L5 - Deader Than A Doornail After Battery Ran Dry
ISSUE:
Took phone out for about 11 hours. Camera switch Off. Won’t charge again
  1. List item - Took L5 out shopping. It was working, but asleep.
  2. Got home, plugged it in. Phone was unplugged - asleep for about 11 hours.
  3. In the morning, the P5 has no lights - nothing
  4. What I did (no lights at all)
    A - Held the power button down - nothing
    B - Held power and volume up together. - nothing.
    C - Removed battery - waited a minute replaced battery - red light came on for about 10 seconds. Nothing else happens. No lights.
    D - Checked power cables - all OK
    E - Threatened it. - Nothing.
  5. I read another very similar issue here - but it’s only solution was 2 users saying they’ve never had it happen and the thread went dead - about 2 years ago.
Ideas?
~s
Edited to correct EOL.
If you can find an old li-ion battery charger for an old nokia-like cellphone, match the polarity, and tape down the wires to the + and - pads.
You can also disassemble an e-cigarette charger, same circuit inside.
If you are in a real emergency pinch and have a USB cable to sacrifice, an old one is OK, the Li-Ion battery is still safely in spec to get charged at 5v from USB-A, I would keep it to 5-10 min intervals between trying to boot up.
Could you add the following:
F. Unplug from charger and remove battery. With battery removed, plug in phone charger. Try to power on. If it powers on, let it boot up. Insert battery without powering off.
You might also read this thread: Powering the L5 without battery or USB . The last note in that thread gives a link to an external battery charger.
It has happened to me, too.
After some trial and error, I finally got to power on again.
Although it happened again soon after.
I don’t think I’ve had a problem with it since then, but I do notice that sometimes the battery apparently drains unexpectedly while powered down. When it goes down to zero, I think it needs to be connected to an outlet for several hours to allow the battery to build up enough charge to power on again. (Even if there’s no LED indicating that it’s actually charging.)
Etcetera.
This my first and last digital phone.
Are you suggesting the power/charger is the issue/history? I just checked the two Puri websites product lists and unless it’s somewhere else, I don’t see I may buy another power adapter/charge.
I do have a couple dozen laptop power adapters and could cut them up. But, I get the impression that A; the adapter is L5 proprietary and if that’s the case, I’d hate to compound the matter taking by on the hat of a phone technician.
I don’t have any of the other things you mention.
It’s not as if I worked the L5 so much I wore the battery to death. On the contrary, I take L5 out once, sometimes twice a week for average 4 - 5 hours and it goes back on the cradle. IMO, battery should still be good.
IMO - what happened mis the L5 battery ran out of the ability to charge because I kept it up too late.
A side note: I was with a friend who has a duop-stalker phone AKA, digital; phone. and it’s battery had a long way to go (78%). Knowing I might be late, I unplugged a Samsung Galaxy S8 Tablet. it was 79% when plugged back in when to it’s charger then I plugged in the L5 c/ adapter
I don’t know at the exact time the L5 battery died because I had no need to wake it until today.
Thanks for chiming in with your ideas - it’s appreciated,
~s
For how many seconds?
I don’t know how many options there are or the exact number of seconds or even whether or where this is documented but there is some kind of long press that is longer than the usual press for powering on and the long press is a reset that may help if things get in an unusual state e.g. Apparently-dead L5 - #7 by Skalman
PS Also Charging issues - Purism user documentation
For a proper, full reset, you need to hold the power button for about 20 seconds while USB cable in unplugged. It won’t work when plugged in.
If it drains after turning it off while plugged in, then it’s not unexpected :wink:
Not while plugged in. :wink:
I mean when it’s disconnected, turned off, and sitting unused for a while.
In any case, it doesn’t happen regularly or consistently.
Not exactly, it is more that below a certain threshold voltage a battery/charging hardware will consider the battery damaged/failed. Some devices have a low level trickle charge that lets you recover from this below-the-threshold state but most don’t. This is where directly forcing a charge with the dumbest of charge curve devices like the vape-pen charger circuit or even the bare USB 5v in for short boost periods to get the battery above the threshold voltage where the normal charging circuit begins to run normally. I have encountered this issue since at least the openmoko era in the 2003ish time period. It is a safety protocol since the charge circuit can’t evaluate anything else about the li-ion cell and it doesn’t want to put energy into a dead, failed, balooning cell.
On the pinephone there was a tow-boot or u-boot fork that had a special charge mode, but that would require threshold voltage to get into blue-light mode.
I noticed that I sometimes have to hold the power button really long to boot the phone (when counting, which I try to do at second speed, I get sometimes above 40). This is rather anecdotal information, but I have to hold the power button sometimes way longer than what I would expect.
Here is something written about holding the power button for 15 to 18 seconds, but my experience is that sometimes you have to hold the power button longer.
Unfortunately, I am a bit vague here, because I write from what I remember, and I do not know exactly when this happens, and I do not know how to reproduce this. But I think this happened when my battery had been very empty, which I always try to prevent.
there is a datasheet somewhere or notes in the bootloader to tell us what the various button options are at boot. Similar to android going into recovery mode or fastboot mode with pwr&vol+ or - pressed.
I was talking about the moment of powering it off.
The same will happen if you turn it off forcefully by a power button long press.
That would likely mean that the press was interrupted, it needs to be continuous and if you don’t press hard enough you may feel it as pressed while it’s not recognized as such.
i.MX 8M Quad reference manual and u-boot source code. Also, one could implement additional “modes” with u-boot scripts.
Fixed it my way.
Thanks Sharon
~s
Hammer? :wink:
[Edit: I should add that on these forums when one asks for help and then manages to solve the issue themselves, they reveal that solution. Why? To help others who might have the same problem.]
Perhaps a wee bit off the track, but might be helpful anyways:
I built myself several bigger lithium-based batteries (several kilowatthours for mobile and stationary use - indoors and 365/24/7 outdoors). One really important point from running those several years:
Never let lithiumbased batteries drain to zero. Always use a battery management system that avoids total drainage and overcharging as that kills all lithiumbased cells on first approach.
Also never rely on those security measures for a prolonged time as those BMS’ses themselves require a small portion of energy, too. Which drains the cells longterm even more.
Having mentioned above fact - although probably everybody knows: I reckon the Librems all consider this fact and have build in all relevant security measures ;).
Holding the powerbutton very long might overcome the issue of this thread.
I just had the “dead” issue again, after my L5 sat fully charged and unused for a week. Here’s what I tried, and how I eventually recovered it:
  1. Plugged it in and charged for hours. (No apparent effect.)
  2. Followed this guide to try and mount the L5’s storage on my laptop. (Failed to mount.)
  3. With battery removed, plugged in to wall outlet again. (Blinking red LED - It’s alive! It’s alive!)
  4. Reinserted the battery. (Blinking red LED changed to solid red LED - Charging!)
  5. Left to charge for an hour or so, then powered on. (Battery was at 0%.)
  6. Powered down, and continued to charge for several hours.
  7. Eventually, red LED turned off, indicating charge complete. (Right?? Although I didn’t power on to confirm 100%.)
  8. Powered on normally this morning, and charge was at only 52%. (Why not 100%?)
@dos, any insights?
Turn the phone off, take the battery out for a few seconds, put it back in and then boot. What’s the value reported?
When the battery gauge’s configuration is uninitialized, Jumpdrive will program it with parameters for the Birch batch, which will make its readings very wrong on other batches.
If “no apparent effect” means no red LED, then it wasn’t charging for hours. It wasn’t charging at all in fact :stuck_out_tongue:
76%
No red LED and no heat from charging.
Exactly. :rofl: “Plugged in for hours,” then.
EDIT: Now I’ve plugged it in again, and the reading just reverted to 0%.
Powered off and on again, back to 73% and charging.
Post all values then: tail -n+0 /sys/class/power_supply/*/uevent
purism@pureos:~$ tail -n+0 /sys/class/power_supply/*/uevent
==> /sys/class/power_supply/bq25890-charger-0/uevent <==
POWER_SUPPLY_NAME=bq25890-charger-0
POWER_SUPPLY_TYPE=USB
POWER_SUPPLY_MANUFACTURER=Texas Instruments
POWER_SUPPLY_MODEL_NAME=BQ25895
POWER_SUPPLY_STATUS=Charging
POWER_SUPPLY_CHARGE_TYPE=Fast
POWER_SUPPLY_ONLINE=1
POWER_SUPPLY_HEALTH=Good
POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=1472000
POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=1472000
POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE=4208000
POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE_MAX=4208000
POWER_SUPPLY_PRECHARGE_CURRENT=128000
POWER_SUPPLY_CHARGE_TERM_CURRENT=128000
POWER_SUPPLY_INPUT_CURRENT_LIMIT=1500000
POWER_SUPPLY_VOLTAGE_NOW=4204000
POWER_SUPPLY_CURRENT_NOW=-750000
POWER_SUPPLY_TEMP=300
==> /sys/class/power_supply/max170xx_battery/uevent <==
POWER_SUPPLY_NAME=max170xx_battery
POWER_SUPPLY_TYPE=Battery
POWER_SUPPLY_PRESENT=1
POWER_SUPPLY_TECHNOLOGY=Li-ion
POWER_SUPPLY_CYCLE_COUNT=4
POWER_SUPPLY_VOLTAGE_MAX=4200000
POWER_SUPPLY_VOLTAGE_MIN=3420000
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=3300000
POWER_SUPPLY_VOLTAGE_NOW=4209531
POWER_SUPPLY_VOLTAGE_AVG=4208906
POWER_SUPPLY_VOLTAGE_OCV=4015078
POWER_SUPPLY_CAPACITY=79
POWER_SUPPLY_CHARGE_FULL_DESIGN=4199160
POWER_SUPPLY_CHARGE_FULL=4199160
POWER_SUPPLY_CHARGE_NOW=3332333
POWER_SUPPLY_CHARGE_COUNTER=107978
POWER_SUPPLY_CHARGE_TERM_CURRENT=159343
POWER_SUPPLY_TEMP=414
POWER_SUPPLY_TEMP_ALERT_MIN=-1280
POWER_SUPPLY_TEMP_ALERT_MAX=1270
POWER_SUPPLY_TEMP_MIN=-2147483648
POWER_SUPPLY_TEMP_MAX=700
POWER_SUPPLY_SCOPE=System
POWER_SUPPLY_TIME_TO_EMPTY_NOW=368634
POWER_SUPPLY_CURRENT_NOW=838894
POWER_SUPPLY_CURRENT_AVG=836082
POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000
==> /sys/class/power_supply/tps6598x-source-psy-0-003f/uevent <==
POWER_SUPPLY_NAME=tps6598x-source-psy-0-003f
POWER_SUPPLY_USB_TYPE=SDP DCP CDP C [PD]
POWER_SUPPLY_CURRENT_MAX=1500000
POWER_SUPPLY_VOLTAGE_MAX=12000000
purism@pureos:~$
