to a librem 5 then there computers and same for the software its a bigger screen and if that is true than this is basically a librem 5 with a tablet display with a slightly better processor? and it comes with a keyboard and pen, all for the same price? am I missing something here, please correct me if I’m wrong.
can add a SIMcard or eSIM to this device?
I think the answer is “no”.
For a start, the tablet is x86 CPU whereas the phone is ARM CPU.
I think “no”. No mobile network capability at all, as I understand it. But you could use an external dongle or you could “tether” it with a phone (e.g. via WiFi).
The Librem 11 also has a NVMe SSD, so you can upgrade it unlike the Librem 5 (USA/Liberty) which has a fixed eMMC capacity. The back of the Librem 11 is not easily removable, so upgrading the NVMe SSD will require some finesse.
There also seems to be no mention of a PGP smartcard reader on the Librem 11.
I guess the expectation is that you would use the Librem Key (if not now then in the future).
interesting because on the video it shows the same interface with apps as the librem 5 showing the messaging and calling apps
Chatty could likely still be used as a Matrix client, but probably not SMS/MMS.
Calls - no clue why this would be needed for a L11.
you can use it as a SIP client. And you can disable in gsettings the loading of the modem manager plugin to just use it for SIP.
You can use it as a xmpp, and matrix client. But actually there are folks that use chatty for SMS on laptops, either on devices with an internal modem+SIM card slot. Or with a USB modem.
Some folks even wrote reviews about that specific part:
I ordered my L11 two days ago. Is there a special forum for the L11 like it exists for my beloved L5?
No, the closest category is Librem, which is the parent category of Librem Key, Other OSes, and Phones (Librem 5).
Hi, could anyone that has been using the L11 for a few days please comment on:
- is it usable with 1 or 2 external displays? Slow?
- have you got it working with a Librem Key?
- are the ergonomics of the keyboard reasonable with larger hands?
- is the keyboard quite noisy?
- does it work well with external mouse via bluetooth?
- have you tried a minimal distro install such as Fedora Sway and did this improve battery life?
- does it run in vertical mode with an external keyboard and mouse?
- if the chassis is an off-the-shelf model, as has been mentioned, have you found any accessories that are available outside of Purism?
Thanks
edit: typo
Yes, really need a forum category to be created for discussion that is specific to the Librem 11. @joao.azevedo ?
+1
(A post must have 10 chars
The lead time of the L11 has now increased to 3 business weeks ![]()
Strange there is no talk about a screen protector for this device, nor I can see any in the accessories. Does it not need one? Does the screen not get scratched?
Doesn’t the L11 come with:
" Detachable Keyboard
Every Librem 11 comes with a keyboard that can be used as a protective sleeve for the tablet when folded. The keyboard doesn’t require any extra battery and attaches to the Librem 11 through a secure hard-wired USB connection."
copied from: Purism - – Librem 11
when folded
Those are the key words.
I am talking about protecting the screen from scratches when unfolded — when the screen is being used and gets touched by fingers, pencils and what not.
You could check out the company Via Screens. They have made screen protectors for the Librem 5, Nexdock, and a whole bunch of other devices. You can even email them to consider making one for your device if it is not listed.
