Output of dmesg command:
purism@pureos:~$ sudo dmesg
[sudo] password for purism:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.13.0-1-librem5 (builder@cumin-landing-arm64-ulk7) (aarch64-linux-gnu-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP PREEMPT Wed Oct 27 08:25:29 PDT 2021
[ 0.000000] Machine model: Purism Librem 5r4
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] On node 0 totalpages: 786432
[ 0.000000] DMA zone: 12288 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 786432 pages, LIFO batch:63
[ 0.000000] cma: Reserved 320 MiB at 0x00000000e4400000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 31 pages/cpu s89496 r8192 d29288 u126976
[ 0.000000] pcpu-alloc: s89496 r8192 d29288 u126976 alloc=31*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 774144
[ 0.000000] Kernel command line: u_boot_version=2019.04-g17a6c2261c console=ttymxc0,115200 quiet fsck.repair=yes security=apparmor splash plymouth.ignore-serial-consoles vt.global_cursor_default=0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 2668772K/3145728K available (12160K kernel code, 2588K rwdata, 4628K rodata, 4160K init, 569K bss, 149276K reserved, 327680K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 38597 entries in 151 pages
[ 0.000000] ftrace: allocated 151 pages with 5 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 128 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] random: get_random_bytes called from start_kernel+0x400/0x5e0 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 8.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.000470] Console: colour dummy device 80x25
[ 0.000510] Calibrating delay loop (skipped), value calculated using timer frequency… 16.66 BogoMIPS (lpj=33333)
[ 0.000524] pid_max: default: 32768 minimum: 301
[ 0.000609] LSM: Security Framework initializing
[ 0.000697] AppArmor: AppArmor initialized
[ 0.000748] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000773] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002437] rcu: Hierarchical SRCU implementation.
[ 0.003415] smp: Bringing up secondary CPUs …
[ 0.003954] Detected VIPT I-cache on CPU1
[ 0.003988] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.004034] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.004596] Detected VIPT I-cache on CPU2
[ 0.004616] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.004641] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.005186] Detected VIPT I-cache on CPU3
[ 0.005206] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.005230] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.005304] smp: Brought up 1 node, 4 CPUs
[ 0.005317] SMP: Total of 4 processors activated.
[ 0.005322] CPU features: detected: 32-bit EL0 Support
[ 0.005329] CPU features: detected: CRC32 instructions
[ 0.013512] CPU: All CPU(s) started at EL2
[ 0.013541] alternatives: patching kernel code
[ 0.015141] devtmpfs: initialized
[ 0.023937] KASLR disabled due to lack of seed
[ 0.024116] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.024135] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.037255] pinctrl core: initialized pinctrl subsystem
[ 0.038329] NET: Registered protocol family 16
[ 0.040110] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.040317] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.040619] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.040688] audit: initializing netlink subsys (disabled)
[ 0.040842] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.041281] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.041288] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.041752] cpuidle: using governor menu
[ 0.041970] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.042055] ASID allocator initialised with 65536 entries
[ 0.042151] Serial: AMBA PL011 UART driver
[ 0.051379] debugfs: Directory ‘dummy-syscon@30340000’ with parent ‘regmap’ already present!
[ 0.051726] imx8mq-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.057934] platform 30a00000.mipi-dsi: Fixing up cyclic dependency with 30320000.lcd-controller
[ 0.061034] platform 30a90000.csi1_bridge: Fixing up cyclic dependency with 30a70000.mipi_csi1
[ 0.061626] platform 30b80000.csi2_bridge: Fixing up cyclic dependency with 30b60000.mipi_csi2
[ 0.063517] platform 32e00000.display-controller: Fixing up cyclic dependency with 32c00000.hdmi
[ 0.077548] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.077563] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.077570] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.077577] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.079011] cryptd: max_cpu_qlen set to 1000
[ 0.083750] iommu: Default domain type: Translated
[ 0.083925] vgaarb: loaded
[ 0.084242] SCSI subsystem initialized
[ 0.084279] libata version 3.00 loaded.
[ 0.084763] pps_core: LinuxPPS API ver. 1 registered
[ 0.084770] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.084788] PTP clock support registered
[ 0.085927] clocksource: Switched to clocksource arch_sys_counter
[ 0.138401] VFS: Disk quotas dquot_6.6.0
[ 0.138465] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.138996] AppArmor: AppArmor Filesystem Enabled
[ 0.145457] NET: Registered protocol family 2
[ 0.145654] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.147602] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.147660] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.147912] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.148459] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.148567] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.148660] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.148863] NET: Registered protocol family 1
[ 0.149295] RPC: Registered named UNIX socket transport module.
[ 0.149301] RPC: Registered udp transport module.
[ 0.149306] RPC: Registered tcp transport module.
[ 0.149310] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.149321] PCI: CLS 0 bytes, default 64
[ 0.149529] Unpacking initramfs…
[ 0.150003] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.155609] Initialise system trusted keyrings
[ 0.155746] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.160671] zbud: loaded
[ 0.161990] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.162596] NFS: Registering the id_resolver key type
[ 0.162625] Key type id_resolver registered
[ 0.162630] Key type id_legacy registered
[ 0.162711] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.162724] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.207181] Key type asymmetric registered
[ 0.207204] Asymmetric key parser ‘x509’ registered
[ 0.207273] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.216752] SoC: i.MX8MQ revision 2.1
[ 0.217598] debugfs: Directory ‘dummy-reset-controller@30390000’ with parent ‘regmap’ already present!
[ 0.220240] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.222311] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 41, base_baud = 1562500) is a IMX
[ 0.240221] printk: console [ttymxc0] enabled
[ 0.240992] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 42, base_baud = 1562500) is a IMX
[ 0.241470] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 43, base_baud = 1562500) is a IMX
[ 0.241585] serial serial0: tty port ttymxc1 registered
[ 0.242039] 30a60000.serial: ttymxc3 at MMIO 0x30a60000 (irq = 51, base_baud = 1562500) is a IMX
[ 0.250468] loop: module loaded
[ 0.252116] libphy: Fixed MDIO Bus: probed
[ 0.252688] i2c /dev entries driver
[ 0.261877] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.263265] sdhci: Secure Digital Host Controller Interface driver
[ 0.263273] sdhci: Copyright© Pierre Ossman
[ 0.263295] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.264751] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.265034] hid: raw HID events driver © Jiri Kosina
[ 0.265615] ashmem: initialized
[ 0.270362] NET: Registered protocol family 26
[ 0.270502] NET: Registered protocol family 17
[ 0.270828] 9pnet: Installing 9P2000 support
[ 0.270876] Key type dns_resolver registered
[ 0.271170] registered taskstats version 1
[ 0.271184] Loading compiled-in X.509 certificates
[ 0.271458] zswap: loaded using pool lzo/zbud
[ 0.271712] Key type ._fscrypt registered
[ 0.271719] Key type .fscrypt registered
[ 0.271723] Key type fscrypt-provisioning registered
[ 0.271867] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.287610] gpio-1 (pmic-5v-hog): hogged as input
[ 0.294513] AUD_1V8: supplied by AUDIO_PWR_EN
[ 0.294773] CAMERA_VDDIO_1V8: supplied by VDD_3V3
[ 0.294924] reg-fixed-voltage regulator-vcam-2v8: nonexclusive access to GPIO for regulator-vcam-2v8
[ 0.295032] CAMERA_VDDA_2V8: supplied by VDD_3V3
[ 0.295816] LCD_3V4: supplied by VSYS_3V4
[ 0.296131] 3V3_WIFI: supplied by VDD_3V3
[ 0.383947] ldo5: supplied by buck6
[ 0.389471] ldo6: supplied by buck7
[ 0.401987] rtc-m41t80 0-0068: registered as rtc0
[ 0.402761] random: fast init done
[ 0.402940] rtc-m41t80 0-0068: setting system clock to 2021-11-02T15:35:37 UTC (1635867337)
[ 0.403017] i2c i2c-0: IMX I2C adapter registered
[ 0.405071] LCD_AVDD: supplied by LCD_3V4
[ 0.406230] LCD_AVEE: supplied by LCD_3V4
[ 0.407134] i2c i2c-1: IMX I2C adapter registered
[ 0.408856] i2c 2-0020: Fixing up cyclic dependency with 30a70000.mipi_csi1
[ 0.410015] i2c i2c-2: IMX I2C adapter registered
[ 0.411703] i2c 3-002d: Fixing up cyclic dependency with 30b60000.mipi_csi2
[ 0.416702] i2c i2c-3: IMX I2C adapter registered
[ 0.421164] etnaviv etnaviv: bound 38000000.gpu (ops gpu_ops)
[ 0.421196] etnaviv-gpu 38000000.gpu: model: GC7000, revision: 6214
[ 0.421642] [drm] Initialized etnaviv 1.3.0 20151214 for etnaviv on minor 0
[ 0.423136] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 3 mkt segment 0 supported-hw 0x8 0x1
[ 0.425356] sdhci-esdhc-imx 30b50000.mmc: allocated mmc-pwrseq
[ 0.430194] VDD_1V8: supplied by buck7
[ 0.431873] nwl-dsi 30a00000.mipi-dsi: [drm:nwl_dsi_probe] Using LCDIF as input source
[ 0.433523] CAMERA_VDDD_1V2: supplied by VDD_1V8
[ 0.433689] LCD_1V8: supplied by VDD_1V8
[ 0.437705] led-backlight backlight-dsi: Not enough levels defined
[ 0.438192] nwl-dsi 30a00000.mipi-dsi: [drm:nwl_dsi_host_attach] lanes=4, format=0x0 flags=0x7
[ 0.438213] panel-mantix-mlaf057we51 30a00000.mipi-dsi.0: 720x1440@63 24bpp dsi 4dl - ready
[ 0.439174] [drm] Initialized mxsfb-drm 1.0.0 20160824 for 30320000.lcd-controller on minor 1
[ 0.469974] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 0.610810] mmc0: new HS400 MMC card at address 0001
[ 0.611400] mmcblk0: mmc0:0001 032G32 29.1 GiB
[ 0.611573] mmcblk0boot0: mmc0:0001 032G32 4.00 MiB
[ 0.611733] mmcblk0boot1: mmc0:0001 032G32 4.00 MiB
[ 0.611856] mmcblk0rpmb: mmc0:0001 032G32 4.00 MiB, chardev (245:0)
[ 0.613258] mmcblk0: p1 p2
[ 0.620204] Console: switching to colour frame buffer device 90x90
[ 0.646535] mxsfb 30320000.lcd-controller: [drm] fb0: mxsfb-drmdrmfb frame buffer device
[ 0.648974] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 0.650161] input: bd718xx-pwrkey as /devices/platform/soc@0/30800000.bus/30a20000.i2c/i2c-0/0-004b/gpio-keys.0.auto/input/input1
[ 2.242694] Freeing initrd memory: 62728K
[ 2.465948] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 2.469446] Freeing unused kernel memory: 4160K
[ 2.469501] Run /init as init process
[ 2.469505] with arguments:
[ 2.469509] /init
[ 2.469512] splash
[ 2.469516] with environment:
[ 2.469519] HOME=/
[ 2.469522] TERM=linux
[ 2.469525] u_boot_version=2019.04-g17a6c2261c
[ 2.484709] mmc1: new high speed SDIO card at address fffd
[ 3.027809] edt_ft5x06 2-0038: probing for EDT FT5x06 I2C
[ 3.031877] edt_ft5x06 2-0038: Model “EP0700M09”, Rev. “\x01”, 0x0 sensors
[ 3.034133] input: EP0700M09 as /devices/platform/soc@0/30800000.bus/30a40000.i2c/i2c-2/2-0038/input/input2
[ 3.034305] edt_ft5x06 2-0038: EDT FT5x06 initialized: IRQ 96, WAKE pin -1, Reset pin -1.
[ 3.043179] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 3.056426] input: pwm-vibrator as /devices/platform/vibrator/input/input3
[ 3.065315] bq25890-charger 3-006a: Got otg gpio hack
[ 3.065523] bq25890-charger 3-006a: Failed to register power supply
[ 3.112887] bq25890-charger 3-006a: Got otg gpio hack
[ 3.113446] bq25890-charger 3-006a: No battery found: -19
[ 3.113459] bq25890-charger 3-006a: Upstream supply changed: 0.
[ 3.113467] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 3.118019] bq25890-charger 3-006a: Upstream supply changed: 0.
[ 3.118048] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 3.118503] cdns-mhdp-imx 32c00000.hdmi: [drm:cdns_mhdp_read_fw_version [cdns_mhdp_drmcore]] firmware version: 50d385ac
[ 3.119830] imx-dcss 32e00000.display-controller: bound 32c00000.hdmi (ops cdns_mhdp_imx_ops [cdns_mhdp_imx])
[ 3.120068] [drm] Initialized imx-dcss 1.0.0 20190917 for 32e00000.display-controller on minor 2
[ 3.120607] [drm] Connector status: 0
[ 3.120636] imx-dcss 32e00000.display-controller: [drm] Cannot find any crtc or sizes
[ 3.121961] [drm] Connector status: 0
[ 3.121996] imx-dcss 32e00000.display-controller: [drm] Cannot find any crtc or sizes
[ 3.122352] bq25890-charger 3-006a: Upstream supply changed: 0.
[ 3.122362] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 3.122525] [drm] Connector status: 0
[ 3.122539] imx-dcss 32e00000.display-controller: [drm] Cannot find any crtc or sizes
[ 3.146937] usbcore: registered new interface driver usbfs
[ 3.146981] usbcore: registered new interface driver hub
[ 3.147050] usbcore: registered new device driver usb
[ 3.155742] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 3.155772] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[ 3.155868] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000000010010
[ 3.155925] xhci-hcd xhci-hcd.4.auto: irq 65, io mem 0x38200000
[ 3.156153] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[ 3.156162] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.156168] usb usb1: Product: xHCI Host Controller
[ 3.156173] usb usb1: Manufacturer: Linux 5.13.0-1-librem5 xhci-hcd
[ 3.156177] usb usb1: SerialNumber: xhci-hcd.4.auto
[ 3.156513] hub 1-0:1.0: USB hub found
[ 3.156536] hub 1-0:1.0: 1 port detected
[ 3.156788] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 3.156798] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[ 3.156807] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 3.156853] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.156923] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[ 3.156930] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.156936] usb usb2: Product: xHCI Host Controller
[ 3.156941] usb usb2: Manufacturer: Linux 5.13.0-1-librem5 xhci-hcd
[ 3.156945] usb usb2: SerialNumber: xhci-hcd.4.auto
[ 3.157270] hub 2-0:1.0: USB hub found
[ 3.157291] hub 2-0:1.0: 1 port detected
[ 3.213937] [drm] Connector status: 0
[ 3.392340] random: lvm: uninitialized urandom read (4 bytes read)
[ 3.417970] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 3.566097] usb 1-1: New USB device found, idVendor=0424, idProduct=2640, bcdDevice= 9.02
[ 3.566117] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.605636] hub 1-1:1.0: USB hub found
[ 3.605739] hub 1-1:1.0: 3 ports detected
[ 3.898461] usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
[ 4.007030] usb 1-1.1: New USB device found, idVendor=0424, idProduct=4041, bcdDevice= 2.09
[ 4.007051] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.007057] usb 1-1.1: Product: Ultra Fast Media Reader
[ 4.007062] usb 1-1.1: Manufacturer: Generic
[ 4.007066] usb 1-1.1: SerialNumber: 000008264001
[ 4.013841] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 4.014802] scsi host0: usb-storage 1-1.1:1.0
[ 4.015114] usbcore: registered new interface driver usb-storage
[ 4.016471] usbcore: registered new interface driver uas
[ 5.029413] scsi 0:0:0:0: Direct-Access Generic Ultra HS-SD/MMC 2.09 PQ: 0 ANSI: 0
[ 5.034101] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 9.078594] random: crng init done
[ 11.227974] [drm] Connector status: 0
[ 14.740284] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 15.167773] NET: Registered protocol family 10
[ 15.170771] Segment Routing with IPv6
[ 15.203522] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 15.204460] systemd[1]: Detected architecture arm64.
[ 15.207166] systemd[1]: Set hostname to .
[ 16.036185] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 16.129747] systemd[1]: Queued start job for default target Graphical Interface.
[ 16.133225] systemd[1]: Created slice system-getty.slice.
[ 16.134152] systemd[1]: Created slice system-modprobe.slice.
[ 16.135014] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 16.135760] systemd[1]: Created slice Cryptsetup Units Slice.
[ 16.136470] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 16.137058] systemd[1]: Created slice User and Session Slice.
[ 16.137271] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 16.137819] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 16.138193] systemd[1]: Reached target User and Group Name Lookups.
[ 16.138258] systemd[1]: Reached target Slices.
[ 16.138327] systemd[1]: Reached target Swap.
[ 16.138601] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 16.138971] systemd[1]: Listening on LVM2 poll daemon socket.
[ 16.139244] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 16.139411] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 16.139912] systemd[1]: Listening on Journal Audit Socket.
[ 16.140205] systemd[1]: Listening on Journal Socket (/dev/log).
[ 16.140569] systemd[1]: Listening on Journal Socket.
[ 16.140982] systemd[1]: Listening on Network Service Netlink Socket.
[ 16.141381] systemd[1]: Listening on udev Control Socket.
[ 16.141666] systemd[1]: Listening on udev Kernel Socket.
[ 16.144474] systemd[1]: Mounting Huge Pages File System…
[ 16.147683] systemd[1]: Mounting POSIX Message Queue File System…
[ 16.151676] systemd[1]: Mounting Kernel Debug File System…
[ 16.154712] systemd[1]: Mounting Kernel Trace File System…
[ 16.155345] systemd[1]: Finished Availability of block devices.
[ 16.161217] systemd[1]: Starting Set the console keyboard layout…
[ 16.164379] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 16.167665] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 16.171368] systemd[1]: Starting Load Kernel Module configfs…
[ 16.174846] systemd[1]: Starting Load Kernel Module drm…
[ 16.178379] systemd[1]: Starting Load Kernel Module fuse…
[ 16.180358] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 16.180557] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 16.185663] systemd[1]: Starting Journal Service…
[ 16.190544] systemd[1]: Starting Load Kernel Modules…
[ 16.194351] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 16.197709] systemd[1]: Starting Coldplug All udev Devices…
[ 16.206184] systemd[1]: Mounted Huge Pages File System.
[ 16.207978] systemd[1]: Mounted POSIX Message Queue File System.
[ 16.209180] fuse: init (API version 7.34)
[ 16.212556] systemd[1]: Mounted Kernel Debug File System.
[ 16.220253] systemd[1]: Mounted Kernel Trace File System.
[ 16.221764] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 16.223882] systemd[1]: modprobe@configfs.service: Succeeded.
[ 16.225197] systemd[1]: Finished Load Kernel Module configfs.
[ 16.228363] systemd[1]: modprobe@drm.service: Succeeded.
[ 16.229251] systemd[1]: Finished Load Kernel Module drm.
[ 16.230414] systemd[1]: modprobe@fuse.service: Succeeded.
[ 16.231216] systemd[1]: Finished Load Kernel Module fuse.
[ 16.235403] systemd[1]: Mounting FUSE Control File System…
[ 16.238533] systemd[1]: Mounting Kernel Configuration File System…
[ 16.244189] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 16.257334] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 16.258068] systemd[1]: Mounted FUSE Control File System.
[ 16.259954] systemd[1]: Mounted Kernel Configuration File System.
[ 16.267033] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 16.267263] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 16.270485] systemd[1]: Starting Load/Save Random Seed…
[ 16.284369] systemd[1]: Starting Create System Users…
[ 16.286199] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 16.287763] systemd[1]: Finished Load Kernel Modules.
[ 16.291186] systemd[1]: Starting Apply Kernel Variables…
[ 16.305191] systemd[1]: Finished Load/Save Random Seed.
[ 16.307969] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 16.329978] systemd[1]: Finished Create System Users.
[ 16.331527] systemd[1]: Finished Apply Kernel Variables.
[ 16.334654] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 16.371178] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 16.375885] systemd[1]: Starting Rule-based Manager for Device Events and Files…
[ 16.376330] systemd[1]: Started Journal Service.
[ 16.401174] systemd-journald[386]: Received client request to flush runtime journal.
[ 16.409230] systemd-journald[386]: File /var/log/journal/9b43caf3619f49f8ba467ec270970f44/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 17.023243] imx-sdma 302c0000.sdma: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 17.023268] imx-sdma 302c0000.sdma: external firmware not found, using ROM firmware
[ 17.026921] imx-sdma 30bd0000.sdma: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 17.026945] imx-sdma 30bd0000.sdma: external firmware not found, using ROM firmware
[ 17.040916] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input4
[ 17.095808] caam 30900000.crypto: Entropy delay = 3200
[ 17.095901] caam 30900000.crypto: Entropy delay = 3600
[ 17.106299] mc: Linux media interface: v0.10
[ 17.130572] videodev: Linux video capture interface: v2.00
[ 17.131361] gnss: GNSS driver registered with major 241
[ 17.141351] s5k3l6xx 3-002d: using default 24000000 Hz clock frequency
[ 17.141402] : probe sd ffff0000bc3d0260
[ 17.141410] S5K3L6-CIS 3-002d: probe i2c ffff000001aef000
[ 17.145781] mousedev: PS/2 mouse device common for all mice
[ 17.147483] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
[ 17.147595] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at endpoint@1 XXX found
[ 17.147614] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
[ 17.148612] s5k3l6xx 3-002d: model low: 0x30
[ 17.149080] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
[ 17.149340] s5k3l6xx 3-002d: model high: 0xC6
[ 17.149440] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at endpoint@1 XXX found
[ 17.149462] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 2, name: mxc-mipi-csi2.1
[ 17.149693] hi846 2-0020: chip id 08 46 using 2 mipi lanes
[ 17.153454] mxc-mipi-csi2_yav 30a70000.mipi_csi: Registered sensor subdevice: hi846 2-0020
[ 17.153789] s5k3l6xx 3-002d: revision number: 0xB0
[ 17.153856] mxc-mipi-csi2_yav 30b60000.mipi_csi: Registered sensor subdevice: S5K3L6-CIS 3-002d
[ 17.154582] wm8962_i2c_probe: 3559: defering probe
[ 17.166750] caam 30900000.crypto: Instantiated RNG4 SH0
[ 17.196000] wm8962 2-001a: customer id 0 revision D
[ 17.198235] mx6s-csi 30a90000.csi1_bridge: initialising
[ 17.200929] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
[ 17.200949] mx6s-csi 30a90000.csi1_bridge: register async notifier success
[ 17.201207] mx6s-csi 30b80000.csi2_bridge: initialising
[ 17.202348] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
[ 17.202362] mx6s-csi 30b80000.csi2_bridge: register async notifier success
[ 17.234258] caam 30900000.crypto: Instantiated RNG4 SH1
[ 17.234285] caam 30900000.crypto: device ID = 0x0a16040100000000 (Era 9)
[ 17.234291] caam 30900000.crypto: job rings = 3, qi = 0
[ 17.278410] input: WM8962 Beep Generator as /devices/platform/soc@0/30800000.bus/30a40000.i2c/i2c-2/2-001a/input/input6
[ 17.368024] wm8962 2-001a: ASoC: error at soc_component_read_no_lock on wm8962.2-001a: -16
[ 17.378190] wm8962 2-001a: ASoC: error at soc_component_read_no_lock on wm8962.2-001a: -16
[ 17.389747] input: Librem 5 Headphones as /devices/platform/sound/sound/card0/input5
[ 17.401053] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.416086] hantro-vpu 38300000.video-codec: registered nxp,imx8mq-vpu-dec as /dev/video2
[ 17.556734] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 17.585297] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 17.589966] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 17.648871] [drm] Connector status: 0
[ 17.735440] Bluetooth: Core ver 2.22
[ 17.735564] NET: Registered protocol family 31
[ 17.735569] Bluetooth: HCI device and connection manager initialized
[ 17.735588] Bluetooth: HCI socket layer initialized
[ 17.735597] Bluetooth: L2CAP socket layer initialized
[ 17.735766] Bluetooth: SCO socket layer initialized
[ 17.764306] redpine_91x: rsi_probe: ***** 9116 Module *****
[ 17.766061] redpine_91x: redpine_hal_device_init: oper_mode = 5, coex_mode = 2
[ 17.767239] redpine_91x: Received Board Version Number: 10
[ 17.768329] redpine_91x: rsi_load_firmware: Loading file RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 17.768425] RSI-SDIO WLAN mmc1:fffd:1: Direct firmware load for RS9116_NLINK_WLAN_BT_IMAGE.rps failed with error -2
[ 17.768436] redpine_91x: rsi_load_firmware: Failed to open file RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 17.780562] redpine_91x: ***** Loaded Firmware *****
[ 18.198854] ext2 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[ 18.228243] spi-nor spi0.0: s25fl016k (2048 Kbytes)
[ 18.256021] 3 fixed-partitions partitions found on MTD device spi0.0
[ 18.256043] Creating 3 MTD partitions on “spi0.0”:
[ 18.256050] 0x000000000000-0x000000030000 : “protected0”
[ 18.256449] 0x000000030000-0x000000040000 : “protected1”
[ 18.256686] 0x000000040000-0x000000200000 : “rw”
[ 18.400104] audit: type=1400 audit(1635867355.491:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/bin/man" pid=554 comm=“apparmor_parser”
[ 18.400134] audit: type=1400 audit(1635867355.491:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_filter” pid=554 comm=“apparmor_parser”
[ 18.400145] audit: type=1400 audit(1635867355.491:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_groff” pid=554 comm=“apparmor_parser”
[ 18.406555] audit: type=1400 audit(1635867355.499:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lsb_release” pid=553 comm=“apparmor_parser”
[ 18.419004] audit: type=1400 audit(1635867355.511:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=552 comm=“apparmor_parser”
[ 18.419035] audit: type=1400 audit(1635867355.511:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=552 comm=“apparmor_parser”
[ 18.745590] caam algorithms registered in /proc/crypto
[ 18.770392] audit: type=1400 audit(1635867355.863:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/bin/evince" pid=551 comm=“apparmor_parser”
[ 18.771129] audit: type=1400 audit(1635867355.863:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/bin/evince//sanitized_helper" pid=551 comm=“apparmor_parser”
[ 18.771330] audit: type=1400 audit(1635867355.863:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/bin/evince-previewer" pid=551 comm=“apparmor_parser”
[ 18.771489] audit: type=1400 audit(1635867355.863:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name="/usr/bin/evince-previewer//sanitized_helper" pid=551 comm=“apparmor_parser”
[ 18.778071] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
[ 18.778098] caam 30900000.crypto: registering rng-caam
[ 19.011806] using random self ethernet address
[ 19.011829] using random host ethernet address
[ 19.077869] usb0: HOST MAC da:93:bd:4a:73:9f
[ 19.078511] usb0: MAC 26:0f:6b:b6:e9:a7
[ 23.013990] redpine_91x: ================================================
[ 23.014007] redpine_91x: ================ RSI Version Info ==============
[ 23.014011] redpine_91x: ================================================
[ 23.014014] redpine_91x: FW Version : 0.2.0.16
[ 23.014021] redpine_91x: RSI FW Version : 1610.0.2.0.0024
[ 23.014027] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
[ 23.014031] redpine_91x: Operating mode : 5 [Wi-Fi STA + BT EDR]
[ 23.014036] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 23.014040] redpine_91x: ================================================
[ 23.063416] redpine_91x: <==== Interface UP ====>
[ 23.063560] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 23.063568] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates…
[ 23.070654] redpine_91x: <==== Interface DOWN ====>
[ 23.074790] redpine_91x: <==== Interface UP ====>
[ 23.074942] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 23.074951] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates…
[ 26.955268] redpine_91x: <==== Interface DOWN ====>
[ 26.960451] redpine_91x: <==== Interface UP ====>
[ 26.960558] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 26.960567] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates…
[ 30.517074] wlan0: authenticate with 78:24:af:90:8b:4c
[ 30.517420] wlan0: send auth to 78:24:af:90:8b:4c (try 1/3)
[ 30.519718] wlan0: authenticated
[ 30.530060] wlan0: associate with 78:24:af:90:8b:4c (try 1/3)
[ 30.536839] wlan0: RX AssocResp from 78:24:af:90:8b:4c (capab=0x511 status=0 aid=31)
[ 30.538011] wlan0: associated
[ 30.616531] redpine_91x: EAPOL 4 confirm
[ 30.666337] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 30.831151] Key type cifs.idmap registered
[ 30.832577] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
[ 30.844726] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
[ 30.856401] CIFS: Attempting to mount \192.168.1.1\My_Book
[ 30.987104] CIFS: VFS: cifs_mount failed w/return code = -5
[ 31.715139] AUD_1V8: disabling
[ 31.715157] CAMERA_VDDIO_1V8: disabling
[ 31.715163] CAMERA_VDDA_2V8: disabling
[ 31.715169] GNSS: disabling
[ 31.715199] CAMERA_VDDD_1V2: disabling
[ 34.249017] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 34.249058] Bluetooth: BNEP socket layer initialized
[ 34.669412] [drm] Connector status: 0
[ 40.516830] rfkill: input handler disabled
[ 44.328510] systemd-journald[386]: File /var/log/journal/9b43caf3619f49f8ba467ec270970f44/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 44.936458] rfkill: input handler enabled
[ 46.372438] [drm] Connector status: 0
[ 50.007729] rfkill: input handler disabled
[ 58.124489] s5k3l6xx 3-002d: fsize i 3 m 3
[ 58.193802] s5k3l6xx 3-002d: fsize i 3 m 3
[ 188.548945] redpine_91x: Packet Dropped as RX PN is less than last received PN
[ 306.958445] edt_ft5x06 2-0038: Unable to fetch data, error: -6
