Installation failed - please help
Hi community,
I tried to install PureOS, unfortunately without suceess. Here is what I did:
Created an install drive as described here.
Using Win10 I created a blank partition on my hard drive (32 GB) and formated it with NTFS.
During Installation process I chose this blank partition for installation (step 5 in installation guide). After reviewing all definitions I started the installation. After approx. 10 min. I got following error message:
Since I am not able to interpret what I can read I urgently need your support. Thank you a lot in advance.
P.s.: Besides this problem PureOS is obviously not able to recognize my network card / wifi hardware. Because I don not have the opportunity to connect to a wifi.
For further information helpful to help me, please do not hesitate to post.
Your disk has a GPT partition table, for a Linux system to be able to install a bootloader you need to have a “BIOS boot” partition. It can be a 1 MB partition on the start of the disk, but requires bios_grub flag assigned to it.
More info:
https://wiki.archlinux.org/index.php/partitioning#Choosing_between_GPT_and_MBR
@mladen: Thank you for your reply.
How to do that? In installation guide there I have several options. I used “replace a partition”. Should I use “manual partitioning” instead? My understanding of this option is, that all data from disk will be deleted by this.
So how to handle? I am obviously no expert.
Since you probably want to retain the existing Windows partiton—then this is not a job for non experienced user. I strongly advise you to backup all your data!
If you wish to proceed: start PureOS live (download the latest tested ISO image: https://downloads.puri.sm/live/gnome/2019-04-19/) and install gparted via Tilix terminal using the following commands:
sudo apt update
sudo apt install gparted
Then start it and refer to manuals: https://gparted.org/display-doc.php%3Fname%3Dhelp-manual, to move or resize the first partition of your disk to create empty space of 1 MB (sufficient) to create another partition. Then in options assign bios_grub flag to that partition.
You probably won’t be able to boot windows after this, but if you manage to install PureOS and if you install bootloader successfully, it will contain Windows entry as well.
Thanks @mladen! Actually this post is based on what proposed when GPT format needs (or preferred as in my case scenario) to be used, under CSM Boot mode. Furthermore it might be used as sort of short guide for those that are about to throw away their old Windows7 (just if=/dev/zero it out from your SSD), or otherwise not used computers :upside_down_face:. Just don’t destroy it, please, especially if there is someone that might reuse it with PureOS (as installed below, without extra firmware that might be, in addition, needed).
I’m trying to, just in order to have have long term performance up to align-check opt from parted. It is actually simple calculation by taking number 2048 and multiplying it to the size as needed. For PureOS with GPT partition style (I’ve used five of them just as an example) we need 8 MiB or 2048×8=16384 sectors for our first partition as confirmed here:
In order to start with our installation we need to boot PureOS Amber Live or Byzantium Live image under CSM anyway (this is prerequisite here, in general), meaning Disable Secure Boot Configuration (if exists) and enable CSM Boot within your BIOS Setup.
As we just entered PureOS Live on our computer let us finally start by opening Tilix terminal:
sudo su - (optional, otherwise include sudo up front of below terminal commands)
If Ethernet communication available:
apt update
apt install pv
fdisk -l
fdisk -l /dev/dev/sd[x]
fdisk -u /dev/dev/sd[x]
Command (m for help): p
Command (m for help): g
Command (m for help): w (only if already decided to move on, backup made!)
Make sure your computer SSD (the one to be reborn again) is still healthy:
dd if=/dev/zero conv=noerror,notrunc,sync bs=4096 | pv >/dev/dev/sd[x]
gdisk /dev/sd
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
MBR: not present
BSD: not present
APM: not present
GPT: not present
Creating new GPT entries in memory.
Command (? for help): n
Partition number (1-128, default 1):
First sector (34-250069646, default = 2048) or {±}size{KMGTP}:
Last sector (2048-250069646, default = 250069646) or {±}size{KMGTP}: +16384
Current type is 8300 (Linux filesystem)
Hex code or GUID (L to show codes, Enter = 8300): ef02
Changed type of partition to ‘BIOS boot partition’
Partition number (2-128, default 2):
First sector (34-250069646, default = 18432) or {±}size{KMGTP}:
Last sector (18432-250069646, default = 250069646) or {±}size{KMGTP}: +1048576
Changed type of partition to ‘Linux filesystem’
Partition number (3-128, default 3):
First sector (34-250069646, default = 1067008) or {±}size{KMGTP}:
Last sector (1067008-250069646, default = 250069646) or {±}size{KMGTP}: +67108864
Partition number (4-128, default 4):
First sector (34-250069646, default = 68175872) or {±}size{KMGTP}:
Last sector (68175872-250069646, default = 250069646) or {±}size{KMGTP}: +33554432
Hex code or GUID (L to show codes, Enter = 8300): 8200
Changed type of partition to ‘Linux swap’
Partition number (5-128, default 5):
First sector (34-250069646, default = 101730304) or {±}size{KMGTP}:
Last sector (101730304-250069646, default = 250069646) or {±}size{KMGTP}:
Command (? for help): p
Disk /dev/sd: 250069680 sectors, 119.2 GiB
Sector size (logical/physical): 512/4096 bytes
Disk identifier (GUID): XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 250069646
Partitions will be aligned on 2048-sector boundaries
Number Start (sector) End (sector) Size Code Name
1 2048 18431 8.0 MiB EF02 BIOS boot partition
2 18432 1067007 512.0 MiB 8300 Linux filesystem
3 1067008 68175871 32.0 GiB 8300 Linux filesystem
4 68175872 101730303 16.0 GiB 8200 Linux swap
5 101730304 250069646 70.7 GiB 8300 Linux filesystem
Command (? for help): w
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): Y
OK; writing new GUID partition table (GPT) to /dev/sd.
The operation has completed successfully.
fdisk -l /dev/sd[x]
parted -s /dev/sd[x] print
parted -s /dev/sd[x] set 1 bios_grub on
Now is time to start Calamares installer (and exit Tilix). If not already said, above is prepared for:
02_17-44-45
Checking if the /dev/sd[x]1 partition is already set to ‘0xef02’ type, yet change nothing please (Cancel) within this window:
And here will be your last chance to give up on PureOS installation under CSM/GPT:
Hope this helps a bit, if not running on top of coreboot yet.
P.S. This is just simple overview, end-user perspective, no guaranty from my side whatsoever (although as described worked on my old, but reliable laptop).
yes and during the install procedure the 8 MiB (or more) bios_grub partition is formatted to ext4 … you can check this after in the Desktop-Environment after the installer wraps everything up at the end …
one thing i find confusing is the fact that the partitions are usually expressed in MiB while in the DE they are expressed in MB. the result is that the conversion yields higher MB numbers than with MiB … just make it MiB (powers of 2 NOT multiples of 10 < pretty please :pleading_face: )
Thanks @reC! Here is the first partition (the one to start with) corrected to:
gdisk /dev/sd[x]
First sector (2048-30318558, default = 2048) or {±}size{KMGTP}:
Last sector (2048-30318558, default = 30318558) or {±}size{KMGTP}: +20480
parted /dev/sd[x]
GNU Parted 3.3
Using /dev/sdq
Welcome to GNU Parted! Type ‘help’ to view a list of commands.
(parted) u MiB
(parted) p
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1.00MiB 11.0MiB 10.0MiB BIOS boot partition bios_grub
(parted) u MB
(parted) p
Disk Flags:
1 1.05MB 11.5MB 10.5MB BIOS boot partition bios_grub
