Is night light working on Librem 5 (PureOS) ?
I don’t see it taking it effect so wanted to check.
Yes it does:
Settings -> Display -> Night Light.
It’s basically screen filter. It makes display yellow-ish
Settings/Displays/Night Light: I do not notice any change. And, I recall now:
That feature it not yet available to L5, it need work on kernel. I waiting this feature too to mitigate invisible blue light.
In this post, @dos said:
What does this mean? Does this prevent the gammastep package from working too?
Is it still a work in progress? Thanks in advance
They are probably busy with something more important
I’ll wait
Thanks
I just noticed yesterday that pinephone-pro already support linux-gamma-ramps, it is a shame that the librem 5 still not.
Let’s see if Nigh Light got fixed for Librem 5 in Phosh 0.34.0 @rekotc
Yes, yes i know BUT Purism need to Enable for Librem 5 too NOT just for Painphone. I don’t want to imagine that Purism is Fixing Issues for Bad Designed devices and moreover is not part of Purism and of course these types of things happen in opensource world and I wouldn’t be surprised and of course is Ridiculous.
So let is cross the fingers to get enabled to Librem 5 too through Gnu Core. ![]()
Open source is for everybody, included what some consider enemies. IMO this war against pinephone is counterproductive, we are all in the same boat trying to create the linux mobile ecosystem.
Lol Linux mobile already exist from Android, not sure what you talk about it. If you want to mean else be more specific. ![]()
OK Enjoy it! But Remember that this is a Free Software Forum From PureOS where i am. You will never Find me on opensources oses Forums like Manjaro, Mints, Jolla, Pain64, System78, Whatever. So YOU need be more Honest. If you do not know what is going on… please read books about it.
Looks like it’s still not implemented. Is there any other way to enable it?
I mean other than through gnome settings.
If I understand correctly, it’s a firmware issue. You won’t be able to switch it any other way until display firmware supports it.
I searched Issues · Librem5 / OS-issues · GitLab for ‘night light’ and only hit I got was Adjust display brightness to ambient light level
Enabling DRM Gamma LUT make GnuCrimson and GnuL5 Atractive.
The GNU Autotools
grok bot says changing from phosh to phoc is most feasible solution at this time
The quickest real fix is a change to phoc, Phosh’s compositor, not a new display driver. phoc could apply the night light color curve itself in one extra GPU pass over the whole screen. That’s roughly 1–3 weeks for someone who knows wlroots (the library phoc is built on) and OpenGL ES. The cost is some battery, but only while night light is on. Nobody has started it, and Phosh’s GitLab would accept it upstream.
