Trouble trying to use Jumpdrive: No blue LED, can't enter flash mode
Following @david.hamner 's instructions here, and here, I can’t get the Librem 5’s LED to turn blue-green, or enter flash mode. The phone either boots normally into phosh, or (apparently) fails to activate the display at all, as documented previously here. (So a lot of trial and error and rebooting.)
I did all this, as per David’s instructions:
Install
Then from either a cold start or a reboot, immediately after the power-on LED, I hold down the volume-up button, but no effect.
Any ideas, anyone, (especially from David)?
Have you noticed this thread about Jumpdrive?
Yes, thanks. I’ve seen it before, and just read through it again, but I still can’t get into flash mode.
I haven’t reviewed David’s repo shown above, but I had previously created a snippet to assist with setup on the host computer (using a PureOS live boot environment to ensure a clean starting point). The script echos various instructions to help the user perform the correct ritual on the L5 to boot into Jumpdrive:
Thanks for the response. If I understand your script, you’re installing Jumpdrive on the computer and then running the script on the computer after putting the Librem 5 in flash mode and connecting it?
My issue is that I can’t get the phone in flash mode in the first place, in order to follow David’s simple tutorial to expose the L5’s storage (via Jumpdrive installed on the L5) to a connected computer.
P.S. I have successfully got into flash mode before, when I flashed byzantium for the first time, but for some reason it’s not working at the moment. I’ve tried dozens of times today.
It installs uuu on the host computer and runs a script using the Jumpdrive repository to establish a connection with the L5, but the L5 is what’s running Jumpdrive to expose itself :see_no_evil: to the host. The rest of the script is used more as a reminder of the steps.
I just used this script last night to recover a corrupted /etc/fstab file on my phone. I’ve noticed that a successful Jumpdrive boot on my phone is noticeably more difficult to initiate when the phone is in an unbootable state (where the timing of the vol+, USB-C insert, battery insert, release vol+ is more fiddly). It took me a number of times to get it right, and it can admittedly be very frustrating. I had the best results when I performed the actions quickly - within a second or two. It sounds like your situation may be more nuanced, though…
@JCS You may want to use the artifacts from sebastiankrzyszkowiak / Jumpdrive · GitLab instead of the tagged release. It’s just the upstream’s latest commit - the last tagged release still used a very old kernel that sometimes fails to probe eMMC and requires several retries, which got fixed years ago.
It’s not fiddly at all. All you need is to hold Vol+ while turning the phone on. The only difficulty comes from lack of any feedback other than on the host the phone is plugged into.
@amarok Are the volume buttons working correctly when booted in phosh?
You need to do it before the LED goes green, and it will stay either red or disabled depending on charging status. Check lsusb on the host to see whether it’s actually on.
David’s instructions aren’t actually for booting into Jumpdrive using USB, but for installing it to use from u-boot. I’d recommend sticking to the normal procedure unless you’re familiar with u-boot. David’s method (well, it was actually a trick I once showed to him :laughing: ) does not use flashing mode at all.
Yep. No problems there.
Nearly impossible, unless…
…which does nothing on my Librem 5, confirmed by then connecting to the computer.
Good to know. (Since his video doesn’t indicate that in any way. :rofl: )
What is the blue-green LED he mentioned supposed to indicate?
OK, I will, because I’m not. :laughing:
I’m familiar with the usual battery-shuffle, claw-grip steps for the flashing procedure, but today I just wanted to learn how to use Jumpdrive to expose the storage to a computer. Not something I need at the moment, but I wanted to see how it’s done. Wasn’t planning on actually reflashing.
I do have this complication, though, so maybe I should reflash. Not sure if that would correct it, however.
The thing is … the “battery-shuffle, claw-grip steps” are actually to put the phone in Serial Download mode. In that mode it will do whatever the host tells it (over USB). The host can tell it to
  • load a disk image over USB and use it to reflash the eMMC drive, or
  • load Jumpdrive over USB and then boot it, and thereby expose its disk or disks as USB mass storage device class devices (and also allow network access in to the phone), or
  • other things.
There must be something really obvious and simple that we’re missing, because if volume buttons work just fine while the phone is booted then there’s really no way that the button won’t be able to put the phone into flashing mode, as this is handled in hardware by SoC’s ROM before any kind of mutable software gets a chance to be executed. Technically you could disable it by burning e-fuses inside the ROM, but somehow I doubt that you have done that on your device :wink:
If you take the battery out, hold the Vol+ button and keep holding it while plugging USB-C in - what happens? Describe both the LED behavior and what happens on the host that you plug it into (what appears in dmesg and lsusb after plugging it in).
Try both USB-C orientations and make sure the same cable works fine on the same port when the phone is booted, so we know that the connection is good.
Worth throwing out there that I’ve encountered some USB-C cables that are not reversible for data as well as some that have other quirks of things not working right, may be worth trying another cable.
Absolutely nothing. No LED.
lsusb doesn’t show it.
dmesg does show Purism Librem 5.
Replacing battery does enable lsusb to see it as well. (As connecting to a power source does cause the L5 to power on involuntarily, and as I do have that issue where the screen frequently doesn’t activate on the first try, I took the extra trial-and-error step of getting the screen to activate and then booting into phosh, and shutting down, all while still connected, just to confirm the lsusb and dmesg output.)
I’m not sure why the procedure worked when I flashed byzantium over a year ago, but doesn’t seem to work now.
I tried both a Sony Android cable (which is what I used to reflash before) in both a USB3 and USB2 slot, in two orientations, and the standard Librem 5 cable in four different orientations. Same same.
Have you been using the sugested jumpdrive version from @dos ?
So I can’t even get to the point where I would be able to use any Jumpdrive version, unfortunately.
P.S. My current goal was not to reflash the OS, but just to get some experience using Jumpdrive to expose the L5’s storage to a connected computer. But not being able to enter Serial Mode is the actual problem at this point.
Help, please! I’ve same Amarok problem: I modified LUKS password but, now, my new password doesn’t work at boot so I decided to flash my L5 pressing volume up + power but doesn’t work! I did it several times also leaving out my Purism PGP card and sdcard, all three hot keys on and then all three off, also I tried without battery using usb cable connected to PC but, in this last case, please see what happens: (I had to convert my video in gif to be able to upload it here so, please, include a pulsing buzz noise too).
My volume button works well.
Please help, I don’t know what to do :sob::pray:
Thank you
trim.2651C4C7-947A-4BCC-8EAC-417D12E87E90
I’m trying to download PureOS image and install into my microsd card and try to install from it if, at turning on, L5 will choose first my card instead of internal disk. I’ll let you know, thank you!
Just realised that there isn’t an image file .iso for ARM processor so I’m doing it on my PC hoping to be able to move into my microsd card when finished.
Please what can I do, now?
I don’t know the command to try again
Clean with 100% isopropyl and a small toothbrush for clean Librem 5 usb-c port. DO NOT use it generic usb-c cable for Librem 5, use a Gnuine. Try again.
Ciao, @veleno. It’s not clear what exactly you’ve tried or not tried, but I suggest starting over and following this updated flashing guide: Reflashing the Librem 5, Up-to-Date Tutorial .
Note that you need to start on a computer running a fairly recent OS version, (Debian, PureOS, etc.). Which OS is your computer running?
If you’re doing this on the microsd card in your Librem 5, I think you’re going to run into problems. I suggest following the tutorial I linked instead.
In that first screenshot, it looks like you are installing uuu too late, in the wrong order. Again, follow the tutorial.
Also see: Successfully reflashed, but at first no LED at entering Serial Download mode
P.S. When flashing, I’ve twice used the USB-A to USB-C cable that came with my Android, and it worked just fine.
Hold the vol+ button while the phone is in the state seen on that GIF. Does the blinking stop?
