US Carriers / IMEI Compatibility Checker
T-mobile USA IMEI checker: https://www.t-mobile.com/resources/bring-your-own-phone
Cricket Wireless IMEI checker*: https://www.cricketwireless.com/cell-phones/bring-your-phone
Verizon Wireless IMEI checker**: https://www.verizon.com/od/prepaid/bring-your-own-device/#/deviceDetails
*AT&T no longer has an IMEI checker on its website, but they own Cricket Wireless, which does provide one, and uses AT&T’s network.
**For Verizon, you can skip the make and model info; then choose “I’m not sure” for the question about where you purchased the device.
This also applies to all the MVNOs that run on the above major networks.
EDIT: Linked this to: https://source.puri.sm/Librem5/community-wiki/-/wikis/Cellular-Providers
US Cellular IMEI checker: https://www.uscellular.com/phones/bring-your-own-device#/
They run their own independent network in a limited geographic area of the US, so they’re not an MVNO, but see this for more info: https://bestmvno.com/mvnos/us-cellular/
Sprint, now owned by T-mobile, only allows an approved list (https://sprint.com/landings/bring-your-own-phone/index.html#eligible-device), or else diverts to T-mobile’s site from this landing: https://www.sprint.com/en/landings/bring-your-own-phone.html.
T-Mobile’s IMEI checker doesn’t work. When I click “Check phone”, it shows a rotating circle thing that never stops.
I just checked my IMEI and it works fine for me. Is it possible it’s a browser issue? Are you using NoScript and maybe forgot to allow the necessary items to run?
By the way, @everybody, in case you’re wondering, only T-mobile’s IMEI checker approves my BM818-A1; none of the others do.
No, I even turned off the ad blocker.
But just now, I deleted cookies for all t-mobile related domains, and then it did work. I guess they have buggy cookies.
I set cookies to always delete on exit, so maybe that’s why I didn’t have the issue.
Even if the librem phone is compatible with Verizon it still WILL NOT work for phone calls. Only when or I guess if purism gets it registered for volte (or even gets volte working in general for that matter) will it work. Texting probably won’t work either. Sorry if I sound aggressive, I have just seen way too many people who blindly believe that if the lte bands match, then the phone will automatically work on Verizon. Verizon is an *sshat when it comes to phones that they can’t inject and malwareise with their bloatware.
Source: Firsthand account of a longtime p.o.w. of verizons network who can’t seem to find a rootable (recent) verizon (volte compatible) phone that isnt a :nauseated_face::face_vomiting: google pixel!
Or when Broadmobi does, actually, since it’s the modem that has to be tested and certified, if it hasn’t been already. (It apparently has been with T-mobile.)
Currently of the 3 major carriers, T-Mobile is the only one that supports the BM818 modem. The Cellular Providers · Wiki · Librem5 / Librem 5 Community Wiki · GitLab wiki page is very out of date.
I recently changed from AT&T to Mint Mobile (a T-Mobile MVNO) on my L5. The BM818-A1 was working fine on AT&T.
Odd, spent about 6 hours trying to connect to their data network. The minute I enabled VoLTE, I received a text from AT&T that said:
Hi, it’s AT&T. The device you tried to activate does not work on our network. We’re here to help. Go to att.com/device for more info and learn how to stay connected.
I have a Librem 5 USA, which also has the BM818-A1 modem, so maybe your phone was grandfathered in and they disallowed any new ones connecting to their network?
It could also be that my SIM card was active on AT&T’s network using an Android phone before I moved it in to my L5.
Same, mine was active in my Galaxy S8 until I started randomly getting hit with “No SIM detected” errors after being on for 24+ hours.
I was able to get to an IMEI check on the AT&T website through Let's identify your device - you just select a plan first then enter the IMEI. The one I put in for my L5 USA is definitely not supported.
