Interesting. Yes, I’ve noticed that everybody in Europe uses WhatsApp, to avoid the cellular providers’ charges, I guess. It’s just too bad that Facebook owns it now. For that reason alone, I know I’ll never use it.
Wi-Fi Hotspot setting:
The setting is there but is it actually working?
In my experience (may not apply at all), when you use WiFi Hotspot, you need to have the cellular modem enabled - because the phone will route (and probably NAT) from the WLAN to the internet via the cellular modem.
I think someone was working on displaying the Hotspot’s access details (SSID and PSK) as a QR code, so another phone could scan the QR code and use the Hotspot. (Not sure I would have much use for that since most of the time the other phone can access the internet directly, but it’s something I would test.)
A full Thai VKB would be nice, as my SO is Thai.
While I have changed keyboards in phosh, I could never get the Thai language to show up on squeekboard.
I haven’t tried it yet, but I’ll check it out and report back…unless Purism can tell us the answer here first. I haven’t had my coffee yet, nor have I ever tried to use a hotspot before.
One use case I’m aware of is, say, you’re traveling overseas with another person and only one person has cellular data. You could use the hotspot to share your data connection with your travel companion. (Or you’re in an area where your SIM has coverage, but the other person’s SIM does not.)
Thai, Thai (Pattachote), and Thai (TIS-820.2538) are listed as options in Input Sources/Choose keyboard layouts or input methods. I tested them and the keyboard didn’t change from the Latin alphabet.
Thai is not one of the options under Language or Formats.
In the store repository, I searched and found “Thai X terminal” which supports Thai (TIS-620 encoding), but didn’t install it.
I have turned in a college essay while in a moving car using my laptop connected to my phone’s hotspot. It might be easier for you to just try and connect with your computer versus a phone, particularly for troubleshooting.
I have used android hotspot at a location without Ethernet and wifi internet access to connect my laptop via the phone’s hotspot via cellular radio to the internet.
I wonder if the tethering / hotspot stuff is the same WLAN station mode as with ordinary access point or if it is an ad-hoc mode and if a phone or a laptop could act as a kind of repeater or mesh station.
Also: to connect a separate tablet or laptop via the hotspot.
Thai (like many other) translations and keyboard layout haven’t been done or aren’t quite finished, so there probably isn’t anything to change to (hence the default), I’d quess. There are some chalenges to do translations but the keyboard for Thai has been at least started, as can be seen from the link.
For anyone else: layout process is less painless at the moment (and more important in my oppinion), as it’s directly under Purism (and @dcz) - see tutorial.
I found a FOSS keyboard on Android for Thai, I could de-compile the APK and try to work on the Thai layout for Squeekboard
If I got help with any upstreaming if it looked good, I’d be glad to.
Using the L5 as hotspot, my Android appears to connect and have a low-strength connection, but the browser says there’s no internet connection, and an email won’t send when I try.
Using the Android as a hotspot and connecting the L5 works fine.
I personally, am checking my email every day…
I wonder, if it’d be possible to have GNOME and Phosh running concurrently, then have phosh turn off upon docking, then everything “refresh” for GNOME
GNOME 40 would look amazing on the L5 if it could be done… But considering PureOS lags a bit behind Debian Bullseye (I presume) it might be a bit. Bringing back auto rotate would be nice as a toggle-able feature.
How about convergence =)
Do you have an adapter to use the L5 with an external monitor? Than you would not have to send emails around.
Unfortunately, no.
I recommend that you file an issue report about the Thai keyboard not working for you:
