[MyL5] Received my Librem 5 (Evergreen)
A maybe interesting observation: In the Files App, just as on any personal computer, you can move objects (docs, pics, etc.) to a level called “Desktop” or even make a “Link To” (i.e. shortcut) for said object, but it doesn’t actually display anywhere in a visible form on the phone’s app list screen or on the wallpaper screen.
Not that I would expect it, too. Just a fun fact.
A future capability, maybe…?
@amarok: Just wondering whether you have tested the GPS.
Is there any app that you have used that shows that it is working / not working? (Obviously the camera app would be one such but the camera itself is not ready.) I suppose you would also have had to have ventured outside of the house, which for COVID and other reasons, may not have happened yet.
No; I don’t really see a way to test it (if it’s even ready as a function yet). There’s no setting yet for “Location” like you would find on Android or iOS, as far as I know.
@amarok you could install Gnome Maps or PureMaps (from Flathub), switch off Wifi and start the map app and see if it can locate your position?
I windet if Therese isn’t any CLI tool which prints coordinates.
@kieran, @db579, @prolog
I installed Maps using @Skalman’s instructions here: GNOME Maps debugging adventures on the Librem 5 (Thanks Skalman! My first time with flathub/flatpak!)
Map displays well. When I tell it to find my location, it pulls up a dialog telling me to enable location services, with a button that takes me nowhere. (Still no official Location settings in the phone’s menu.)
Hopefully, something official will be implemented before long.
Thanks for the test. Hopefully soon then!
Just realized there IS a Location Services in the settings, and it’s On, but it never helped with Maps. Sorry about the misinformation! I suspect it’s just not implemented yet.
Finally remembered to get and test the second Q heifer but no sign of the double-tap or did not work at all. Was it suppose to be included in the plain amber phone images (6044, 6119, updated)…?
FYI a kernel update has just arrived that enables proper USB PD current negotiation :slight_smile:
Thank you for the update! Does fast charge degrade the battery faster? If so, can we manually choose the charge rate?
Yes, you could do that already before as well:
sudo i2cset -f -y 3 0x6a 0x00 <VALUE>
where <VALUE> is between 0x00 (100mA) and 0x3f (3.25A). See https://www.ti.com/lit/ds/symlink/bq25895.pdf page 32. You can verify the currently set value with
cat /sys/class/power_supply/bq25890-charger/input_current_limit
This is also useful to set input current limit to a higher value than the default 500mA when using USB-A chargers.
If I Set it that way, how to get then back to the proper USB PD current negotiation?
Just remove the USB-C cable?
I would issue a WARNING here for anyone tempted: BE extra careful with this kind of command, before using it :
  • if it’s connected to a charger or powerbank, check its capabilities (ex: 5V ⎓ 2A)
  • if it’s connected to a device USB port, what kind is it ?
  • Double, triple check the command line before validation
  • It’s safe to put a lower value than the one already set
  • if you want to put a higher value you have to understand what you are doing
/!\ Do not use if you are not sure of what you’re doing /!\
You could seriously damage you stuff !
Feel free to add any other security recommandations, or to explain to me if I over-reacted here :wink:
@Cc281080 : I assume you could save the value before changing it and putting it back, or disconnect-reconnect the USB-PD cable
Yes.
You didn’t, thanks for saying that :slight_smile: Maybe with one comment: the phone will stop drawing power automatically once the voltage drops below a certain threshold, and setting a high value won’t necessarily mean that it will draw that much power (it’s just the maximum limit), so with well-behaving chargers it shouldn’t really be dangerous. However, keep in mind that not all chargers are well-behaving.
Let me stress the importance of another warning though:
i2cset is a low level tool that allows you to directly set certain hardware registers. Always make sure you have typed the arguments correctly since you may be one typo away from breaking your hardware. When it doubt, consult the datasheet.
The charging ability of a device is a pair of values: voltage and current. So your device might have the rating of 5V and 2A. This will be noted as sth like 5V·2A or 5V, 2A, or 5V@2A. But I’ve never seen “5V == 2A”, and let no one be fooled that there’s any kind of equality there :stuck_out_tongue:
You are thinking to much like a low level developper ! :smiley:
I used == because my lazy ass didn’t looked for the DC symbol Unicode character
So by (5V == 2A) I meant (5V ⎓ 2A)
I’ll edit my post :stuck_out_tongue:
Nah, I’m thinking about all the people without much physics knowledge that might come here and misinterpret the mental shortcuts those more experienced take. Thanks for updating!
can you find the app ‘Metadata Cleaner’ on the L5 store ?
just noticed this GUI-front-end on PureOS-10-Byzantium store today and wondered if it’s on L5 as well.
