How to reset gnome to defaults?
I tried enabling the “Applications menu” in “Extensions” in Gnome “Tweaks”. It doesn’t work, and now “Extnsions” shows a triangle with a “!” in it next to “Applications menu”.
How do I restore the Gnome state to its defaults?
I had the same problem when I first received my Librem back in April. I did send a note to support in case others had this issue, but I reconstructed the scenario from memory here. I hope that helps you.
You may know this, but where I say to reinstall gnome-menus, use the --reinstall option on install. Otherwise, apt will not let you do it. E.g.
sudo apt --reinstall install gnome-menus
Thanks for the tip. After reinstalling gnome-menus and rebooting, the “Applications menu” extension was on and working.
I am glad that worked for you.
